And, a Phoenix nest where new Helis are raised up from ashes!!
The Nano is supposed to be much easier than previous CP's. If I understand right, it doesn't even need trimming. I have rolled around the thought of one also. |
United Kingdom, England, Kent
Joined Sep 2012
I just can't manage to get mine fixed up; Main rotors will go fine without the flybar attached, but completely seized when attached.
Need to replace the swash plate anyway as half the balls are on their last legs. What difference does it make if you attach the servo link to a different hole on the servo? |
You must have the links in the wrong position/or balls. Can you post a pic(s) from different angles? Mike. EDIT: What makes you think the swash balls is "on it's last legs."??? |
Sounds like you have the anti rotation collar upside down....happens. ![]() ![]()
Joined Feb 2012
I started off heli flying with the Blade 400 and a copy of the T-Rex 450.
It was a distinct pleasure to relax so much flying the 120 after learning on the others. The 120 can be flown indoors in a small room but just try that with a 400 or 450 or even 500 3D heli and unless you're an expert you'll be in a mess of trouble. I suppose the newer larger flybarless CP helis with 3 axis gyros are easier to fly but just the same, that 120 is an easy toy in comparison, safer, and less prone to major damage if it crashes. JLT_GTI - if you're having a problem with it "going elsewhere" when you try to stop then don't try to fly a larger heli until you either gain skills with the 120 and can make it do anything you what it to do and also learn to set up the heli properly. As I said, the 120 is relatively safe but those larger ones are not. It's easy to go from a 450 to the 120 but not the other way around. |
| Thread Tools | |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro Helis | 6526 | Jan 12, 2013 12:20 PM |
| Discussion Update Blade CP or buy E-Flite Blade SR or 400? | markhwing | Electric Heli Talk | 10 | Aug 06, 2012 03:16 PM |
| Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others | everydayflyer | Batteries and Chargers | 45 | Apr 08, 2010 04:55 AM |
| For Sale Did you just buy a new E-Flite Blade SR? | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Feb 28, 2010 12:01 AM |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro RTF | 2 | Jan 07, 2010 09:36 AM |
