Old Sep 09, 2011, 11:53 PM
ChopperJack is offline
Find More Posts by ChopperJack
Moving Parts
ChopperJack's Avatar
United States, MS, Columbus
Joined May 2011
Originally Posted by tracknoob View Post
I recently had a relatively new original Walkera 4f200 battery get puffy on me, not while flying, but after I left it in the truck. Dang, lesson learned, it gets too hot to leave the lipos in there while flying. So I really hated to give up on it, since clearly the stress was from a lone-time ambient thermal overload, and not from internal issues or electrical over-stress or age/break-down....
I read up on it, including both very-vocal ends of the spectrum; both the horror stories with scare-tactics, as well as the shoulder-shrugging "wait 'til it does something' "I've flown puffy batteries lots of times" types.
At the end of the day, I got on line, ordered a couple of new ones, and with that done, did the difficult task of snipping the leads off a $20-something dollar battery that was *probably* still usable and just chucking it.
My analysis was simple: Do you really want to risk this thing going up and endangering your heli, or a lot worse?
No, I do not.
Case closed.
I received my new battery and LiPo bag today. My two puffy LiPo's are going to visit the land fill. Thanks for all the help and advice.
Also, as to excessive heat caused by motor and ESC, I may have the motor and main gear a little too tight. I'm going to loosen that a bit and see if it makes a difference. Now I wish I had bought that little IR remote temperature gage I saw at Radio Shack today. I'll probably go back and get one to help in making comparisons.
Thanks - jack
LATER:
Case reopened. I've been meaning to make a comment about the recycling symbol printed on most LiPo batteries - the one that looks like a trash can with a line through it which indicates do not dispose with trash. Most batteries have this. The disposal procedure says it is okay to dispose in trash AFTER discharging. I wonder what we are supposed to do?
ChopperJack is offline Find More Posts by ChopperJack
Last edited by ChopperJack; Sep 24, 2011 at 08:28 AM. Reason: additional information
Old Sep 10, 2011, 12:28 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Thanks - jack
I can tell you that both when I got them new as well as now after a lot of flights, both of my helis like to have a decent gap -- they do not seem to wear gears (like the Erazor which gobbles them up like M&Ms!), so I would indeed let it 'breathe a little in the gear gap area -- the head spins *very* easily on both of mine, with no noticeable gear drag at all.
tracknoob is offline Find More Posts by tracknoob
Old Sep 12, 2011, 11:34 PM
Moving Parts
Joined May 2011
Originally Posted by ojo View Post
Hi Jack,
it is quite simple: I opened up the rx and looked at the chips The rest I know from flying two 2702 in a 4f200 and a V120D02.
Regards, Ojo
Did you plug stock 4f200 servos into the 2702 (sounds like you did)? Wow additional information says you have to upgrade to digital servos with the 2702.
Old Sep 13, 2011, 01:40 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
DEFINITELY NEED DIGITAL SERVOS!
I often forget to mention that in my own discussions about mounting the 2702 up to the 4f200, but it is critical!
The good thing is that the stock ESKY HBKII items work perfectly, and fit fine, and are cheap, and a lot of us happen to have them around the house anyway, so for me, I did not even have to order parts to do the conversion, I already had them on hand.
I did not however, mount digital servos on the 4f200 that I put the 2618 on. I looked at the bill of materials/parts list for the 4f200LM, and it uses the same non-digital servos that the 4f200 uses, so there should be no problem functionally, although if performance is sluggish or otherwise not up to par, then that would be among the first things to check/eliminate, I would think, especially in order to do a fair comparison between just the radios themselves.
Old Sep 22, 2011, 09:14 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
I just received my 4F200 2 days ago. The AIL/ELE gyro functions don't work. The tail gyro seems to work fine. Has anyone else received a DOA RX on this heli. ?
I tried everything I know to get it to work, but the RX gyro is definitely DOA.
I had the same problem with a RX2618V that I bought for my FBL modded 1#A, I replaced the RX, and the new one worked fine.
clearprop88 is offline Find More Posts by clearprop88
Old Sep 22, 2011, 09:37 PM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Have you cycled the switches on the rx? I've heard that can eliminate weird things like this. Are you sure the rx switch for the 3 axis is in the correct position? I don't have a 4F200 any more, but I think you can disconnect the motor (or use throttle hold), then tilt the heli to see if the swash responds. I think the thing needs to see throttle input before the 3 axis will work.
