Joined Apr 2011
Are they drop in's? A part of the housing sticks out, does that get in the way of anything? I see that HK has them on backorder for $21. Where did you get yours? |
Hi guys, I've got 5 sets of new simulated CF 4F200 blades for sale:
http://www.rcgroups.com/forums/showt...5#post20785365 Thanks, Rafa |
Walkera 4F200 with Spektrum AR7200BX Beastx
So I took the plunge. Bought the Spektrum AR7200BX receiver and installed it onto the 4F200. I purchased it from my local HubHobby store for $219. It flies very smooth and very still. I have some tuning to do. Just using default settings at the moment. The cold weather has been relentless and too cold for my fingers.
I've only been in this hobby for a little while (since Feb 2011) and I must say - it's not cheap. I started with mostly Blade products. Started with Blade mCX2, then Blade 120SR and finally the Blade SR. I then wanted to jump into a belt CPPM and saw the 4F200. I purchased mine with the WK2603 transmitter instead. Please note at this point, the value of a fully programmable transmitter was unknown to me. I've been flying the 4F200 over the summer and crashing it as well. I've probably went through 17 main gears, 12 sets of blades, two swash plates, at least two sets of cyclic servos, re-built the tail twice and more. However, I believe I've reached a point where I've figured out all my upright orientations. This also means I rarely experience a crash now. I am now getting into fast forward flight and figure eight circuits - fast and high ones. I know this will change again when I get into the inverted stuff. I live in Minnesota where the cold weather keeps folks inside most of the time. So over the 2011 winter I purchased a Blade mCPX for $149 and a DX6i transmitter for $160. I wanted something that I can fly inside and also something that will bounce off the ground during a crash as I learn my inverted orientations. I now use the Spektrum DX6i transmitter with all my helis. The 4F200 was the last bit that didn't have a Spektrum receier. The purchase of the AR7200BX has changed that entirely. I don't foresee me buying another Walkera heli in the forth coming years. My next plunge will be a heli that I built from a kit. I'm thinking Tarot 450 Flybarless kit here. On closing, the 4F200 is a great heli. Since I have re-built certain sections of mine over at least twice, I don't have problems with loose screws. Mine is a solid and balanced runner. Pretty much all screws on the heli now are ones that I have placed there. This bird has taught me a lot (and still will) and has made me aware of how complex a full CCPM heli can be. And the price is hard to beat. Enjoy the pics. |
Awesome, RB!
What a great time to be in this hobby -- a 2.4 Ghz freq hopping radio, AND three axis gyro stab system, all in one package, less than $200, from a major mfgr, with a top notch rep for customer service. I'll bet that 4f200 is humming now -- the 2702 is such a great improvement, and this is head and shoulders over *that* mod, so with it properly tuned, you will be getting everything out of that airframe that it is capable of delivering! Nice job, and thanks for sharing!
Thanks tracknoob! I am pretty sure the air frame is capable of more than I can deliver at this point.
Remember I purchased the 4F200 with the WK-2603 transmitter which in my opinion was a semi-programmable transmitter very much like the HP6DSM transmitter that shipped with the Blade SR. I so desired to have the programmability the 2801pro offered, so it was either I purchase a 2801pro from WOW for $140 or get a 3-axis gyro/receiver combo that could be paired up to my DX6i transmitter (which is very comparable to the 2801 both in function and cost). I sure wish I would of purchased the 4F200 with the 2801pro from the get go - oh well - lesson learned - wish I knew then what I know now. The 4F200 is such a smooth runner when tuned mechanically. Honestly I enjoy flying this bird, even when the stock RX-2612V receiver was in use. Only if the weather would start to warm up just a tad... Quote:
I have to agree with you there. The cheap chinese electronics does not do it justice. It's quite robust as well, since what I've put it through. I've hit a tree, and countless crashes due to dumb thumbs. I've even managed to land it twice with one of the ball links to a servo popped out
I drilled the hole in the servo arm to big. I don't want to try that a third time so I'm replacing my servo arms.Once I have the money I'm also going to the AR7200BX, probably around this summer. I'd have to get both a transmitter and that receiver. |
First Fast Forward Flight
Finally! The weather warmed up. Most of the snow is gone. Daylight savings time has began. It was time to fly this thing.
| Thread Tools | |
| Discussion Another new Walkera! HM 4F200 | heli-parkflyer | Micro Helis | 84 | Jan 08, 2011 02:40 PM |
| Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version | nighthawk0077 | Aircraft - Electric - Helis (FS/W) | 0 | Nov 22, 2009 08:23 PM |
| Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss | EQMOD | Micro Helis | 47 | Sep 26, 2009 11:59 PM |
| Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head | EQMOD | Micro Helis | 13 | Sep 01, 2009 11:15 PM |
| Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 | stevel48 | Micro Helis | 146 | Dec 03, 2008 10:16 AM |
