Old Feb 03, 2011, 11:34 PM
Xextriz is offline
Find More Posts by Xextriz
USA, NC, Havelock
Joined Jan 2011
Originally Posted by macz View Post
Hmm...wondering if I should get a 4f200 or the v400d02.. I have a 120d03 which flies like a coax..what do u u think is better? Is the 4f a handle to fly?
you do not want a v400d02 I'm pretty sure, never owned one. It's tail is driven by a separate motor and doesn't not use a servo to control pitch. You'll get better response from a v120d01, 4f200 or v450d01, something that's tail is driven by the main motor and controlled by a separate servo to control the pitch of the tail blades. That's my opinion at least.
Xextriz is offline Find More Posts by Xextriz
Old Feb 03, 2011, 11:44 PM
macz is offline
Find More Posts by macz
Joined Jan 2011
I have the 120d03 and it's tail is motor driven and is pretty good...
macz is offline Find More Posts by macz
Old Feb 03, 2011, 11:57 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
The bigger the heli the worse a tail motor gets... they work ok on the really little ones, not so much on the bigger ones. And the v400 has brushed motors, which don't last very long.
desertstalker is offline Find More Posts by desertstalker
Old Feb 04, 2011, 01:03 AM
macz is offline
Joined Jan 2011
I know brushed motors don't really last...is the 4f200 hard to fly I had a SR and that was a pain to fly...the 120d03 that I have is great...
Old Feb 04, 2011, 02:59 PM
macz is offline
Joined Jan 2011
Hmmm
Old Feb 04, 2011, 05:07 PM
Kevinmt10 is offline
Find More Posts by Kevinmt10
Joined Jan 2011
what are some good servos to us to replace the factory one's
Kevinmt10 is offline Find More Posts by Kevinmt10
Old Feb 06, 2011, 11:31 PM
Xextriz is offline
USA, NC, Havelock
Joined Jan 2011
For the 4f200, I use Futaba S3114 for cyclic and Align DS420 metal gear for tail
Old Feb 07, 2011, 02:27 AM
ojo is offline
ojo
Find More Posts by ojo
ojo
Joined Dec 2006
Hi,
I just put in the MKS DS470 and my first test-flights were convincing. You have to turn the receiver by 180 though.
Regards, Ojo
ojo is offline Find More Posts by ojo
Old Feb 08, 2011, 03:59 AM
ojo is offline
ojo
ojo
Joined Dec 2006
Originally Posted by stretch1100 View Post
Do we know what module the stock pinion is? .4 or .5 ? I found some venom ones that are 2.3 mm and will fit the shaft on the blue motor
Hi,
I think the pinions are module 0.3. I ordered some from this shop:
http://www.lemo-solar.de/
To widen the hole from 2mm to 2.3mm I used three drills consecutively: 2.1, 2.2 2.3 mm. This kept the hole centered. The scorpion 2208- 4660KV runs smoothly with the new pinion and fits well into the 4f200. I had do enlarge the mounting holes and remove part of the base cover, that was all.
Regards, Ojo
Old Feb 08, 2011, 09:17 AM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
Crap I hope you're wrong cuss I ordered some .04 mod ones based on DK's post ;-)
stretch1100 is offline Find More Posts by stretch1100
Old Feb 08, 2011, 02:39 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Shoot. I'm sorry about that stretch. If it is wrong I will purchase the pinions from you and reimburse the postage as well. I forgot that I just used the stock 4F200 pinion bored out. LMK.
Darryl
dkfuji is offline Find More Posts by dkfuji
Old Feb 08, 2011, 05:58 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Originally Posted by Bravo47 View Post
Heres a glowing review of the V450 from another pilot-
Link- http://www.rcgroups.com/forums/showp...5&postcount=56
Looks like this decision is going to make you sweat Rafa
Mine arrived today from WOW Hobbies. Looks good. Will test tomorrow.
http://i117.photobucket.com/albums/o...yT99/v450a.jpg
http://i117.photobucket.com/albums/o...yT99/V450b.jpg
Wish I could say the same about the fuselage from eTamiya,
but since I am going to my LHS to change the V450 battery terminals I might check out the fuselages they have there. Contemplating removing the scale body guns, keeping the colors and using medical emergency decals on it or keeping the guns and doing a camo paint job on it, using Army decals.
urrl is offline Find More Posts by urrl
Old Feb 09, 2011, 12:26 AM
USA, IL, Elgin
Joined Jan 2006
Darryl
Hello,
6 days ago we posted noted in your order and emailed you notification that the pinions have been discontinued and are no longer available. There might be other pinions available but we havent heard from you, so we were waiting
Thank You for contacting us!
Sales Dept
DiscountRCStore.com
Thank You,
Discount RC Store
www.DiscountRCStore.com
Well crap never got any notification from them. Asked for a refund. Any way to verify what mod pinion is required before I try and order from someone else? What about ordering a different size shaft in 2mm in stead of 2.3mm? Who sells those? Are 2mm .4 or .3 mod pinions easier to get?
Old Feb 09, 2011, 02:47 AM
ojo is offline
ojo
ojo
Joined Dec 2006
Hi,
it is module 0.3. The modul is calculated as follows: modul = diameter[mm]/#teeth. Enlarging a 2mm hole to fit a 2.3 mm shaft is really no problem if you have access to a drill press.
Regards, Ojo
Old Feb 09, 2011, 06:22 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Buy an CB180D brushed motor and use it's pinion, minus 1T comparing with stock F200.
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
