Old Aug 09, 2012, 08:15 AM
IntegrityHndywrk is offline
Find More Posts by IntegrityHndywrk
IHW Heli Division
IntegrityHndywrk's Avatar
United States, FL, Palm Coast
Joined Mar 2012
Originally Posted by tengarang View Post
Thank you for your valuable words and time invested to clarify, I will not give up and take your suggestions and try again tomorrow night after i get home from the office....until then, I can only thank you for your help, since I have not had the chance to try...its late ... but tomorrow ill go at it again.
thanks
regards
tengarang
It's my pleasure. The 2702V is actually very easy to program. It's the instructions they provide with it that is the big mystery! Good luck!
IntegrityHndywrk is offline Find More Posts by IntegrityHndywrk
Old Aug 09, 2012, 09:00 AM
Firewolf is offline
Find More Posts by Firewolf
Firewolf's Avatar
Heliyork
Joined Nov 2009
Two years back i got my 4f200 with lots of spares but this heli proved to be a total disappointment for me it was really a PITA. That rx2612 was a disaster, i tried to use it on one of my 450 clone which met the same fate as my 4f200
I am using a 2702v in another 450 clone with jet ranger fuselage and i am happy with it.
I am surprised that this 4f200 thread is still alive and lots of valuable information has been added since i last checked it (around 18 months back...lol). Anyway i am thinking of converting my 4f200 to a two blade heli and have ordered few v200d03 spares. I don't want to spend money on walkera 3 axis rx but i do have Tarot zyx 3 axis gyro and might want to try it first. Any thoughts from you fellas?
Firewolf is offline Find More Posts by Firewolf
Old Aug 09, 2012, 10:57 AM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
I concur...the instructions IMHO are not very clear. For this evening, in conjunction with the proper procedure you have suggested, I will setup my radio as follows:
Swash Plate = Normal (since I am fixed pitch) --> please correct if I am mistaken
gyrosense = ill set to AUX 2 with position 0 to 80%...pos1 I will not use....should I leave it inhibited?
rudder throw = 120% plus minus...got this from youtube video...but this may be specific to the guys setup.
Pitch Curve = I flattened out all to zero since I have no pitch to play with...if I leave it default, with given throttle range the cyclic pitch will move which alters the stability...
Any other critical settings I should know about not mentioned here?
tengarang
tengarang is online now Find More Posts by tengarang
Old Aug 09, 2012, 06:03 PM
IHW Heli Division
Joined Mar 2012
I've heard good things about the ZYX 3 axis gyro. But i don't know anything about it really. As far as info on the 4f200 I also have a build log that i update and change from time to time. It's mostly just a jumble of random repair and upgrade information. There are also some links to topics outside my build log. I will be updating it again soon with more info i'm sure. The next addition just might be a while but it will be worth the wait. It will be a build log for building a 4f200/v200 frame and helicopter from parts.
4f200 - Upgrades, Repairs, Modifications
tengarang
I am unsure if / how the 2702V will react in normal (1 servo) mode. If the swash is moving correctly you should be okay though. Just make sure the gyro is operating correctly too and not too sensitive for your fixed pitch swash and rotor head.
For your gyrosense i would use 80% on one position and 70% on another position. Try them both and see which one works out best. You don't always have to have the gyro so high. Especially for FP and non 3d type flight. As long as it holds the tail you will be okay. 70% is usually a good starting point.
It sounds like you actually are a little more familiar with the FP setup then i am. I have never actually flown a legit FP helicopter. The only heli i've ever flown that was FP or had a flybar was the WLtoys v911. Cool little heli though. So i don't know how much more i can help. But if you have more questions i will try to answer
Old Aug 09, 2012, 07:20 PM
clearprop88 is online now
Find More Posts by clearprop88
Joined Apr 2011
There's a very active thread on the zyx, and it's updated version the zyx-s. You should be able to get most of your questions answered there.
http://www.rcgroups.com/forums/showt...&highlight=zyx
clearprop88 is online now Find More Posts by clearprop88
Old Aug 09, 2012, 10:59 PM
tengarang's Avatar
Joined Aug 2010
Hello IntegrityHndywrk...you are a wonderful human being....im finally airborne because of you
Your instructions mine as well replace the manual "tail section" worked like a charm. Because of your help, now I am hovering hands free.....your step by step instructions were critical to my success....if it weren't for your intervention I would still be beating my head on the wall down stairs....it took no time, like you said...its real easy provided executed properly.
now for others who are curious about my fixed pitch setup which is not really applicable here...since IntegrityHndywrk spent his time and sincere effort to get me airborne, it is only right in my mind to share my settings,....since there were some unknowns prior to the experiment.
