Old Dec 12, 2011, 11:42 AM
Mahfu is offline
Find More Posts by Mahfu
United States, IL, Chicago
Joined Sep 2011
Originally Posted by OldGuyHelifly11 View Post
I think it has something to do with the programming of these particular receivers. I have tested the tail hold during setup with 3 different helis that I have this Rx installed in. In each case during pitch pumps & full power punch-outs, I can get the tail to drift, and during piros I have gotten the tail to let go where I had to manually recover it. I'm finding that the GYRO HOLD has to be around 70-80% to be rock solid. However.... during the times that mine crashed, I was only doing SLOW forward flight in my backyard, at about 5ft altitude, doing circles & figure 8's. Figure that one out!
I just ordered an RX2624V to test, maybe it's improved. I hope.
AB
I wasn't doing much more than hovering and forward flight. I was a little higher but pitch and throttle were behaving fine so I was able to get it down without incident.
Let us know how the 2624 works out.
Mahfu is offline Find More Posts by Mahfu
Old Dec 14, 2011, 01:25 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
I have a WK2801 Pro, but I have been flying my 4F200 in 2603 Compatibility mode. I would like to fly it in 2801 mode, but I can't seem to get it set up right.
It's all stock except for the RX, I'm using a 2618 RX.
What servo Normal/Reverse settings should I use, and any other settings to use the 2801 TX?
clearprop88 is offline Find More Posts by clearprop88
Old Dec 14, 2011, 09:26 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
From memory I think you have to interchange the PIT and AILE servo leads in order to get the mix right in 2801 mode using a rx2612. Also set the swash to "single servo" mode. Somebody else may be able to confirm the servo channel swap.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Dec 14, 2011, 10:34 PM
Joined Apr 2011
Mick
OK, thanks, I'll try that.
Edit: That didn't work. What servo reverse settings did you use?
Old Dec 15, 2011, 12:40 PM
Mahfu is offline
Joined Sep 2011
Which way is your RX installed? The 2618 has to be rotated 180 deg from the direction the 2612 is installed.
Old Dec 15, 2011, 12:54 PM
OldGuyHelifly11 is offline
Find More Posts by OldGuyHelifly11
1 year flyin' & lovin' it!
OldGuyHelifly11's Avatar
United States, CA, Covina
Joined Aug 2011
My 2618 is installed exactly as the 2612 was, however, I had to rotate it 180 when I did my 1#A FBL conversion. On mine, it is set to 1 servo, & the Aile & Elev ch are reversed. I can't confirm the Ch swap without taking it apart.
Also, I got the 2624V in & the rudder gyro is programmed wrong. I think I got a defective one. Everything else works fine. Going to try another one.
AB
OldGuyHelifly11 is offline Find More Posts by OldGuyHelifly11
Old Dec 15, 2011, 01:09 PM
Joined Aug 2011
Originally Posted by tracknoob View Post
Those @!%!@$#%@$^@## 2612's have probably wrecked more helis, and caused more frustration than any single part I can think of in RC.
My attitude on the 2612 =
My attitude on the 2618 =
My attitude on the 2702 =
I just took my 4f200s out the other day, one with 2618, one with 2702, and while the 2618 is better than the notoriously untrustworthy 2612, the difference to the 2702, IMHO, makes it worth the price to upgrade all the way. So much smoother, predictable, and yet more responsive.
Tracknoob, quick question on the Rx2702, I noticed that it has connections for BATT, THRO1, & THRO2. How did you connect yours to your ESC/BATT?
I'm about to complete a FBL conversion for a HIKO400, and use the 2702.
Thanks!
AB
Old Dec 15, 2011, 02:24 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Thanks!
AB
ESC (including BEC power -- pos and neg-- and also throttle signal) to THRO1, all other servos as labeled. THRO 2 not used.
tracknoob is offline Find More Posts by tracknoob
Old Dec 15, 2011, 06:22 PM
Joined Aug 2011
Thanks. I just happened to stop by WOW today and saw one on the V500 connected.
AB
Old Dec 15, 2011, 10:11 PM
Joined Apr 2011
AB
Are all of your servo's set to normal?
Old Dec 15, 2011, 10:13 PM
Joined Apr 2011
AB
Does the 2624 bind with the 2801 TX without swapping servo's, or any other changes.
Old Dec 15, 2011, 11:37 PM
Joined Aug 2011
Aile & Elev are both REV.
Yes, It's the Rx2624V for the 2801, they also have a 2624V-D for the DEVO. I got the reverse Gyro figured out. I had to swap the rudder servo to the opposite side of the heli. Darryl suggested it, it worked. I put 2 packs through it to set the gyro sens up. Hovers beautifully. I noticed that on this one, when the voltage gets low you don't have to fight it to keep it level. I'm thinking that's one of the upgrades from the 2618 & 2612. I cant wait until the weather gets better, rain today, wind tomorrow.
AB
Old Dec 16, 2011, 07:44 PM
dgibbons is offline
Find More Posts by dgibbons
dgibbons's Avatar
United States, AZ, Phoenix
Joined Jul 2011
2702 RX Rudder Reverse
I have a 450 clone with the 2702 rx. I recently had my 5084 tail servo fail. I replaced it with a savox 0262. Here's my question. I'd like to flip the tail grips & need to reverse the the servo throw on the rudder. What's the best way? Thanks for the help.
dgibbons is offline Find More Posts by dgibbons
Old Dec 16, 2011, 08:18 PM
Joined Aug 2011
I recently ran into the same situation with one of mine. Question, when you reverse the rudder/servo direction in the Tx, does the gyro not respond correctly? That's what mine was doing. I re-mounted the servo to the opposite side of the tail boom. It worked fine after that.
Good luck,
AB
Old Dec 16, 2011, 11:50 PM
dgibbons is offline
dgibbons's Avatar
Joined Jul 2011
I haven't gotten that far yet. Are you reversing it on the reverse menu or are you using a negative value to reverse the direction? Or, what channel is the rudder on the tx? I haven't reversed the rudder gyro on the rx yet.
Thanks again. I hope I'm not hijacking this thread with this question.
Good luck,
AB
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Off Site Walkera 4#3 2.4Ghz RTF - Metal Head Version nighthawk0077 Aircraft - Electric - Helis (FS/W) 0 Nov 22, 2009 08:23 PM
Discussion Unique "mixer less" Bell Hiller Head design of the MSR plus Walkera 4#3 Mixer lesss EQMOD Micro Helis 47 Sep 26, 2009 11:59 PM
Discussion 45 Degree Flybar Conversion on a Walkera 4#3 V1 BELL HILLER head EQMOD Micro Helis 13 Sep 01, 2009 11:15 PM
Build Log Walkera 4#3 HH-65 USCG Dauphin--VIDEO 4 Blade head works page6 stevel48 Micro Helis 146 Dec 03, 2008 10:16 AM
