It's been around for decades, that stuff. I just don't know how it reacts with plastics and things. It's not like your soaking anything either. A drop goes a long way if it can slide into the bearing. If it just pools on top then it might be too thick to soak in. I generally oil my bigger bearings every 5 or so flights and the smaller ones like the v120 every 10 flights or so. If you do it too often you end up with some run off and ejection. When i changed my V120D05 airframe out last time the inside of the frame where the main shaft bearings sit had a little pool of oil in there. I don't think i would have needed to oil the bottom bearing under the main gear for a long time. I think some of the oil from the top bearing runs it's way though the middle there too because the part of the shaft between the bearings was all greasy too. So i was probably oiling those particular bearings a little too often. But no damage was done. Just a little messy. On the 4f200 i oil the main shaft bearings every 5-10 flights or when i get around to it. They don't eject much and only a drop or 2 is needed in each then spin your bearings to work the oil in and wipe the excess off so it does not accumulate grit and grime |
Since i just ordered a Gaui X5 and I couldn't find an actual Gaui X5 thread here. I started a new one for the microbeast super combo and other setups if anyone is interested in that conversation. For the time being i will be testing it with my 2801-pro and 2801-pro RX
![]() Gaui X5 FES Super Combo - w/ Microbeast & other |
IntegrityHndywrk,
That is some awesome inverted flying. Cruising around inverted is becoming second nature to you. You practically don't even need to think about it. At your current rate, when do you think you would be able to fly the 4F200 similar to Manuel Campus (a.k.a. buildem336) in this YouTube video? As for me, I probably get a quarter as much flight time as most on rcgroups do, it'd take me seven years. Quote:
Ahhhhhh... sweeet!
Was there a last straw tipping point that caused you to fire away at the buy button? The uBeast is nice. And of course the X5. Both high quality and respected brands engineered and supported by folks who give a care (damn). One of the reasons why hobbyists like the uBeast over the AR7200BX is because they don't want the receiver built-in. They want the choice of running a different receiver. Receiver independence! Quote:
and then i don't mind it so much. Accelerating my skills is also, IMO, my v450. I kind of have it in the back of my head now, since the v450 has lock me out so many times. I just kind of think, i might as well enjoy it and push the limits! Because if i don't crash it Walkera will do it for me! Thats the truth too. I've only thumbed the 450 once since i owned it. It's kind of heart breaking for most when they watch the video i made too. Worst part of it is i don't record all my flights and i have deleted quite a few crash videos because the angles were wrong or the expletives were too abundant to cut out Quote:
The second crash in the vid is actually my fault. All the rest are 2702V lock outs.
Integrity:
I own a string of 26xx and 2702 Walkera receivers. If I saw someone flying a 450 or larger heli on any of them, I would have one piece of advice, and one only for them, but it would be emphatic and absolute: * Remove the Walkera receiver. *Use either a Spektrum full range with satellite, OR a Futaba. I have never had a single problem with either of those setups, on airplanes or on helis, but I have yet to have a Walkera receiver that I really trusted and have not had some sort of problem with. * Do not be suckered in by the idea of integrated FBL control into the Walkera package. It is fool's gold. Run a Beastx, or other 'real' FBL system. You can save money in a million ways in this hobby, but the receiver/FBL combo is not one I'm willing to scrimp on any longer. |
It's funny because i have been saying EXACTLY THAT. But you would be surprised how much support i get for Walkera being "Okay". Often when i bring up these intermittent issues about WK Rx units it's surprising how many people "Love their Devo" or "love their 2801". It often gets thrown in my face that th DX8 had major issues with dropping heli and everything too. But the truth that EVERYONE that is supporting Walkera fails to recognize is the DSMX version of the DX8 has been out for about two years, and sure it had problems at first and dumped aircraft because of it. But two years later, the ISSUE IS FREAKING FIXED! Where as, two years later, i'm buying a 2702V, NEW, and still having lock outs that have been reported here and there from users for over a year and a half now but remain for the most part hidden and very hard to find. When i started having the lock outs, NO ONE MENTIONED TO ME THAT THE 2702V has had this issue with other users before. I struggled with it for like 6 months. Switching out all kinds of different electronics in the process. The brand new units from wow hobbies still have the random defect and is dropping heli out of the sky. It's not cool. I wish more people would not be so supportive of Walkera just because they are invested with their products. It would be more accurate to say, i wish more people would ATTACK Walkera for the actions they take, as well as the ones they don't take, should a epic safety concern like this appear. It's absurd, honestly. |
Good luck, I'm sure you've already got it figured out. Are you going to get a fuse for it? |
I have noticed the blades on the stock 4f200 are over twice the width of the 200SD5 blades. I'm thinking lift will be close to the same maybe. Also, phasing is locked down not adjustable. It is close to being set at 90 degrees but a bit off. I am hoping this will not cause a problem. My biggest problem so far is getting the servo arms set at 90 degrees. Mechanical adjustment is out of the question so I have to resort to subtrim which acts a bit crazy. I can get the arms as close as possible to 90 then when I turn it off and back on, the right servo drives all the way up and left down some. But, this is consistent every time thereafter. So, I am thinking I will find an intermediate position which will result in servo arms at 90 after rebinding. Parts are available from WalkeraHelicopterSupply.com and WOWhobby. I have found that Dave at WalkeraHelicopterSupply can order anything you need. He was out of stock on 200SD5 feathering shafts until he found out I needed five of them. It took about two weeks but he restocked and I received parts yesterday. I am relatively sure since I bought most of the parts from him I am now recognized as a customer in good standing. ![]() I grew impatient in the mean time so decided to cut the 200SD3 feathering shafts down I had ordered as a substitute. I cut them to the exact length of the 200SD5 shafts which is 7.25mm. Only problem is you are left with about three good threads after shortening the shaft and screws. The 200SD5 shafts even though shorter have way plenty of threads. I will be removing the modified feathering shafts and installing the correct ones. I don't trust three threads no matter if they are thread locked or glued.
Bell 206 and Support Vehicles
Here is an interesting scene I encountered after returning to my hotel in McComb, MS Friday afternoon.
The servo arms are a pain, and always will be. Your best bet is to try hand fulls of servo arms, or try to move the internal gearing inside the servo so that the neutral point is closer to 90. You can do this by pulling the main spline gear out of the potentiometer and rotating it by 90 degrees and trying the horn. Rotate another 90 degrees, try horn. I really can't think of one 3 axis gyro that won't act up if you use trims or subtrims. My beastX gyros warn that it will case the gyros to confuse them for YOUR inputs and it could cause a crash. Walkera just does not document anything at all. But i know many people argue this point. But i've flown the 4f200 with misaligned servo horns so many times, it really doesn't matter as long as your get it close and the travel is in line the whole path. Good luck with it either way, i know it's a pain working on these damn servos. |
Five Blade Head Alignment
Here is what I came up with. As to servo arm 90 degree adjustment, the best I could do was to set ELEV subtrim to U25 and AILE subtrim to L68. That got the arms close to 90 degrees. I gave the starboard side servo link one twist in making it slightly shorter. I think this is as close as I'm going to get it for now. I'm sure I will need to make additional adjustments. As to phasing, not much I can do about that because there is a pin going through the main shaft which locks the swash follower (normally used to adjust phasing) in place. As you can see from the pictures, phasing isn't off much.
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
