Awesome job with your 4F200 Rafa!
Your are a natural for a CP heli. It took me many months to get to that point. Went from Coaxial to FP to CP... Tom |
Latest blog entry: My RC Web Site
I'll take a little credit, but I think it's mostly the 1s and 0s. I don't think that my 3-axis experience compares to you guys that have been doing it for a while. It's your collective experience that has driven technology to the point that it is today. I also wonder if the 'support group' of 2 years ago was as strong as the one today. Happy flyin', Rafa |
The OC, California
Joined Feb 2007
I have done more work on the set-up of this heli and here is what else I have found out. The servo arms are very short so that means they run out of travel way before they should. In order to achieve a full +/-12* pitch, the pitch curve needs to be at least 90% at the top and bottom. Unfortunately, when the collective reaches the top (or bottom) the servos bind up and cause a nasty interaction. At max pitch, if you give full Ail it causes the swash to interact and lean backwards. Also, giving forward/back cyclic at that position results in very little swash movement. Using the stock arms the best I could get was +/-9* without the interaction. Not quite enough for action packed flight nor any mild to serious 3D. I am going to try to work on a solution.
and because there is more lift from 3 blades rather than 2 you don't need as much pitch (+- 8-9* rather than +-10-12*) to create the same lift ( nor as much headspeed - but maybe a little more torque) -which reduces induced drag (the casue of engine bogging). And lastly you'll have quicker response from cyclic input because there is less distance between the blades.... on a 2 bladed head there is 180* travel around the swash before the blade gathers the cyclic input, on a three bladed head there is 120* travel, on four blades there is 90* travel etc. So multi bladed heads provide better performance with a smaller rotor diameter, slower headspeeds and with less induced drag applied on the head (smoother control because HS is more consistent through the pitch curve). |
Australia, VIC, Melbourne
Joined Feb 2010
I really like the look of this Heli, what are peoples thoughts on this as a first CP? I have a half 4#6s half v120D01 and once I'm able to fly circuits etc. I want to move to CP. |
As a CP newbie, and this as my first CP heli, I'd say that this has been a good heli for me. I was trying to decide (with some help from dkfuji) between this and a V120D02, and ended up going with this for several reasons. I like the smallness of my CB100 because I can fly indoors, but I don't see the advantage of a super-small CP heli for me, given my limited indoor and backyard space. I've heard that in CP, bigger is better, for various reasons. I also figured that the larger heli would be easier to work on. Although there are not that many of these out there yet, some of the opinions you seek might be found in the last few pages of this thread, as some more experienced pilots than me have been commenting on my first few days of CP with this heli. I'd say jump in, the water's fine. Rafa |
However, it should be noted there is some decrease in efficiency and the increased torque means it will be more resistant to direction changes. This are why you don't see multi-blade heads used for 3D. |
Latest blog entry: Lousy weather!!!
some references:
Converting to FL a small heli like a 250 or 450 there is a little squirrely. There 's really no difference except you are now flybarless. Meaning you won't realize what the flybar does until you actually remove it. Now comes the fun part. You need to set up the phasing, blades...perfectly and this is very critical on a multibladed head. Some scale guys fly with stabilization ie: Vbar, Skookum... and some don't. But the rule of thumb though is you should set the rig up to fly it without first, to get it's best performance. And, a 3-blade system is inherently balanced - a 2-bladed system can never, truly, be balanced. So, lower vibration. Also,you can use shorter blades and a slower rotor RPM but still obtain the same lift. my2cents |
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
