Old Jan 03, 2013, 03:26 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Importance of using fresh batteries in both the transmitter and heli....
Jake8131 is offline Find More Posts by Jake8131
Old Jan 03, 2013, 03:39 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
How did you get this snapshot of my landing? There's another $50 million down the drain. ...Scratch that: It appears that they can use some parts to cut it down to around $41 million.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Jan 03, 2013, 03:41 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
The rocket pylon still looks good to me
Chap1012 is offline Find More Posts by Chap1012
Old Jan 03, 2013, 03:43 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Time to take inventory and put another order in to HopMeUp.com.
Old Jan 03, 2013, 03:54 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
I wouldn't be standing in front of the rockets if I were them!
Heli Pad is offline Find More Posts by Heli Pad
Old Jan 03, 2013, 03:55 PM
Wind Spirit is offline
Find More Posts by Wind Spirit
Wind you go around in circles
Wind Spirit's Avatar
United States, FL, Middleburg
Joined Jan 2012
Originally Posted by 1Pilgrim View Post
Man, some of those fixed wing pilots make us heli drivers look like rocket scientists. They would croak if they knew all we have to go through just to get our finicky machines into a stable hover.
All they have to do to go blasting around the sky is bolt on a seriously dangerous motor, load up a hymongous battery and make a cursory check of the cg.
Recently out of the goodness of my heart I tried to get some of the guys on the T-28 thread to consider applying some simple statics principles to nail down the cg more precisely. They would have none of it!
For some reason they are content to flip their craft on its back, plop its wings down on a couple of sharp objects and wait to see which way it tilts!
I posted a more sensible method on my blog - you might want check it out.
That was GREAT!, you may want to have it published.
I am with you about the birds. As far as the fury friends, well, they make a great stew. One thing I can tell you about us country boys, we will never go hungry!
Wind Spirit is offline Find More Posts by Wind Spirit
Old Jan 03, 2013, 04:01 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by rwek View Post
Took my 120 SR out today. First time in quite a while. Was able to use a local gym. Once powered up I realized that I had no rudder. The servo doesn't move, whichever one it is. Not sure which servo is the rudder. Once home I started to disassemble it to see if anything stands out. The only thing I can see is a thin copper wire from the upper left of the board is not attached to anything. That is if you are looking from the rear of the heli. I plugged in the battery and moved the stick and absolutely nothing. Any ideas? I am using a DX 7 Tx by the way. I used it for a MQX prior to trying to fly the SR 120 so it was functioning fine prior to this.
The rudder doesn't use a servo... rudder comes from controlling the speed of the tail rotor... directly from the output of the ESC
The wire you saw is the antenna, it's not supposed to be attached to anything (well, it needs to be attached to the board )
North_of_49 is offline Find More Posts by North_of_49
Old Jan 03, 2013, 04:09 PM
Joined Dec 2011
WHY is my antivirus still going nuts on this website???!!!:eek:
careful here today, guys...
Infection Details
URL: h t t p://d1ros97qkrwjf5.cloudfront.net/42/...
Process: C:\Program Files\Internet Explorer\iexpl...
Infection: URL:Mal
EDIT
http://www.rcgroups.com/forums/showthread.php?t=1801134
http://www.rcgroups.com/forums/showthread.php?t=1801055
Old Jan 03, 2013, 04:51 PM
rwek is offline
Find More Posts by rwek
St. Louis, Mo.
Joined Jun 2008
OK. I should have known that. Possible that the tail motor is out? I guess I should be looking back there then. Looking in the wrong place.
rwek is offline Find More Posts by rwek
Old Jan 03, 2013, 05:03 PM
DaveNH is offline
Find More Posts by DaveNH
DaveNH's Avatar
United States, NH
Joined Nov 2012
Infection Details
Infection: URL:Mal
EDIT
Are you using Avast? I noticed some that posted about it are, might be a false positive.
DaveNH is offline Find More Posts by DaveNH
Old Jan 03, 2013, 05:23 PM
Joined Dec 2011
Yes.
It's flagging offsite content this site loads in the background from an advertiser or tracking tools as malicious. Sometimes those are false positives, sometimes they're legit. There's obviously a reason cloudfront is on a shite list... sometimes a site doesn't even know they are forwarding malicious content. Personally, I'm not too concerned out this one but best to be aware... thought I'd pass on what some are experiencing.
It's still doing it by the way.
Old Jan 03, 2013, 05:26 PM
Joined Dec 2011
If the tail rotor was out you'd know it pretty quick... you'd be spinning (yawing) rather hard in place.
Old Jan 03, 2013, 05:36 PM
DaveNH is offline
DaveNH's Avatar
United States, NH
Joined Nov 2012
Yes.
An advert was my next guess, not too uncommon to have adverts doling out malware. Would also explain why I'm not having an issue, I block allot of advertising and tracking domains via OpenDNS and DNTP.
Old Jan 03, 2013, 05:44 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
I'm using Avast and I've been on this web site all day. Mine doesn't complain (for better or for worse).
Old Jan 03, 2013, 06:18 PM
Joined Dec 2011
Originally Posted by heli pad View Post
i'm using avast and i've been on this web site all day. Mine doesn't complain (for better or for worse).
Description:
Edit
seems to be taken care of now.
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
