Old Nov 25, 2012, 10:03 AM
Flight Freak
BattleDude's Avatar
United States, WY, Crowheart
Joined Aug 2011
Originally Posted by 1Pilgrim View Post
Hate to bring everyone down on a holiday weekend, but my 120's been grounded since last Tuesday with what sounds like a bad esc.
I wanted to take my batts down for storage last week before heading out of town. After doing the first few the boring way (charger) I decided to try flying a few of them for 3 minutes each. My scatter diagrams showed that at three minutes the voltage would be down to around 3.85V. It should have worked, but...
The first flight was fine but a minute or so into the second flight the heli went to full throttle and pinned itself to the basement ceiling! I tried everything I could think of, even turning off the tx, but to no avail - the li'l dickens just kept bouncing off the ceiling like an oversized crane fly. I reached up and grabbed it and had my wife hold it by the skids while I disconnected the battery. She was not amused.
After flushing the adrenaline out of my system I turned on the tx and loaded up a fresh batt. The heli responded normally to swash and tail rotor inputs but the main motor only answered the call intermittently, maybe 30% of the time. I could hear a high-pitched whine whenever the throttle was advanced, even when the main motor wasn't responding.
Is there a fix for this or do I need a new board or could it be something else entirely?
I think it sounds like a circuit fail on the board, myself. I can't picture in my mind, anything else it could be.
BattleDude is offline Find More Posts by BattleDude
Old Nov 25, 2012, 02:52 PM
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
Originally Posted by stuball56 View Post
That would be horrible if it happened outside! You would lose it. I fly mine outside whenever the weather is ok, (no wind).
Yeah, it's too cold and windy here so we're back indoors for the winter. I had 12 good flights at the gym the previous Saturday. It would've been quite a show if the heli had gone to full throttle and started banging its head on that high ceiling!
I'm gonna look for burn marks on the board and maybe apply some alcohol with a Q-tip. If I can't resurrect the board I may decide to spring for a whole new heli - this one has well over 500 flights on it in the past 18 months.
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Nov 25, 2012, 04:23 PM
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
I took off the canopy, head and pushrods then disconnected the main and tail motors and removed the brick leaving the shaft, main gear and motor installed on the heli.
Plugging the battery directly into the main motor did spin the motor and shaft - so far so good.
Turning on the tx and plugging the battery into the brick did bind the brick to the tx and allow the swash servos to function - so far so better.
Plugging the main motor into the brick did allow the main motor to respond to throttle inputs - more joy, but it only lasted until the next step.
Aye, but here's the rub. Plugging the tail motor into the brick allowed the tail rotor to respond to stick inputs (throttle and rudder) but the main motor no longer responded to the throttle through the brick; now it only runs when plugged directly into the battery.
There are no traces of burn marks on the board and I never detected any electrical smells; even so it looks as though something is definitely wrong with the board. My lhs quotes $65 US for a new one; anybody have a cheaper source?
Old Nov 25, 2012, 04:51 PM
If It Works, I'll Break It
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Spend the extra $$ and get a BNF and use your old one for spare parts.
Jake8131 is offline Find More Posts by Jake8131
Old Nov 25, 2012, 05:16 PM
Look ma, no hands!
1Pilgrim's Avatar
Joined Aug 2011
Definitely leaning that way, especially with the indoor season just starting. I learned so much from my first heli that it'd be fun to mod and upgrade a brand new one. Anybody know if the new ones are still identical to the original?
Old Nov 25, 2012, 05:52 PM
Joined Apr 2010
My son finally destroyed his tail motor after about 3 months of flying. But I decided to ditch replacing it and have him work on my old walkera v120D01 as preparation for a CP heli-- the V120D01 is fixed pitch, but does not have that much self stabilization and is a great trainer for a CP. Unfortunately, that heli has been discontinued by Walkera, but I have enough spares to keep him airborn for awhile.
I wish Blade would enable a good intermediate/transitional FP heli in the 120 size (like the MSRx...)
Chief
BHChieftain is online now Find More Posts by BHChieftain
Old Nov 25, 2012, 07:25 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Do you mean that the main motor was functioning properly before you plugged in the tail motor? I've had this happen and replacing the tail motor solved my problem. Sometimes, when the tail motor gets fried, it takes away amps from the main motor. Try another tail motor before buying a whole new one.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Nov 25, 2012, 09:13 PM
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Had the same problem on my MSR and a tail motor fixed it.
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Nov 25, 2012, 09:42 PM
Joined Jun 2012
Erratic flight
I just bought a 120SR RTF after months of reviewing helis. I was really excited, until it lifted off for the first time. It acted like it was a pendulum moving several feet back and forth, went in circles (toilet bowl effect), and didn't follow the input from the remote very well. I have only had it in the air a few times and then it was pretty much just to trim it. It acts like the 120 in this you tube video:
http://www.youtube.com/watch?feature...v=bW4At9fPCq4#!
I tried rebinding it to the transmitter, tightening and loosening the screws in the blade grips, but nothing seems to help. Any suggestions what to look at next? I ordered a Rackon CNC flybar in hopes that will help. Thanks for any help.
hereathome is offline Find More Posts by hereathome
Old Nov 25, 2012, 10:02 PM
Not another moment lost...
Chap1012's Avatar
USA, MA, Malden
Joined Mar 2008
That doesn't look too bad to me. Pop off each link one at a time and polish the balls with a piece of paper bag. Lube the balls with a plastic safe lube (i use Break Free CLP). Insure the flybar is straight,,..do this by eye. Carefully bend to shape. Your heli is demonstrating a flybar problem.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Nov 26, 2012, 02:41 AM
Jake8131's Avatar
Joined Dec 2010
Looks to me like a cracked main shaft causing the shaking.
Old Nov 26, 2012, 05:28 AM
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Sounds like a fried FET. I've discussed it here more than a few times and relatively recently. I bought mine in that condition on the cheap last winter. It's more common with the 120 than we'd like it to be.
Bought my new board from valuerc on ebay for a little over $40 at the time. Guys buy 120's and part them out.
North_of_49 is offline Find More Posts by North_of_49
Old Nov 26, 2012, 05:35 AM
Joined Dec 2011
It's happened to more than a few people I know of with this specific bird.
Old Nov 26, 2012, 05:36 AM
Joined Dec 2011
Originally Posted by Wind Spirit View Post
Hi, I have not heard of this problem before, :
Yes, you have
Old Nov 26, 2012, 05:39 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
I would not use a Rakon flybar, yet. The SR120 works best with stock parts. When you start modifying, you begin to incur 2nd and 3rd order of problems that you will not understand. I know--that's how I started out in this hobby!
Check what Mike says about smooth functioning links, and that your flybar and main blades are tracking perfectly. If you do not know how to do that, let us know, we can help. Check that the tail boom is not cracked or loose. If everything is in order, your gyro may be off and you should contact Horizon Hobby. They back their products.
Addendum: The video looks fairly normal, so that is not bad. The 120 is made to keep flying--hovering is more of an art.
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6526 Jan 12, 2013 12:20 PM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro RTF 2 Jan 07, 2010 09:36 AM