Do adjusting the pots make a difference?
Other than that, it might be dead.
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Sep 23, 2011, 04:31 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Rafa is correct in that the ELEV and AILE gyro's dont come into play until the throttle is at around 40%(RX-2612V). Disconnect your motor then test it by increasing throttle, then tipping the heli about watching the swash movement. The RX dip switch needs to be in "WK" (flight mode) as well for the gyro' to function.
Bravo47 is offline Find More Posts by Bravo47
Old Sep 23, 2011, 01:13 PM
Joined Apr 2011
Thanks Rafa, and Bravo for your inputs. I tried all those things, but it's still dead. A replacement is on the way.
Old Sep 23, 2011, 01:16 PM
Joined Apr 2011
I noticed that the mast, and head parts are available for the V200D03 from several suppliers.
Has anyone tried converting the 4F200 to a 4F200/V200D03?
Everything on these two heli's looks the same except for the heads.
Old Sep 24, 2011, 12:48 AM
Moving Parts
Joined May 2011
Too bad you couldn't have gotten them to send you a RX2618V as replacement. The gyro on this one is always on - none of that 40 percent stuff which might be okay but my 4f200 flies like a dream with a 2618 receiver.
Old Sep 24, 2011, 01:10 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Should have my own 4f200 with 2618 back aloft after the weekend, and I'll give a flight report. But I'm sure it will be anti-climatic, based on what has already been said about the improvement, and the fact my own maiden with the 2618 was indeed going VERY well.... at least, until my tail rotor failed, due to my own maintenance hiccup.
New parts have arrived, and are being installed, adjustments are being made... WHEELS ARE IN MOTION!!!
http://www.rcgroups.com/forums/showp...postcount=1678
Old Sep 24, 2011, 11:55 AM
Joined Apr 2011
Thanks Jack & Track. I have a 2618 RX that I plan to put in the bird today.
I agree about the 40% throttle. It should work as soon as it binds up. If I wiggle the heli. around the servos should respond right away. I'll see if it works that way when I get the replacement 2612.
Any suggestions for TX setup? I like to start with 60% all around, and 80% for Expo., and maybe 70% for the tail.
Is anyone using foam blades? I like to use foam blades on a new heli. so that if I hit anything the blades explode instead of the heli.
Any comments on my two blade mod.?
Old Sep 24, 2011, 12:49 PM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
F200 & 200LM have the same settings on TX. RX2618 is way stable than 2612, on mine is 80%/25% for DR-EXP. Foam blades on F200? i don't think it can fly correctly with.
AC
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Sep 24, 2011, 04:08 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I started with the Wow 4f200 settings, but I think I have over time done a tweak or two. Not sure exactly, but I think it's got to boil down to personal preference eventually anyway.
I have incidentally ended up with foam blades on two different helis and had trouble with balancing and tracking both. YMMV. Personally, on the 4f200, I think those cheapo plastic blades from Ebay for the Trex 250 are about the best deal in town, and they fly just like I like it -- crisp.
As to going to two blades... well, I am certainly guilty of a lot of 'spearmintin' and swappin' various stuff myself, so who am I to say? I will say that the sole reason that I got the 4f200 was the three blade head, and that with the right stabilization, the stock motor and stock tail make this a heckofa performer. I have a hop-up motor I got somewhere for it, but I've never been tempted to even take it out of the bag -- this thing SCOOTS, in all directions you can point it in.
Old Sep 24, 2011, 04:09 PM
rew-7 is offline
Find More Posts by rew-7
rew-7's Avatar
UK, Leeds.
Joined Mar 2009
Sure it can,http://www.dealextreme.com/p/fiber-g...-15-pack-48344 I use these all the time. They perform the same as original and definitely help cut down on crash damage. I also run 3s and quite a high HS. These blades are just scaled up versions of V120/4G6 blades.
I personally have had very little problems with tracking(above whats expected of a 3 blade heli) and balance the same as normal.
rew-7 is offline Find More Posts by rew-7
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 03:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 09:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 27, 2009 12:59 AM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 02, 2009 12:15 AM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 11:16 AM
