Old Nov 05, 2010, 11:10 AM
martin_ is offline
Find More Posts by martin_
Joined Sep 2010
At 300' is very small, but in a sunny day with a blue sky it's ok for me.
As for the TX it's Ver: 2.3, I guess this is the 100mW, I see ''SN:8'' inside the batt cover.
But the manual is not clear with the: ''10mW or 100mW''.
I will tell you later what is the exact mW, a friend of me will come here this week-end and we will take the output mW with is equipment, at the same time I will install an SMA adapter to be able to screw any WIFI antenna available on my TX, they are very cheap, a longer one should give a lot of extra range.
martin_ is offline Find More Posts by martin_
Old Nov 05, 2010, 01:00 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Interesting, keep us posted please.
There is a built-in range check function in the transmitter under the display menu that reduces the output power so you don't have to walk so far. If your friend has his equipment to make signal strength readings also have him check the output in range check mode if possible.
Thanks, Don
dbennettya is offline Find More Posts by dbennettya
Old Nov 05, 2010, 11:04 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Actually it wont, The antennas you see claiming +x dbi are not proper omni-directional ones the give higher signal strength in some areas and lower in others (Not a good thing for helis).
The lenght of the antenna is determined by the wavelength of the signal (usually a half or quarter wavelength antenna is used) going to a longer antenna will make very little difference unless the current one is the wrong length to start with.
desertstalker is offline Find More Posts by desertstalker
Old Nov 09, 2010, 11:28 AM
DaRk_SitH is offline
Find More Posts by DaRk_SitH
Joined Nov 2010
I Beg pardon for my English , I have to use the translator.
what behaves the helicopter in realities rather then on video from shop?
Cost(stand)s to buy him(it) with transmitter 2801pro or it is enough 2603?
And will approach he beginner?
I only flew on 3D helicopter in Simulator
I well fly on Blade Msr Advise please
DaRk_SitH is offline Find More Posts by DaRk_SitH
Old Nov 11, 2010, 12:01 AM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Welcome,
I think that most of the videos from shops are pretty accurate about this heli. (Have you seen the Wowhobbies 3d video on Youtube? That's crazy stuff!)
If you want to see beginner videos of this heli, you could go to youtube and search 'rafa 4f200'. You'll come up with a few of the videos I've filmed of me learning to fly collective pitch with this heli, having flown only a CB100 in the past (sort of similar to the msr). I haven't posted a video lately, mostly because my tripod is my only consistent cameraman, and I've gotten to where I can fly in an area larger than the camera's frame can film.
I would say that if cost allows, and if you are planning on flying any other Walkera stuff, go for the 2801pro.
As for advice for another beginner, I would say to go join helifreak so that you can watch the 'Finless Bob' videos stored at this link. They will help you begin to learn what you need to know about collective pitch helicopters.
http://www.helifreak.com/showthread.php?t=41692
Simulators are great, but sometimes it's just more fun to have the helicopter there in front of you instead of a computer screen.
Good luck, let us know,
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Nov 11, 2010, 12:24 AM
Joined Feb 2010
Definitely get the 2801, the 2601 is really hard to program and doesnt give good control over throttle and pitch curves. The 2801 makes it much easier to set up a CP heli especially for a beginner.
Old Nov 11, 2010, 06:52 AM
Joined Nov 2010
Thank you
Old Nov 12, 2010, 04:46 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Heres a short video of me doing some sloppy circuit flight indoors this afternoon at our friday arvo flight meet. Flying indoors with the 4F200 made me quite nervous, due to walls, nets etc. Oh well no crashes so im happy
Walkera 4F200 indoors (3 min 18 sec)
Bravo47 is offline Find More Posts by Bravo47
Old Nov 12, 2010, 07:41 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Nice circle flight ,fast pass through.
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Nov 12, 2010, 03:47 PM
Bravo47 is offline
Australia
Joined Jun 2010
Thx AC. I need to tune some headspeed back into my 4F200 now though as im growing a little more confident. At the moment its choked back to 80% at max throttle which keeps is calm but only just has enough pull out to keep me out of trouble. Its still a work in progress.
Mick
Old Nov 12, 2010, 06:46 PM
Joined Sep 2009
Mick
Have you try to use smaller pinion? diminish only "one" tooth did make sense.I use CB180 stock motor pinion to replace F200's one & heli is way easier to handle in high speed,also using another 30A Esc did resolve completely heat generated from motor/Esc. Seems Walker Esc is lacking of Amps for the motor(they say 20A but i don't think so...).I can fly 3 packs of lipo without heating the motor and this Esc has a super soft start on throtle input!
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Old Nov 12, 2010, 08:12 PM
Bravo47 is offline
Australia
Joined Jun 2010
Thx AC ive been looking for a budget priced ESC with soft start. I just purchased two. One for my 4F and one for my HBK2
Mick
Old Nov 14, 2010, 03:19 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I wonder how this heli handles wind in comparison to a 2 bladed heli like the Trex 250?
Also, I wonder what is likely to break in a crash? If just one blade is damaged, would you have to replace the whole set?
Martin, I use my 2801pro on a Trex 450 without any problems. I am it had flown outside 300 ft before. However, it could be that the 2801pro receiver used is better than the unit in the 4F200. I totally agree though that it is not such a good idea to fly such a small heli to outside 300 ft. I am definitely not flying that far with my similarly sized V200D01 at the moment.
Derek
zadaw is offline Find More Posts by zadaw
Old Nov 17, 2010, 04:30 AM
Bravo47 is offline
Australia
Joined Jun 2010
Originally Posted by Alwayscrash View Post
"She's now got the yellow, plastic blades from the Align 250. Flies nice to this newb."
Hey Rafa, if you wants some more stable (even 3axisgyro disabled!), try the white blades one, they are tip-weighted and gave heli super stability, anyway, heavy blades is a must for multiblade heli.
http://cgi.ebay.com/2-Set-Plastic-Ma...96503585036006
AC
Hey AC
Ive been previously using the yellow plastics as well and am quite happy with them, but curiosity got the better of me when you posted the other weighted option. Ive got a set fitted but havnt flown them yet, but I was wondering do you know why each set is marked "A" and "B". Seems a little odd?
Mick
Old Nov 17, 2010, 07:52 AM
Joined Sep 2009
Hey AC
Mick
Well,seems they label A&B for easier balancing and checking CG instead of putting some red & blue tape.Also, i did cut off 1/2 inch to prevent blade strike on hard landing.These blade are heavier than yellow one and did tame down heli a lot, ideal for flying around backyard.
AC
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 03:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 09:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 27, 2009 12:59 AM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 02, 2009 12:15 AM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 11:16 AM
