Old Dec 27, 2011, 09:58 AM
HELIRON69's Avatar
United States, PA, Shippensburg
Joined Feb 2010
Originally Posted by tracknoob View Post
Here is some info and pix that might help (from earlier on the thread) - for instance, notice that with the 1800, I need to put the wires at the top so the canopy goes on:
http://www.rcgroups.com/forums/showp...postcount=1453
http://www.rcgroups.com/forums/showp...postcount=1454
Thank you for the pics. Darryl did install the longer arms. The one for the elev servo has been trimmed but it still sticks out past the frame. The battery won't go up against the frame. I've found some 1500mah 25c batteries that are shorter than stock. After the first of the year I'll order some and give them a try.
HELIRON69 is offline Find More Posts by HELIRON69
Old Jan 02, 2012, 12:31 PM
deliver1003's Avatar
Joined Jul 2011
Hy Guyz I have been away for a while ,
I had the 3g stabilizing problems with my walkera 4f200 with rx2702V,a few pages before.
I have replaced the rx and now everything is fine.
THX for all the help!
Walkera 4F200 Upgraded 2nd flight (3 min 4 sec)
Have fun guyz!!
Davee
deliver1003 is offline Find More Posts by deliver1003
Old Jan 02, 2012, 02:10 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Yessss!!!!!
tracknoob is offline Find More Posts by tracknoob
Old Jan 02, 2012, 03:18 PM
1 year flyin' & lovin' it!
OldGuyHelifly11's Avatar
United States, CA, Covina
Joined Aug 2011
Davee
Glad to hear you got it worked out. I finally got my 2702 conversion project up & running, just to strip a auto-rotation bearing on the mainshaft. With the 2702, it was VERY stable. Nice receiver! Your 4F looks like it flies well!
Happy flying!
AB
OldGuyHelifly11 is offline Find More Posts by OldGuyHelifly11
Old Jan 02, 2012, 04:28 PM
Joined Jul 2011
Happy flying!
AB
Thanks!
Yes it was a hard job to find out,but we did it
thanks to this forum and all of you guyz!
If somebody has any problem or question about rx2702v or walkera products i think i can help. except 3d i have to tweak my bird a lot to behave as i like.
I'm interested in your auto rotation project!
If you are ready with it, please show us!
I will post some better videos in the future if you want to or follow me on my youtube channel.
my plan is to buy a TREX 550E V2 3GX or TREX 600 EFL Pro this summer and take some Gopro HD footages
Anyways, thanks again, and nice fly to all of you
Old Jan 05, 2012, 09:06 PM
Joined Apr 2011
[QUOTE=deliver1003;20300508]Thanks!
I have 2 4F200's. One with the stock 3 blade head, the other with the 2 blade V200D03 head. I'm using RX2618V receivers in both of them. When I bind the RX's with my 2801 Pro Tx SOMETIMES it pulls down the AIL servo about 10 degrees from a level swash. It does this on both of the heli's so it must be something in the RX's that's causing it. Has anyone noticed this problem with the 2618 RX's ?
I'm considering buying a RX2702V receiver for my V450D01. WOW makes a big deal about their 3 page setup instructions. Are these instructions available online so that I can look at them before ordering it. Some posts I have read say that the instructions are not very helpful. My V450D01 manual has detailed instructions for setting up the RX with the 2801 Tx. Is that good enough?
clearprop88 is online now Find More Posts by clearprop88
Old Jan 05, 2012, 09:55 PM
Joined Aug 2011
[QUOTE=clearprop88;20334494]
Thanks!
I had that problem with the 2612V & 2618V. each time, I had a helluva time hovering, wouldn't stabilize. The 2612 caused me to dumbthumb one into the ground while landing. In each case I replaced them with new Rx's, one a new 2618V, the other a 2624V. Both are flying without any issues.....so far.
As far as the 2702V, your V450 instructions are sufficient, WOW's are the same with a few editing clarifications. I set one up using their instructions without any problems. What a great Rx! If you have any further questions, PM me.
Good luck,
AB
Old Jan 05, 2012, 11:00 PM
Joined Apr 2011
Thanks AB.
I have a replacement 2618 on order. Hopefully it will work OK.
I have another problem with the 2618. When I program in Throttle Hold it also messes up the leveling of the swash. When I inhibit throttle hold it works OK, except for the occassional pull down of the AIL servo that I mentioned before.
Hopefully these problems are fixed in the 2624.
Old Jan 05, 2012, 11:22 PM
Joined Aug 2011
Originally Posted by clearprop88 View Post
Thanks AB.
Must be a glitch with your Rx. Are you setting the pitch too? I don't have those problems with either of mine with the TH.
Good luck!
AB
Old Jan 06, 2012, 12:04 AM
Currently living to fly...
Japan, Tokyo
Joined Jun 2011
Thanks!
You can try this...
http://www.rcgroups.com/forums/showa...2&d=1315069057
thwaitm is offline Find More Posts by thwaitm
Old Jan 06, 2012, 11:45 AM
Joined Apr 2011
[QUOTE=thwaitm;20336056]
Thanks, got it.
I'm looking for the 3 WOW setup sheets.
Old Jan 06, 2012, 11:48 AM
Joined Apr 2011
Good luck!
AB
Yes I set the TH pitch curve too.
I have the TH set to -5 just to be sure the motor is shut off.
The strange thing is that it occurs on both of my 2618's.
Old Jan 06, 2012, 11:57 AM
Joined Aug 2011
[QUOTE=clearprop88;20339830]
Originally Posted by thwaitm View Post
Thanks, got it.
PM me.
AB
Old Jan 06, 2012, 01:04 PM
Joined Apr 2011
I think I may have solved the problem with the occasional pull down of my AIL servo.
I use subtrim and trim to level my swash.
If I zero the subtrim and trim before I turn on the TX and RX the swash ends up almost level. So each time I get ready to fly I have to set the subtrim and trim each time. It's annoying but it works.
I read in a post somewhere that that's the way the 2618 gyro works. I didn't beleive it when I read it, but I beleive it now.
If you have subtrim set to the left the gyro will try to compensate to the right when it boots up.
Anyway, the moral is, you have to mechanically level the swash. I was too lazy to do that, and was relying on subtrim to do it for me.
That may be the problem with my TH also. I havn't tried it yet, but I think it will solve that problem too.
Old Jan 14, 2012, 07:51 PM
Joined Aug 2011
RX2702V setup
Glen_d13...You have to go into your user settings and set it to allow PM's.
AB
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
