Wylie TX
Joined May 2009
I mounted mine here: |
Hello, yes, we can send to US but the shipping cost are very expensive! We send by DHL and it cost 30,00 Euro (packed with 1 kilogram) to US. Best regards www.Live-Hobby.de Team Kareen Gebauer Meik Gebauer Elektronischer Vertrieb e. K. Inhaber: Meik Gebauer Euteneuen 3 57548 Kirchen - Katzenbach (Euteneuen) Tel. +49 (0) 2741-931746 Fax. +49 (0) 2741-6724 Email: Info@Live-Hobby.de Home: www.Live-Hobby.de USt.-IdNr.: DE 245655633 Registergericht: Amtsgericht Montabaur Reg.Nr.: HRA 3719 |
Joined Jan 2011
Ok so I got the 4f200 and love it just one huge problem that I need help fixing. I am using a 2801 pro controller have it set up left handed flight, mode 2, my swash is 1 servo, and everything else is factory setting except I have adjusted the travadj so I can get use to the controls. The problem is my elevator and aileron are mixed up on my right stick. So to acheive forward flight I have to move the stick to the right not up like I,m use to, left makes it goes backwards, up makes it fly left and down makes it fly right. Needless to say first flight went a little rough. Lucky I was low enough that I just broke the landing skid and have to change the main gear because a few teath got messed up. Cheap fixes but hate this set up. Can anyone help me out???
The front servo should be plugged into the 'elev' slot on the rx. The one on the left side, the same side as the wiring and the 'elev' servo, is the 'pit' servo, it obviously goes into the 'pit' slot on the rx. The one on the right side of the heli is the 'aile' servo, and it goes into that slot on the rx. Check this and let us know what you find. If some setting or switch was flipped, things would be 180 degrees off, not 90 degrees, I think. This is what makes me think that the servos are crossed. Rafa |
Here's a little test: With the heli powered and bound to the tx, with the throttle off, what happens when you move the right stick up and down? You should see the elev (front) servo move thru it's travel, and the other two should stay pretty much still. If you move the right stick left and right, the elev servo should stay pretty much still and the aile and pit servos should move thru their travel. Is this how your servos are reacting? Did you say that you had had the head (links) apart yet, or not? Does the setup of your head look exactly like this: http://image.helipal.com/4f200-rotor.jpg Rafa |
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
