Old Aug 02, 2010, 04:14 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by dkfuji View Post
Hey Rafa nice job. Took me forever and a load of parts to get my first outdoor CP hover going okay. Good for you man.
Have to agree here as well. I was three months crashing and rebuilding my first CP heli on a weekly basis, before I could achieve a loose hover like Rafa just demonstrated. Perhaps the 4F200 may be a good transition to CP heli suggestion if it holds up well over the next few months. Looks good so far anyhow.
Im hoping to see my 4F200 delivered some time this week.
Nice flying Rafa
Bravo47 is offline Find More Posts by Bravo47
Old Aug 02, 2010, 04:59 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
Iam so tempted to buy one of these,but I know as soon as I do,walkera will bring out another new and exciting heli. Then I will want the next one.
Walkera are killing me
jasonjetski is offline Find More Posts by jasonjetski
Old Aug 02, 2010, 08:04 AM
sportvelo is offline
Find More Posts by sportvelo
Australia
Joined Oct 2009
How does it compare stability wise to the 4G6S? I am searching for that yet to be developed "indoor CP".
sportvelo is offline Find More Posts by sportvelo
Old Aug 02, 2010, 09:42 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
What do you guys think? very neat inside, must be well planned before cutting fuse....will get some brush paint in white/blue/red soon.
Alwayscrash is offline Find More Posts by Alwayscrash
Old Aug 02, 2010, 10:06 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
I am wondering the same thing. Maybe walkera will come up with their own version of the Blade SR cp.
NaterPin is offline Find More Posts by NaterPin
Old Aug 02, 2010, 01:11 PM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Take III. More newbie questions.
Hi Guys,
I went for my third session this morning (no video this time), and now I'm thru this battery break-in thing that the manual talks about (With the battery fully charged, let the battery discharge to no less than 70% charge, then charge fully again. The book says that doing this 3-5 times will increase battery like and consistency. I did it 5 times.).
Anyway, I figured that if I could, I would stay in the air as long as I could, to try to gauge how long the battery lasts on this thing. The good news is that I made it 6:48 with no 'ground touches'. At 6:49, something went wrong. Maybe I goofed, maybe the battery went flat, I don't know. All the sudden, the heli stands on end, then comes down to the ground, doing a little cartwheel on the training gear. When I got to the heli, all was fine, with the exception of the tail pitch slider assemblies and tail blades. One of the blades broke, another one of the blade holders got torn from the hub, etc. There begins the $ and downtime that everyone was talking about. I knew it was coming at some point, I was just hoping it would happen when parts were more readily available. I can't complain, it was a great 6:48 (all tail-in)! I even flipped into ST-1 for a second or so in the middle of the flight, just to see what would happen. I got scared as I heard the motor spool up so I flipped the switch back to normal--that's what happened.
Oh yeah, my question. My CB100 would just slowly start to lose power as the battery discharged, and I knew to bring her down when the heli wouldn't 'punch' anymore. Should I expect a similar thing on this heli, or will it suddenly just give up the ghost?
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Aug 02, 2010, 01:12 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
[QUOTE=mrschultz02;15686699]
So, I probably shouldn't ask but does the Walkera use a standard 3mm main shaft?
I am afraid not. It is a 4mm shaft. Also, the pitch of the main gear is .25mod and so is the belt drive gear. So, that makes it difficult to change things out or use a standard one-way bearing set-up. There are rumors that Walkera is working on fuse's for this heli as well.
dkfuji is offline Find More Posts by dkfuji
Old Aug 02, 2010, 01:16 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Originally Posted by Rafa's CB100 View Post
Hi Guys,
Anyway, I figured that if I could, I would stay in the air as long as I could, to try to gauge how long the battery lasts on this thing. The good news is that I made it 6:48 with no 'ground touches'. At 6:49, something went wrong. Maybe I goofed, maybe the battery went flat, I don't know. All the sudden, the heli stands on end, then comes down to the ground, doing a little cartwheel on the training gear. When I got to the heli, all was fine, with the exception of the tail pitch slider assemblies and tail blades. One of the blades broke, another one of the blade holders got torn from the hub, etc. There begins the $ and downtime that everyone was talking about. I knew it was coming at some point, I was just hoping it would happen when parts were more readily available. I can't complain, it was a great 6:48! I even flipped into ST-1 for a second or so in the middle of the flight.
Rafa
The nature of the 3 axis gyro is it will go nuts when the voltage drops. There is no telling what the heli will do if you fly out the pack. One thing I do know is the stabilization ability goes haywire when the battery pack is flown out. This differs greatly from the CB100.
Old Aug 02, 2010, 01:34 PM
Live to learn. . .
Austin, TX
Joined Dec 2009
Thanks. Knowing this makes me feel better, actually.
There it is, we now have a baseline as to the absolute limit of time a stock battery can just hover around--6:48.
Rafa
Old Aug 02, 2010, 01:42 PM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
It so happens I have one of these fuses laying around. Did you relocate the battery or are you removing the front of the fuse every time you access the battery? How'd you cut it so clean? And what holds it firm to the guts?
Let us know how it flies with the full fuse on. I've been holding off on this heli, waiting for the larger Esky version (CT), but if the orange 222 fuse works good, I might forget about the CT.
xviper is offline Find More Posts by xviper
Old Aug 02, 2010, 02:06 PM
Joined Sep 2009
I want to keep everything as stock, changing batt will need to pull out the first haft (thinking of using some small magnet to keep it fast-snap).After trimming fuse weights about 92g, heli still lift up with plenty of power! I use a thin scissor with small tip to cut the fuse and finish with some sand paper.You onle need to find some best place on chassis to put some tiny screws for holding the tail haft-fuse ,the front one once snap in will fit tightly between landing skid and battery holder, so just need to make it "married" closely with the other half.Anyway, there is some stock screws that fit perfectly with the fuse if you wants to keep it tighter but i think that's not very important tho.
Putting a 3blades heli on scale really change a lot of look. Hope i can finish it nicely!
Acrash
Old Aug 02, 2010, 02:24 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Nice work A. It is going to look very cool when completed. All you will need is some lights next. LOL.
Old Aug 02, 2010, 02:48 PM
Joined Sep 2009
Darryl,
Don't you know that i've destroy two fuses before to go for this third one?LOL!
Old Aug 02, 2010, 02:59 PM
dkfuji is offline
The OC, California
Joined Feb 2007
He he. . Of course. I actually installed the 180Q fuse on a 3D EP200 a while back and it did look very cool. Here is a vid of it flying in the park. The added weight did effect it flight characteristics though. The tail was not as snappy but of course I had some really cheap electronics in it and it was not flybarless. I also replaced the landing skids and built an aluminum subframe for the landing wheels to keep the "look".
Walkera CB180Q Fully 3D CP Mod (2 min 18 sec)
Old Aug 02, 2010, 03:02 PM
Joined Sep 2009
ok, some update.It's really a pain for removing tail rotor, belt drive assembly to put fuse in so i've cut-off a 5mm space along the tailboom-fuse to make the job easier.Just snapit in and keep it tight with the existing stock canopy holder pin. This way, it will be verey simple to take it out for maintenance.Don't worry, plastic fuse can be slightly bent without breaking. So far, i'm looking for some magnet for the other half, maybe finding on some glasses clips....Also, using a thinner batt will give more space on the upper end & made fuselage fit more nicely onto the front.
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
