Why don't ya tell me sooner?haha! it's way easier than my method.Anyway, i did replace at same time main gear & belt. Thanks man, |
The OC, California
Joined Feb 2007
All this talk of pitch settings and throttle curves is this custom setup or fixing it to fly decent out of the box? This heli is on my list to purchase but I'm wondering if i'll have to do all this setup work before I fly? I had a Belt 250 before and loved it but I was ahead of myself. Went back to practice more on various sized FP birds and got good with them. Now thinking about thinning out the herd and getting this one. Not ready to do any 3D yet but would like to feel the performance and speed of belt driven CP. I love the torque tube tail setups but it doesn't feel as good as a belt. Also looking at the 2801 tx I'm not just sure I'm ready to have to read through the manual and forums to figure out how to work it and what every setting/button does. Wish this part was more user friendly(this is for you Walkera if you're listening). I'm thinking that's how the Blade SR made it's way into the market with the theme to sellers "Beginner CP and ready to grow when you are" something along those lines. Thoughts? Suggestions? Do I stay here and read this thread everyday until I decide to buy so I know all the in's and out's? I just wanna fly!
Hi stretch1100,
This heli flew fine out of the box, I think. In fact, I was able to fly my first few flights without too much incident (other than my couch hit and learning how a weak battery affect flight), or at least less than some others in this hanger had mentioned with their intros to CP. I'm just totally new to CP, and had asked dkfuji for advice before I jumped in. He referred me to the Finless Bob vids on helifreak, and I just wanted to apply my newfound knowledge. Really, I wanted to see if I could reproduce the -9 to 9* that he mentioned a while back. I think I might have just discovered a slight adjustment problem with the original setup, that's all. I don't really even have enough experience to know whether it was flying well or not, and that's why I was trying to check the stock setup. I'm just looking for a baseline to work from. Jump in, the water's fine. Rafa Quote:
I haven't played with the throttle hold yet. I guess that by setting throttle hold to -15%, you don't have to disconnect the motor? Rafa |
The OC, California
Joined Feb 2007
Yes, yes, yes. Always have throttle hold set-up. It will save you striping your maingear if you hit that before you have a blade strike. It will also save other parts as well. Plus it is a safety feature to always use when you are moving the heli while it is plugged in before and after the flight. You just never know... |
Joined Jan 2009
Cheers, Jonathan WowHobbies.com |
Manny told me in one of the other threads that he has a 4F200 already, but that his swash suffered this problem. That's why we haven't seen a Manny video yet.
![]() Get him some parts, get him some parts,Rafa Quote:
0* at midstick!!!
Hi Guys,
I'm happy to report that I have adjusted my swash to blade grip linkages to 30.0mm, as AC had noted yesterday (they had been around 31.2mm). The result is that I now have zero degrees pitch at midstick, and -9 to 9* of pitch travel!! Woo hoo. Now if the rest of my parts would just get here, I could try to get back up in the air . . .. Thanks Guys, Rafa ps The other thing I learned is that one full turn on those particular linkages changes it's length 0.25mm. Quote:
Hope you'll get parts soon to get in the air again. Actually i'm using these settings and heli is flying perfectly, really smooth aggressive flyer , no 3D test , only routine outdoor flight. Stick Mode: Mode 2 Swash: 1 Servo normal Reverse: Elev - Revs; Aile - Revs; Thro - Norm; Rudd - Norm; Pit - Norm Trvadj: All 100% except Rudd 120% Swaats: none Gyrhld: Gyrosens -> Auto -> 0: 79%, 1: 79% Hold:0 DR&EXP: Ele, Ail and Rudd D/R 100% ---All Exp +35% Curves: Thrcurv -> Nor: Linear(0-25-50-75-100) St1: 90% all across; St2: 100% all across Pitcurv -> Linear in all modes (0-25-50-75-100) AC |
Australia
Joined Jun 2010
After this afternoons flight at the basketball stadium which mostly consisted of hovering about I was a little concerned about the outrunner temperature. I could smell the motor after the flight and it was hot to touch. Battery and ESC were fine and barely warm.
Im running a linier throttle curve, and 40,51,65,74.5,84 pitch curve which outputs -2 to +10 or there abouts. Im guessing blade pitch is exceeding RPM requirments and putting the outrunner under too much load. What would be the best method to reduce motor heat, increase head speed, or reduce reduce pitch to RPM relationship to reduce motor load. Higher head speed with reduced pitch seems to me to be the best path to follow. Does this make sense or am I off track? My other CP heli motors dont run this hot at all. Mick |
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
