Old Dec 08, 2012, 03:27 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by SR120 fan View Post
The only problem I have with nuclear is that developing countries simply to do not have the funds to build them and instead will resort to coal burning power stations. ... All surplus energy will stored easily as hydrogen, perhaps using underground natural structures or just the same way we store natural gas. Forget fuel cells they will never work for the masses as they require the rarest elements on earth to work and are just a decoy by the petrol/car companies to buy themselves a bit more time.
As for what Battle Dude said. Unfortunately I think anyone in a position to make a difference thinks the same and doesn't want to ruin their retirement pot.
No 3rd world countries should have nuclear, period. I like your hydrogen storage concept as long as it's not used to develop heavy water and ends up bombs. Maybe we ought to forego this conversation, however, as I think we've now taken it way beyond RC!
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Dec 08, 2012, 03:30 PM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Chap1012 is online now Find More Posts by Chap1012
Old Dec 08, 2012, 03:32 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Mike... Are you trying to tell us something?
Old Dec 08, 2012, 05:00 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Wow, we must've touched a nerve! I'd still like to see a "glow in the dark" 120!
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Dec 08, 2012, 05:40 PM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Crowheart
Joined Aug 2011
Maybe we ought to keep it to the 120SR-N (RC)
Fly for 2 years without a recharge!
BattleDude is offline Find More Posts by BattleDude
Old Dec 08, 2012, 05:43 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I just have to think that nuclear powered R/C helicopters could serve a starving world--in some way or fashion.
Old Dec 08, 2012, 05:44 PM
grampi is offline
Find More Posts by grampi
Joined Jan 2005
Originally Posted by Brian VT View Post
You'll need to get from JST to the 1 cell outlet on your charger. Is that 1 cell outlet a female for JST (same as on your 120SR) ?
Either way, I haven't seen an "octopus" harness that would plug into that 1 cell outlet. Most have banana plugs. You may have to rig something.
Forgive me but I guess I'm out of of touch with all these acronyms...what is JST? I don't think I want to charge multiple batteries off of one outlet....charging 4 batteries on one outlet would mean I'd only have a max amperage of .5 amps...that would make for some pretty slow charges...being able to use all 4 charging outlets would give me a lot more flexibility...now if I can just find out where to buy the connectors and pins so I can make my own charging adapters....
grampi is offline Find More Posts by grampi
Old Dec 08, 2012, 05:59 PM
Brian VT is online now
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
JST is the type of connector your 120SR, and it's battery, have.
You will use your 1cell outlet for 1cell batteries. That can be as many batteries as you want (in theory) on a proper harness.
Your charger has a max. output of 2amps. It can/should all come out the 1cell outlet.
Most recommend charging at 1C. You could charge four 500mAh batteries at 1C with your charger that puts out 2A through the 1cell outlet.
You need you find a connector to go from JST to whatever that is for your 1cell output to charge the lipo(s) for your 120SR.
This is the basic, plug-n-play method. If you want to get into funky wiring beyond that, well, go for it. I can't help with that.
Brian VT is online now Find More Posts by Brian VT
450man is offline
Find More Posts by 450man
450 Helis Rule!
450man's Avatar
United Kingdom, England, Saltash
Joined Aug 2012
The white ports look like balance ports to me... not charging ports. Normally charging only requires 2 pins... + & - ... regardless of the number of cells.
Could they be combined charge and balance ports perhaps? Clearly, I have no idea???
450man is offline Find More Posts by 450man
Old Dec 08, 2012, 06:01 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Yes.
Old Dec 08, 2012, 06:38 PM
grampi is offline
Joined Jan 2005
You will use your 1cell outlet for 1cell batteries. That can be as many batteries as you want (in theory).
What's 1C? What I do know is this charger will put out 2 amps from each of it's 4 charging outlets. If I were to rig up an adapter so I could charge four 1 cell batteries on one outlet, that would split the amperage 4 ways...meaning a max charging output of .5 amps per battery, which would be too slow. If I could find a place that sells these connectors, and the pins that go in them I'd be in business...with a pin and a wire on each + and - on each of the charging outlets would give me four 1 cell charging adapters with up to 2 amps of charge available to each battery.
Old Dec 08, 2012, 06:45 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
What is 1C??? C'mon. Enough hijacking of this 120 SR thread. A complete and thorough Lipo battery charging education can be found in myriad places on the web. Right here on RC Groups in fact is enough information to educate yourself about the basics of (safe) battery charging and use.
And here
stuball56 is offline Find More Posts by stuball56
Old Dec 08, 2012, 08:59 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
For 5 bucks more the Thunder AC680 is a better deal than the old AC6.... it's the upgraded version...
80watts instead of 50.
6amp charge current instead of 2.2.
I was going to get one for a backup but I won't be buying from hobbypartz anymore
North_of_49 is offline Find More Posts by North_of_49
Old Dec 08, 2012, 09:43 PM
grampi is offline
Joined Jan 2005
And here
I guess I did get off topic...sorry...I did get the connectors I needed though...
Old Dec 08, 2012, 10:26 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
"Hijacking" would be a little harsh. This forum is made for those who are wanting to know more and we've always been courteous.
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 09:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 04:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 05:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 01:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 10:36 AM
