Old Aug 18, 2010, 06:22 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Hey Rafa's, i love .....the coin. Be careful, this can be lost during flight and waste some ice cream for kids....
Alwayscrash is offline Find More Posts by Alwayscrash
Old Aug 19, 2010, 12:02 PM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Loss of R rudder control?
Hi Guys,
I've got 9 packs thru the 4F200 so far. I've started upping my pitch curves a bit (that is why my climbout was so weak. I had setup pitches in hold, but hadn't changed the pitch curves in hold to match st1 and st2--Oops.), I've also started backing the d/r and expo down a bit.
Yesterday, after I had been flying for a few minutes, she suddenly went off to the left by herself. I was able to get her down without incident, but I couldn't see a reason why it would have done that. I brought her back over to my little landing mat, flew for another minute or so without incident, then put her away for the day.
This morning, same thing. I could walk her back to the mat, try again, and within 20 or so seconds of flying, I could tell that I was losing right rudder. It would still want to yaw left with full right rudder. Thinking that maybe this was the first sign of a weak battery or something, I tried my other battery. Again, it took a few seconds for symptoms to show up, but it will lose right rudder. Luckily, I've been able to get her down without problems so far, but I obviously need to address this.
I've got no experience with servo controlled tails, so I'm wondering if anyone has advice about how to figure out if this is a mechanical or an electronic problem. I know that dkfuji and wow have talked about weak tail servos. Is this what a tail servo does when it's going bad, or might I have an rx issue? Thanks,
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Aug 19, 2010, 12:44 PM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
4f200 3D
Hay Rafa did you checkout Manuel on utube?
vronny is offline Find More Posts by vronny
Old Aug 19, 2010, 01:23 PM
Joined Sep 2009
Originally Posted by Rafa's CB100 View Post
Hi Guys,
Rafa
Hey Rafa, did the tail go left fastly or slowly dragging? If there 's too much pitch angle on main blades tail can pull left due to lack of compensation, most when you punch throtle for climbout. If servo is bad then it will jerk all time and you can hear it buzzing.
AC
Old Aug 19, 2010, 01:26 PM
Live to learn. . .
Austin, TX
Joined Dec 2009
Holy cra*!!!
I was going to post it here, but since Manuel is on rcg, I pm'ed him to ask him to post it to us.
Rafa
Old Aug 19, 2010, 01:44 PM
Live to learn. . .
Austin, TX
Joined Dec 2009
AC
Well, it's kinda gentle at first, almost not noticeable. Then, I feel rudder acting a little weird, so I try rudder in both directions and notice that I'm gradually losing R rudder.
I'm just hovering around a few feet off the ground, so not any throttle punching.
I've tried to work the rudder servo after it's made it back on the ground and I make it over to the heli, but that is usually some seconds later and the rudder servo seems to work OK. I haven't heard any buzzing from it, but I'm also hesitant to put any resistance against it, since they say they fail so often. Can a servo fail when it gets hot, then start working again when it cools a bit? Intermittant failure?
I figure that my options are to try to fly it again till it happens, then quickly run over and see if the servo still works, or just replace the tail servo and see how it goes.
Rafa
Old Aug 19, 2010, 02:26 PM
Joined Sep 2009
Rafa, did you move RX antenna far away from servo? this can cause interference too!
AC
Old Aug 19, 2010, 02:33 PM
Live to learn. . .
Austin, TX
Joined Dec 2009
AC
Forgot to mention that I did make sure that the antenna was going away from servo. Thanks,
Rafa
Old Aug 19, 2010, 04:37 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Would this be easier to fly than the V120D02?
NaterPin is offline Find More Posts by NaterPin
Old Aug 19, 2010, 05:12 PM
buildem336 is offline
Find More Posts by buildem336
vista, Ca
Joined Nov 2006
I got to do a video with Wow's Wakera 4F200. It really needs a better lipo the stock one has a hard time with 3d. I could barely do a couple of tic tocs then the Hs would start to slow down because the stock lipo can't keep up. Other than that the heli is pretty good.
Check it out.
Walkera 4F200 3d flight with WowHobbies.com adjustments (3 min 7 sec)
Manuel
buildem336 is offline Find More Posts by buildem336
Old Aug 19, 2010, 05:58 PM
Joined Sep 2009
Very nice video ! Are you using stock lipo for this demo?
AC
Old Aug 19, 2010, 11:39 PM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
Check it out.
Manuel
Manuel Brother! Tell us that aren't worthy how we can learn to fly even 1/4 as good as you? What system worked for you? How much did you spend on sim vs. actual 3D flight practice? You should teach classes I'm sure people would pay! You could hold it online and charge us!
stretch1100 is offline Find More Posts by stretch1100
Old Aug 20, 2010, 03:32 AM
mlody_666 is offline
Find More Posts by mlody_666
Joined Aug 2010
Hi Guys,
I have problem with my Walkera 4F200, after a little crash I broke Main Gear. I ordered the new item form chinesejade and exchanged this item, after that when I try to start a heli vibrate very strongly. What may by the reason? I checked almost everything: loose screws, receiver, main blades, please help
mlody_666 is offline Find More Posts by mlody_666
Old Aug 20, 2010, 03:33 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Manuel
Excellant flying Manual.
Its hard to believe Walkera has produced a $200 heli that can do all that? or is that 4F200 heavily modified?
Thx for posting
Bravo47 is offline Find More Posts by Bravo47
Old Aug 20, 2010, 09:33 AM
gmbnj is offline
Find More Posts by gmbnj
Joined Dec 2007
Just a feeler......
I bought a 4F200 2801pro combo. My first heli came DOA and this is the replacement.
I flew it 4 times so far and I am not in love. I have (3)trex 450's, 1 trex 450 pro, 4G6s and a CB100. I just don;t think this heli is for me.
I may sell the heli as a BNF or trade for another heli.
Anyone want to make an offer?
gmbnj is offline Find More Posts by gmbnj
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
