Old Dec 05, 2010, 10:52 PM
earthling1984 is offline
Find More Posts by earthling1984
Joined Sep 2009
No response yet from WowHobbies.
earthling1984 is offline Find More Posts by earthling1984
Old Dec 05, 2010, 11:58 PM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
I wouldn't expect one over the weekend. Seems like Jonathan usually answers email on weekday afternoons.
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Dec 06, 2010, 01:44 AM
Live to learn. . .
Austin, TX
Joined Dec 2009
Originally Posted by Alwayscrash View Post
Get this and you'll get 8' flight or more...
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Hi AC,
So, I got a pair of these ESCs. I just installed it on my main bird, but haven't flown it yet. I have confirmed that it spins in the proper direction and all that. I'm wondering if you have gotten into the programming functions of the ESC yet?
I tried to do the 'throttle range setting' and get into the programming functions, and I can't seem to do either. I'm not really sure that I need to, except that the manual recommends changing the start mode to 'soft' or 'super-soft' from 'normal' for helicopters. I'm not sure what they mean by the 56712 beep, unless they are relating the numbers to the notes on a musical scale. Any advice?
Rafa
Old Dec 06, 2010, 03:32 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by Rafa's CB100 View Post
Hi AC,
Rafa
I picked up the same ESC's Rafa on advice from AC, but im yet to fit it. There is a little work around for the 2801TX to get into the ESC programming mode. There should have been a programming sheet that came with your ESC that defines any programmable parameters.
Have a read of this link to find out how to get into the ESC programming mode when using a 2801tx- http://www.helifreak.com/showpost.ph...66&postcount=1
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Dec 06, 2010, 06:43 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Hi AC,
Rafa
Hey Rafa, I've use another old 72Mhz TX to program it then after swap it back to heli.But i did use it as stock when received and heli is flying fine too, no need to program(brake is disabled by default).Just raise on max 2801 throtle and power it then lower stick after the first beep.
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Dec 06, 2010, 08:57 AM
martin_ is offline
Find More Posts by martin_
Joined Sep 2010
Hi AC,
Rafa
I'v got that ESC too, in fact a 35A one for me, and the programming mode works perfect, there is no menu option but 16 option (1 to 16beep) to choose.
martin_ is offline Find More Posts by martin_
Old Dec 06, 2010, 09:04 AM
Live to learn. . .
Austin, TX
Joined Dec 2009
Mick
Thanks guys! The helifreak link did the trick--almost. I wound up powering the rx using my second heli, but when I connected the new esc without a battery, it would only make a very light click at a one second interval. I then decided to go ahead and power the new esc with another battery, and then it did all it's little tricks. I'm guessing that the current being fed thru the rx was not enough to power that huge capacitor. Anyway, I was able to set the throttle limits, and also enter the programming modes to change the start setting to 'super-soft'. (I never did try the normal mode, I'll have to go back and try it that way too.)
The heli sounds and feels very different. The curve must also be a bit different (or an effect of the delay), as head speed actually goes up a bit now when I pump the throttle. Also, at the end of 4 minutes, my voltages were 3.85V/cell, up from 3.80V (just hoverin' about). (AC, you're a genius!) It was near freezing this morning, but battery and motor were both cool to the touch. I guess I'll start upping my timer a bit now.. .. ...
Thanks again,
Rafa
Old Dec 06, 2010, 09:27 AM
Joined Sep 2009
Thanks again,
Rafa
You know what. i try to use the stock walker Esc on my Blade 400 and it even did not regconize Rx when binding! seems it's programmed for only Walker RX,holy crap!
You'll love the yellow one, just fly as many lipos as you wants, never worry about heat again!
happy holidays flight!
AC
Old Dec 06, 2010, 04:26 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Here is the vid Manny did of a completely stock 4F200 right out of the box. It will do some 3D for sure. Wish I was able to wring out a heli like he does but oh well. I'm still having fun.
Walkera 4F200 3d flight with WowHobbies.com adjustments (3 min 7 sec)
dkfuji is offline Find More Posts by dkfuji
Old Dec 06, 2010, 09:40 PM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
You know Daryl, Manny and you always seem to get the best and most reliable Walkera products that flies straight out of the box with few problems afterwards. I completely agree with you that this heli is an excellent flyer but I have only been able to have one flight with it before it became unflyable.
At least two persons have had duds so far: earthling1984 and me. What we really need is long term reports from more modellers.
zadaw is online now Find More Posts by zadaw
Old Dec 06, 2010, 10:00 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Unfortunately most people dont come to a forum and say it worked fine... so there is typically a far higher incidence of fault reports on the Internet (as a proportion of reports) than the incidence of actual faults.
