Old Dec 17, 2011, 12:46 AM
OldGuyHelifly11 is offline
Find More Posts by OldGuyHelifly11
1 year flyin' & lovin' it!
OldGuyHelifly11's Avatar
United States, CA, Covina
Joined Aug 2011
Originally Posted by dgibbons View Post
I haven't gotten that far yet. Are you reversing it on the reverse menu or are you using a negative value to reverse the direction? Or, what channel is the rudder on the tx? I haven't reversed the rudder gyro on the rx yet.
Thanks again. I hope I'm not hijacking this thread with this question.
Based on your latest questions, I'm unsure of what you're trying to accomplish. Why are you reversing the blade grips? Are you trying to reverse the tail pitch, or blade direction? Or are you trying to compensate for the direction of the rudder gyro response?
AB
OldGuyHelifly11 is offline Find More Posts by OldGuyHelifly11
Old Dec 17, 2011, 06:26 PM
dgibbons is offline
Find More Posts by dgibbons
dgibbons's Avatar
United States, AZ, Phoenix
Joined Jul 2011
I want to be able to correct the geometry on the tail slider. Currently I have more travel with left rudder due to the slider is not centered. Flipping the grips will correct this. I can just mount the servo horn on the other side to correct the servo travel direction, but I'm wondering if there is another way.
AB
dgibbons is offline Find More Posts by dgibbons
Old Dec 17, 2011, 11:31 PM
Joined Aug 2011
O I C, I thought you were having rudder direction problems. You can't adjust the linkage or slide the servo mount up or back to center the slider???
AB
Old Dec 17, 2011, 11:42 PM
Joined Aug 2011
I finally got those Henge servos I've been waiting for. Set the 2702 up, & couldn't believe how easy it was. Got a 30 second hover in, limited by darkness & a little rain. Going to try & get it adjusted & flying tomorrow!
AB
Old Dec 18, 2011, 12:48 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
AB
Are the Henge servo's drop in's. What's the Henge number?
Are you using the 2702 in the 4F200?
clearprop88 is offline Find More Posts by clearprop88
Old Dec 18, 2011, 12:54 PM
Joined Apr 2011
I finished the 2 blade mod last night.
It fly's great, better than the 3 blade version.
It's much quieter, and very stable. Longer flight times too.
I flew it with the 1500mah stock battery this morning just to see how long the flight time would be. I got 10 minutes on the pack.
I have another 4F200 which I'll keep as a 3 blade version.
I think this is one of Walkera's best designs yet.
Old Dec 21, 2011, 01:08 AM
Joined Aug 2011
I'm using Henge MD933's for the cyclics in my HIKO400. They are a bit longer in depth, but I was able to use the stock mounting tabs. I had to mount the rear servo behind the tab, the servo arm was too close to the elevator servo. WK7.6-6's came out. I'm also using the 2702 in the HIKO.
I'm not sure if they will fit in the 4F200....anybody?
AB
Old Dec 21, 2011, 11:38 AM
Joined Apr 2011
AB
How do you program the 2702 RX. Do you use the TX to program it?
Old Dec 22, 2011, 09:04 AM
Joined Aug 2011
I got an info booklet from WOW. It is essentially the V450 setup instructions with some modifications/updates made by WOW. It's a very direct and easy to follow instruction sheet that explains how to setup the endpoints of servo travel and gyro direction. Everything is done using both the Rx & Tx.
Let me know if you need some assistance.
AB
Old Dec 23, 2011, 01:43 PM
HELIRON69 is offline
Find More Posts by HELIRON69
HELIRON69's Avatar
United States, PA, Chambersburg
Joined Feb 2010
I got this heli from Dkfuji, part of a package deal.I've read this whole thread and was kinda expecting the worse. To my surprise and delight it flys really well. My first liftoff it did go to the right a little but I was nervous. Just added a little more throttle and up it went. The tail is rock solid and holds in hard climbouts. So far after 6 packs no problems that were discussed here. Things may show up over time but THIS heli is awesome. I guess getting it from Darryl has something to do with it.
By the way the LM flys great too. He sent along 1 1500mah and 1 1200mah battery. The 1500 was in the LM and the 1200 in this one. I tried the 1500 in the 4F200 and could not get the canopy on without pushing the batt up against the Elev servo. Is the 1500 for this heli shorter? Would like to get some extra batts and hoped to use them for both. Some advice would be great.
Merry Christmas and Happy New Year,
Ron
HELIRON69 is offline Find More Posts by HELIRON69
Old Dec 26, 2011, 08:37 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by tracknoob View Post
ESC (including BEC power -- pos and neg-- and also throttle signal) to THRO1, all other servos as labeled. THRO 2 not used.
THRO 2 is not filtered for 'power on with non-zero throttle' so you can use it to program your ESC. Plugged into THRO1 you won't be able to program the ESC.
thwaitm is offline Find More Posts by thwaitm
Old Dec 26, 2011, 10:36 AM
Joined Aug 2011
That's good to know. I was attempting to program a new ESC yesterday, and gave up. Thanks!
AB
Old Dec 26, 2011, 11:43 PM
Mahfu is offline
Find More Posts by Mahfu
United States, IL, Chicago
Joined Sep 2011
Ron
First off it sounds like you are dealing with a non stock heli. The 1500 is the recommended battery from WOW. It is possible you have longer than stock servo arms. The stock arms come close to the battery to begin with. You'll have to have someone else tell you what the stock length is for the servo arms though. I changed mine out a while back and don't have access to my heli right now regardless.
Mahfu is offline Find More Posts by Mahfu
Old Dec 27, 2011, 01:51 AM
HELIRON69's Avatar
Joined Feb 2010
Thank you. Dkfuji has modded this heli and may have put on the longer servo arms. I'll have to PM him and ask. I'll also look around on Ebay and try an find a battery that is a little shorter. I can't complain too much, I got a great deal on this and it flys really awesome.
Old Dec 27, 2011, 05:58 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Here is some info and pix that might help (from earlier on the thread) - for instance, notice that with the 1800, I need to put the wires at the top so the canopy goes on:
http://www.rcgroups.com/forums/showp...postcount=1453
http://www.rcgroups.com/forums/showp...postcount=1454
tracknoob is offline Find More Posts by tracknoob
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
