Old Oct 04, 2012, 12:08 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Originally Posted by BattleDude View Post
The Nano is supposed to be much easier than previous CP's. If I understand right, it doesn't even need trimming.
I have rolled around the thought of one also.
Saw them in my LHS today when I popped in on my way home from work. Had to resist the urge. After following the Carbon Cub and 130x since their release I want to see how this plays out first... hopefully less (or no) issues
North_of_49 is offline Find More Posts by North_of_49
Old Oct 04, 2012, 03:56 AM
SR120 fan is offline
Find More Posts by SR120 fan
United Kingdom, England, Kent
Joined Sep 2012
Thanks a lot guys for the responses. I fell asleep shortly after posting. I got the fly bar to move by applying some considerable force to the swashplate as I thought it might be a bearing issue which I think it maybe. But there is so much DIY that has been done it could be anything. The good news is that the rotors will now spin fast enough to fly no worries. The bad news I have zero control because of the swash plate (balls broke, glued on end of links and one of the servos is pretty much knackered.
Regarding the don't go there. I went there as I had no choice because one of my holes snapped but the servo/heli hasnt worked properly ever since the solder issue where I melted it anyway.
The reason why I think the balls are on their last legs is I've had numerous ones now snap and the leg bits that are attached to the balls are starting to go that colour where they have been played with a bit too much.
I definitely need a new swash plate as there are no balls and Im doubting the bearings and links are as bent as bent can be.
One other little worry was the rear boom came off. When it was off, both rotors would run no problem. When I pushed it in too far neither the main rotor or rear rotor would run? Any ideas.
I will look into the collar issue but as the servos are so screwed, there is probably little point now. Im quite happy that the rotors ran well though. But more fixing required. Might look into getting another SR120 if i can find one second hand but over here they seem to go for nearly the same price as new ones.
I will probably carry on the fixing cause though for one last time. After that it is a new heli and the old one for spares (bad spares)
SR120 fan is offline Find More Posts by SR120 fan
Old Oct 04, 2012, 06:27 AM
Brian VT is offline
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
Originally Posted by Jake8131 View Post
Does anyone know what is up with HeliFreak????
http://www.rcgroups.com/forums/showthread.php?t=1743908
Brian VT is offline Find More Posts by Brian VT
Old Oct 04, 2012, 12:43 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Are you calling me a freak???? Or, what's up with the forum?
Edit: Oh, now I see your link. Nothing came up on my Mac.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Oct 04, 2012, 01:11 PM
Chris.S. is offline
Find More Posts by Chris.S.
Registered Abuser
Kelowna, BC Canada
Joined Nov 2010
Sorry but, did you say you glued the links on to the swash balls?
Chris.S. is offline Find More Posts by Chris.S.
Old Oct 04, 2012, 04:04 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Chris, you beat me to it. I read it the same way...
@120SR fan, Please post some pictures of your work and what you've done. BTW, pull the boom out from the main frame carefully. You'll notice there is a notch at the top (inside the hole). Make sure your wires are inside that notch/channel when you slide the boom back in. Inspect the wires while you have the boom off. It's possible you could have damaged a wire if it was put in there wrong.
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Oct 04, 2012, 04:44 PM
Joined Sep 2012
No balls to glue onto as they were long gone. Glued straight onto the swash plate. Desperate times lol
Old Oct 04, 2012, 04:50 PM
Joined Sep 2012
Mike.
You don't want pictures. They would make you cringe. In fairness if it wasnt for the one knackered servo I reckon I could get her flying in some sort of fashion.
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Wow! That can't possibly work. If the balls are not perfectly straight, you will always have problems. Unless, of course, you have meticulously placed these balls directly back on like the original. If you can do that, you should just build your own helicopters!!! Use the parts as a pattern and create your own 2X one or something!
Old Oct 04, 2012, 04:58 PM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Break out the champagne!!!! My DX8 has returned!!!