Its entirely possible that Manny got a good one, none of the WKs I've bought have had problems out of the box (aside from minor setup things that I'm sure he checked for and corrected).
desertstalker is offline Find More Posts by desertstalker
Old Dec 06, 2010, 10:12 PM
zadaw is online now
Hong Kong
Joined Jan 2010
You know, I have had two Walkera helis so far that has given me really bad problems: 4g6 and 4F200. Both did fly out of box but problems came within a few flights. I also have CB100, CB180D, 4#6 and V200D01 which are relatively problem free. However, there was a serious incident when the receiver of the CB180D burnt out right after I attached the battery and I burnt myself.
So I wonder whether I am getting really bad luck. My point is knowing that it is for a review, would Wow carry out extra checks before it is sent out to Daryl and Manny? I think any vendor would in this situation. I have been an Internet vendor before for other products and I certainly did that. I don't blame Daryl, Manny, or Wow as afterall, they do not work for Walkera. Their reviews are definitely highly helpful and appreciated. Of course, it is possible that Wow carries out the same checks on the other helis they send out.
Old Dec 07, 2010, 09:03 AM
Joined Sep 2009
Hey all. So I had the problem with my 2801 TX being defective and crashing my brand new 4F200 and my 4G6.
I was being overly careful to *not* crash my 4F200. I had only 3 flights on it, and was taking it slow, only doing normal/easy forward flight(I am capable of inverted flight). Then the heli lost signal/control and crashed. Then with same transmitter this happened to my 4G6. I now stopped using transmitter.
I contacted wowhobbies and asked if I could return the whole defective order for a full refund. I was told I could send back the TX to be 'inspected' but that is it. Also, their email about the send back/RMA of the transmitter... They did *not* include an address to ship to, or an RMA number... Then they sent me 2 more emails... First one with an RMA number, no address... then a 3rd email, saying 'sorry wrong RMA number, here is the correct one'... but again, no address or instructions for shipping...
I am very unhappy with WOWhobbies right now. If you sell products that don't work, they should be returnable. I mean, if I went to a store, and purchased a CD that wouldn't play in my CD player, would they let me return the CD... YES...
If I purchased a computer and the mouse wouldn't work because there was some problem with the plug in the back of the computer, could I return the PC... YES...
If I purchased a defective transmitter and helicopter, that causes itself to crash... can I return it... NO?!?
I used to praise wowhobbies. I have over over 3,000 subscribers and counting on youtube. I have over 500 videos, most of which on RC products and reviews... No longer will I point people to wowhobbies or praise this company...
I basically spend $350+ on this helicopter/TX combo, and now it is 100% worthless... to get it working again, I would have to spend about $100 on repairs and a new transmitter...
Wowhobbies, you really let me down... and you lost a very good customer... I have spend hundreds at wowhobbies in the past month, and have been happy with their shipping times. I'm not happy anymore...
Old Dec 07, 2010, 09:14 AM
chiefs_nut_58 is offline
Find More Posts by chiefs_nut_58
chiefs_nut_58's Avatar
USA, IL, Evansville
Joined Oct 2010
Originally Posted by Dan203 View Post
If you find a CP like that let me know. I currently have a 4G6 and I just can't seem to get the hang of it. Every time I think I'm getting better I do something stupid, it gets away from me and costs $20 to fix.
Dan
get the 2610v version 2 rx wow sells em but i dunno who else does.... it the 3 axis gyro helps alot mann try it
chiefs_nut_58 is offline Find More Posts by chiefs_nut_58
Old Dec 07, 2010, 10:57 AM
dkfuji is offline
The OC, California
Joined Feb 2007
Sorry it hasn't worked out as well for the 2 of you. I am a bit surprised though since I have had at least 35 full flights out of my 4F200 (including a few hard crashes due to dumb thumbs) and she still is solid as the first day. I also have a 4G6 with the 2610V Rx that is my daily flyer. It has to have over 100 flights so far and she still is the best little CP heli I have. I don't work for Wow nor Walkera so all the helis and parts are the same as the ones that are sold online. Wish I could help the guys having problems cause there is nothing worse than spending your hard earned money on something that just doesn't work. The thing is, I use the 2801Pro Tx and Rx's in all kinds of applications (i.e., T450Pro G3 FBL, Gaui X5 FBL Skookum720, T250, Gaui 255, etc.) without incident. Maybe I am just lucky with this stuff. Don't know. I know most of you are not newbies, but if I can help in anyway, LMK by PM.
Darryl
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