Swash: Normal (so this turned out to not have an effect on the overall setup)
Gyrosense AUX2: pos 0 = 80%(might give it 85% per my feeling feeds back) pos 1 = 70%
elev dual rates & expo: pos 0 = 100% 35% expo, pos 1 = 80% 55%expo
ailerons dual rates & expo: same as ele
travel: rudder ele aileron set to all +/-120%
I may or may not play with the POT on the 2702V to experiment to learn alittle more about the device and its application to the Funcopter. Thinking of ordering another 2702V unit for my other funcotper so I can free up the receiver for another project.
Best Regards
tengarang
Old Aug 09, 2012, 11:12 PM
IHW Heli Division
Joined Mar 2012
Best Regards
tengarang
So glad i could help. I'm happy to hear your enjoying your new setup!
Old Aug 09, 2012, 11:15 PM
tengarang's Avatar
Joined Aug 2010
To be honest I put off this project for almost 10 months because I gave up hope...turned my attention to others in my fleet, now that im done i had to face reality one more time....so its really a build up of frustration
for the life of me I have been searching for manuals and comments ...google searched to page 20.... nothing nil.
thank you thank you...there is always a greater force out there
Old Aug 09, 2012, 11:23 PM
IHW Heli Division
Joined Mar 2012
In that case, maybe you should take a look at this PDF. It might help you learn a little bit more about the 2702V. It is a supplemental manual for the v450d01 helicopter, which is outfitted with the 2702V. This guide was made because of the poor instructions originally released with the V450d01 and the 2702V that it comes with. It should translate almost directly to your helicopter. Though the swash is much easier to do for your FP it seems. This manual will show you how to do a CCPM setup with it and check the gyros,etc.
Old Aug 10, 2012, 01:11 AM
Firewolf is offline
Firewolf's Avatar
Heliyork
Joined Nov 2009
IntegrityHndywrk, some good info there. I never thought i would touch my 4f200 again ever as it was my most expensive micro heli with lots of spares and i had few plans to make it scale that all went down the drain due to its terrible issues
Originally Posted by clearprop88
Thanks There's a very active thread on the zyx, and it's updated version the zyx-s. You should be able to get most of your questions answered there.
Thanks clearprop88 for the link. I 'll go through it out once i get my spares.
Old Aug 10, 2012, 01:20 AM
tengarang's Avatar
Joined Aug 2010
Thanks IntegrityHndywrk, ill go over it for sure over coffee tomorrow morning before departing to the office.
thanks friend
Regards
tengarang
Old Aug 10, 2012, 04:36 AM
MX48 is offline
Find More Posts by MX48
United States, GA
Joined Dec 2011
The EMAX ES08MD servos work fine with the stock electronics and do not require any reversing or require the receiver to be oriented 180 degrees. So this is good news.
razorblade,
Did you ever get your servos mounted and working? thinking about putting them in my V200D03.
Moto
MX48 is offline Find More Posts by MX48
Old Aug 13, 2012, 12:28 AM
razorblade is offline
Find More Posts by razorblade
razorblade's Avatar
United States, MN, Coon Rapids
Joined Feb 2012
Originally Posted by MX48 View Post
razorblade,
Moto
Sorry no I did not start. I am still flying with Futaba S3154 servos on cyclic and been tinkering around with an upgraded 2000mah 25c lipo at the moment. The job will require some aluminum pieces on the 4F200 frame to be modified in order to make them fit. The servos are about 1mm taller than stock. Hopefully just some grinding with a Dremel power tool and then adjust lower ball links.
razorblade is offline Find More Posts by razorblade
Old Aug 13, 2012, 05:33 AM
MX48 is offline
United States, GA
Joined Dec 2011
No problem. I think I am going to stay with my S3114's and put my money towards a Mini Protos.
Moto
And my brother lives in Eden Prairie, was just up there about 3 weeks ago. Went up there to cool down from Georgia, you know how that went...95+ degrees!
Old Aug 19, 2012, 08:17 PM
IHW Heli Division
Joined Mar 2012
Hey razorblade. How about an update on that tachometer you got, now that you've had it for a little bit. I'm looking at other tachometers but they seem to have a 4 blade max limitation. How is yours working out? Do you only need to put a piece of tape on one blade to get a accurate reading? Also have you determined the proper point to take a head speed reading from? Would it be the blade's CG point? or the tips? It's looking like that is an exceptional tachometer for the price. Though i'm assuming it's because it's not a hobby related product. It is actually a tool for woodworkers, lathe operators, etc. But it appears to be working accurately for heli rotors?
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
