Wylie TX
Joined May 2009
This seems like a great deal for 15 blades. Anyone try these?
http://www.dealextreme.com/details.dx/sku.48344 |
Joined Sep 2010
They are more rigid than the original CF and fly great, but easy to break. There is a fiberglass square rod inside covered with painted plastic, painted like CF appearence. |
Hong Kong
Joined Jan 2010
I had a blade stike today while trying to take off. A couple of servos were stripped in addition to the damaged blades.
I find it very easy to trip over when trying to take off? Can you tell me what is the best way to take off? Do you open the throttle gradually or do you yank it up suddenly at one stage? I wasn't facing the wind today and this was probably a big mistake, although the wind was relatively mild. |
AC |
Wylie TX
Joined May 2009
To take off I usually let the head spin up slowly so the heli doesn't spin to much when the head starts up. I then slowly bring the head up to speed to the point the positive pitch is starting to make the heli light. If your swash isn't level you will probably notice it will start to tip. If all looks good at this point I give it a more aggressive push of the stick to get it off the ground. I like it bring it up to speed slowly so I can check things look ok before I pop it up. If you "yank it up suddenly in one stage", your motor may not be up to speed the positive pitch is kicking in. Once motor catches up you may have more pitch/speed than you want for a normal take off. Also check that the blade strike didn't damage the swash. The steel ball connectors can strip loose of the aluminum swash after a hard strike. Depending on the severity of the strike, you may have to rebalance the blades too. |
0-50% is rate mode 51-100% is HH with around 50 being neutral. 0 is the highest setting of gain for rate and 100 is the highest for HH. If you want more info search setting up of HH gyro. You need to set the gyro up in rate mode first so it doesn't drift too much then when you set HH your servo will be in the optimum position. Hope this is clear as I'm not the greatest at explaining. ![]() Try some % less than 35/40 and tail should start to hold again-assuming this is standard HH gyro we are playing with. |
Wylie TX
Joined May 2009
When is yours due to arrive? |
Sorry to hear about the blade strike. One thing that hasn't been mentioned yet is throttle and pitch curves. Seems like somewhere along the way, my curves were messed up, and it caused the heli to be hard to take off and land. You might try messing with the 'hov p' and 'hov t' to see if it's better, then adjust your curves accordingly. For example, what if you don't have enough head speed at take off, or not enough headspeed for the corresponding pitch? To answer your question, I let it spool up, similar to what ri0grand described, then I'll usually let it float off the ground, without a dramatic punch. I know people have advised against it, but I'll let it sit a few inches off the ground for a bit sometimes, then slowly climb out. It seems to handle it just fine. People have talked about an unlevel swash, so I'd like to try to take another shot at describing my method for a level swash and good tracking blades. I came up with this all on my own, so please let me know if I'm messing something up, or can add to it: 1. Take a pitch gauge, and attach a level to the top of it. I happen to use the orange and blue pitch gauge that Wow sells, and I like it because you use the knob on the gauge to finely adjust the gauge, not just hold it in place, like some other pitch gauges I've seen/used. It also goes up to +/- 15 degrees. The level I found is from Home Depot. See pic. 2. I was taught to set your throttle hold pitch curve to be the same as your idle-up pitch curve, (at least at the hover point) which might be the same as your normal pitch curve (at least the upper half, or course). I've also used the method taught to me by dkfuji, and Finless Bob, which is to set up your pitch curves so that you've got zero degrees pitch at mid-stick. 3. Flip the little switch on the rx to the 'adj' position, bind the heli. Flip it to throttle hold. Given everything described in step 2, you should have the same pitch curves as you are using, with no throttle. 4. Carefully set the throttle to mid stick, which should, in theory, be zero degrees. 5. Pick one blade to start with, and set your pitch gauge up to it. 6. Line up the swash so that the three posts on the rotating part of the swash line up with the three stationary posts. Note the position of the blade with the pitch gauge on it, and figure out which servo your blade is lining up to (E, A, or P). 7. Note the pitch that the blade is sitting at while lined up to that servo, making sure that the blade is lined up as well as possible with the blade grip (to simulate flying position). 8. Rotate the rotor 120 degrees CW, and your blade, or at least it's post on the swash, should be lined up with the next servo. Note the blade pitch again. 9. Rotate the rotor another 120 degrees, now you should be lined up with the last servo. Note the pitch again. In a perfect world, your readings would be zero degrees at each of the 3 positions, and your servo arms would all be right at 90 degrees. Even if your readings are something other than zero, they should all be consistent. If they are, your swash is level. If they are not, adjust the servo-to-swash links until all 3 pitch measurements are the same. It stands to reason that if the pitch measurement taken on the same blade, at three different positions in the rotor rotation, is all the same, then the pitch must be the same throughout the entire rotation--meaning that the swash is level. 10. Once your three readings are consistent, then adjust the swash-to-bladegrip link so that you have zero pitch at mid-stick (or whatever pitch you want at whatever throttle position). 11. Once that blade is turning true, move your pitch gauge to another blade, and adjust the swash-to-bladegrip link of that blade to match whatever pitch reference you just used on the last blade. 12. Once the second blade is turning true, repeat the process to the third blade. 13. Once you are done and the heli is disconnected, be sure to flip that little switch on the rx back to the 'wk' position before flight, as I hear it will certainly flip over on take off if left in the 'adj' position. If all blades are balanced and everything else is in zen, this should get it done. This would also be a good time to check your total (min/max) pitch. I just did all of this to my heli last night, in addition to replacement all 6 links and a new belt (after almost 45 flights). The old belt was still running fine, but I could certainly observe the wear with a new belt sitting right next to it. She flew four good packs this morning--knock on wood. I'm not sure if it's aging batteries or maybe an aging motor, or maybe the heavy blades, but I can tell that it's not quite as punchy as it used to be, and I keep bringing my throttle curves up slowly. How long does one expect a motor to last, btw? Happy Friday, Rafa |
Wylie TX
Joined May 2009
Hi Rio
That gyro is a strange one. Been waiting for mine for the past few mornings but we have delayed Xmas post in the UK at the moment so it might not arrive until after Xmas! If mine is like yours I would start by getting the servo to centre the pitch slider on the tail shaft (prob 65% gain-as a starting point based on what you've found) then test hover and adjust the tail linkage to get close to no yaw/drift either way. If the tail seems ok pitch pump to check it still holds, then adjust the gain up until the tail starts to hunt-back of a few % and fly. Then fine tune as you see fit. Once I get mine and its set up I'll let you know what I've learnt. |
Wylie TX
Joined May 2009
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