They repaired the left trim mechanism, but surprisingly, they also replaced both gimbals!!! I didn't think there was anything wrong with the gimbals. Now I'm wondering why they thought they needed to be replaced????
I could understand, however, if I've totally worn out the gimbals after the first year. Hey, as many times I've had to pull UP, steer RIGHT, steer LEFT, and WOAHHHH, watch out for that tree!!!!! Yeah, I could have worn out the gimbals.
I just went out and flew my 120 #3 in the wind and I am glad to see that the memory wasn't erased. When the wind dies down, I'll fly #1 & #2. I hate that darkness is coming way too soon now in this area.
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Dude, let me get this straight as I'm having a hard time wrapping my brain around this.
Are you telling us the ball is long gone. GONE! Right? That means you glued the link (that plastic piece with a hole at each end) right to the swashplate?
Am I reading you correct?
Old Oct 04, 2012, 05:32 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
SR 120 FAN!!
Jake8131 is offline Find More Posts by Jake8131
Old Oct 04, 2012, 07:01 PM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Fremont County
Joined Aug 2011
No Mike you silly bird, he glued the balls back on the swash plate!
SR120 Fan, don't pay any attention to these guys. I will slap them for you!
But anyway, just a thought for you... a simulator such as Phoenix or RealFlight can save a bunch of money on real aircraft parts and repairs.
It doesn't cost any repairs parts to crash time and time again with a sim.
My first 120 wound up in the boneyard real fast. If I would have had my Phoenix Sim first, I am positive my first 120 would still be around.
If/when you decide to upgrade to a computerized radio, such as the DX6i, you can also play with the settings in the radio to tame your real bird down, and in the simulator also.
I have Phoenix and the physics are very realistic. I am currently using it to prepare myself for the maiden flight of my Parkzone Spitfire Mark9.
Just a thought for you, I know it is expensive but if a person plans to stay in this hobby, the sim and a good radio are worth gold.
Cheers!
Kyle
BattleDude is offline Find More Posts by BattleDude
Old Oct 05, 2012, 12:29 AM
Joined Sep 2012
Yes. That's what I did. Guilty as charged. I'm assuming by the replies that this achievement/blasphemy isn't committed too often or with preferential results?
SR 120 FAN!!
Hahaha
Cheers!
Kyle
Unfortunately. The balls in question were not reglued and Chap got his head around it successfully. I quite want to show you the pics now. When I get home from Uni I will use the wife's phone and upload you the glory that is my glueing.
It must be said that I tried glueing the balls on but they were just not up to the job. I wasnt expecting great results. Just wanted her back in the air as it had been such a quick demise and parts take a little while to get here or i'm just impatient.
Regrading the simulator. I was already thinking about one and think you are right that it should go onto my more immediate list of things to obtain. I will get this one going again the more traditional route i.e no super glue and might just get a cheap one off ebay to get my fix around the house as I will probably get an mSR off someone for my birthday at the end of the month to play with.
Let the ridiculing begin
Had I started flying my SR120 in a park it would have lasted a lot longer but alas lack of common sense got the better of me and it was walls and trees galore
Old Oct 05, 2012, 06:41 AM
Wind Spirit is offline
Find More Posts by Wind Spirit
Wind you go around in circles
Wind Spirit's Avatar
United States, FL, Middleburg
Joined Jan 2012
Well, At least you did not use duct tape. You didn't did you?LOLWS
Wind Spirit is offline Find More Posts by Wind Spirit
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Helis 6658 Oct 28, 2015 08:24 AM
Discussion Update Blade CP or buy E-Flite Blade SR or 400? markhwing Electric Heli Talk 10 Aug 06, 2012 03:16 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
For Sale Did you just buy a new E-Flite Blade SR? Z06 Tony Aircraft - Electric - Helis (FS/W) 3 Feb 28, 2010 12:01 AM
New Product Blade SR RTF Electric Micro Heli by E-flite ghost2212 Micro Ready-to-Fly 2 Jan 07, 2010 09:36 AM
