Wylie TX
Joined May 2009
Changed the belt yesterday. I started noticing a lot of fiber dust on the tail. The new belt was quite a bit thicker than the one I replaced. I don't know if they changed the dimensions, or just tolerances. Maybe it was just worn. There were lots of loose fiber strands.
I can get over 6 minutes on a pack. I have an alarm device that sounds when the any cell drops to 3.3v. The performance noticeably diminishes before that though. It has an LED display and plugs into the balance plug. I just sit it on top of the battery and you can read the voltage through the canopy. I ordered another voltage alarm that alerts before 3.3v I thing will be better. I use the stock batteries and NRG 1300mah packs. The NRG came with 18g wire which didn't seem to deliver much punch (supposed to be 35C). I changes the wires to 14g and it is better. I also have a Hyperion 1800mah pack I haven't tried yet. I need a balance plug adapter for it which I should have later this week. I bought an X-Charger B6 which works great and can speed up charging significantly over the stock supplied charger. Ideally I am trying to stop at 7.4 volts under load which seems to be about 6 minutes with the stock 1500 mah battery. Quote:
AC |
I've gone for 3S , extremely powerful and quite nervous!
http://www.rcgroups.com/forums/showt...3#post16360072 |
Australia
Joined Jun 2010
A friend of mine with a 4F200 and myself have both had troubles with the tail box screws stripping out. Could somebody tell me whether you guys have found any tail box swap out from other heli?
eg: does the TREX250, HK250, GuruZ, etc tail box, swap out? even if it has to go back to two blade tail rotor? What are the alternatives? Mick |
And yes, you can use 2blades from HK250 kit but will lost 3blades look from stock! AC |
Wylie TX
Joined May 2009
I'm interested in your experience both with the 3S and your HK250/Trex250 parts swap. First, do you use the belt from a Trex250 if you swap the boom? Standard 4F200 belts don't last very long-so I've been looking for another option. How does putting a longer boom on effect the gyro (mine is quite waggy/gainy already as standard). I have no experience of 250 parts and keep seeing the Trex tail booms described as long boom, are there two options with the Trex and therefore different belt lengths as well? Could you post a pic of 4F200 boom next to a Trex boom to compare the lengths (I got a Trex belt of Ebay to try in the 4F200 and its way longer so I'm trying to see what sizes are involved). If you have a 4F200 already fitted with the Trex boom a pic of that would be great too. Are any other Trex parts compatible with this heli? Main shaft or head? On to the motor and 3S. How long do you set your timer for on the 3S 800mAh your using? I'm either going to convert my 2S 1300mAh to 3S or buy some new 3S batts what would you say is a good size balance for this heli? [My reasoning for converting my 1300's is this would balance my heli nose to tail weight wise. But I don't want to make it too heavy(as a complete heli)-nobody seems to be using anything bigger than 1000 mAh for 3S in 250's.] Last question-honest... I have this motor http://www.hobbyking.com/hobbyking/s...idproduct=8143 on order for my 3S conversion with 13,14 or 15t pinion what would you try first? The pinions will fit the HK/Trex250 main gear so I'm hoping they will be ok meshing with the 4F200! I would of tried your motor but missed your post and already got this ordered. Sorry for all the questions but it seems you've already done exactly what I have been thinking about. I know I've asked a lot so just answer when you have the time. It would be great if I could pick your brains in future. Thanks Andy |
Hey Andy,
I've just post some pics about tail modding for 4F200.Trex250 boom is longer than F200 so if you wants to have more tail authority just swap in Trex boom onto stock F200 near tail servo( just do some good measurement and cut off stock F200 leaving enough space to insert Trex boom on it and use CA.This way, you still use stock tail fin.servo holder.....Use kevlar belt for Tr250 will last longer than stock, make sure all screws on tail box aren't too long which can reach belt and gave premature wear. -Stock 4F200 tail boom measures: 22.5cm -HK250: 25 cm Beside tail rotor assembly, only drive belt pulley(near main gear) is compatible with F200. -For 3S, i put 5' on TX timer but flight time is more than that(about 8' sport flight) using 30A Esc and new motor. Making heli nose heavy and using heavier blades will make a lot of difference! that's a good idea . I'm using these upgrades and so far my bird is very docile and flight time is on average 6~8', Esc & motor is very cool in touch, even after 3 packs ! -Esc: http://cgi.ebay.com/ws/eBayISAPI.dll...m=110455544593 -motor: http://cgi.ebay.com/4800KV-Outrunner...ts_Accessories (don't worry,this motor can handle 3S and runs cool). HK motor seems don't have enough rpm for this heli , DK have mentioned on his earlier post that stock motor has 6000kv!Don't forget to use smaller pinion with 3S,i use CB180D stock motor pinion on new motor(1 tooth less than stock).Stock F200 main gear pitch is way difficult to find for matched pinion so i use CB180 one's which match perfectly.I'm still looking for a pinion with less teeth for lowering HS a bit(actually, it's 6200 which makes scarying noise when start...sounds like a vacum dirt cleaner!). Hope this help AC |
Joined Sep 2010
After a long inspection and some test I found the problem, the servo input is well reversed in the TX and all work very fine exept that the axis gyro in the receiver are not reversed and still make their correction in the wrong direction. Is there a way to reverse the axis gyro movement, or I will have to change the motor polarity in both servo? |
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
