Semi Scale Schweizer 300 3 blade
Here is my Hk 450 Pro belt edition with a Lightning heli 3 blade head. I am using the scale blades that RC Aerodyne offers.
Overall performance is good, and with the correct phasing, I do not need any electronic stabilization. I run a lower head speed, and the tail keeps up nicely. My thought is to let the blades cone properly instead of being flung out with a crazy high head speed. Current Setup: Hk450 Pro Belt Drive Hobbymate HB2840 3600Kv 13t Mystery 40A ESC MD922 Digital Servos .07 sec. Cyclic Futaba 9257 Tail Servo HK401b Gyro RC Aerodyne Scale 450 Blades Phasing: with one blade over the tail boom, the follower is 90 degrees to it. Flight: Remembering that we are flying helicopters, I thought of a real one in which you have to trim the rotor disk to the proper angle for the type of flight you are in. In forward flight you have to trim the stick back to neutral or else you will be way in the stick and that's when the dual rates start to loose effect. Once you get it trimmed close for the winds you are in, the helicopter will fly nice for the whole flight.
Lake Zurich, IL
Good show; those blades are nice!
I got the same blades going a few months back.
Joined Feb 2010
You can get a Hughes 300 Fuse from Pro Heli... .
http://www.proheli.de/onlineshop/ind...?cPath=196_215 but it's a bit semiscale... . |
Cheers - Boyd
This is where mine came from.
http://scaleflying.3dcartstores.com/...ize_p_808.html easy enough to set up, but requires a lot of tightening after each flight. Just routine maintenance. I also have a smartmodel 3 blade head, but with the weird swash i never got around to using it. |
| Thread Tools | |
| Wanted 3-blade 450 swash or full head | TRYPHON75 | Aircraft - Electric - Helis (FS/W) | 0 | May 13, 2010 05:53 AM |
| Sold Typhoon 3 blade head with swashplate (450 size) | pttse | Aircraft - Electric - Helis (FS/W) | 9 | Mar 11, 2010 11:24 AM |
| Discussion 450 3 blade head...Smartmodel vs. RC Aerodyne...which is shorter? | SidewaysLS4 | Scale Helicopters | 12 | Sep 23, 2009 05:14 PM |
| For Sale 2 blade cp pro frames with/electronics, cnc head...*NEW PRICE* | abapitcher712 | Aircraft - Electric - Helis (FS/W) | 0 | Jul 19, 2008 04:00 PM |
| Sold HBFP bare frame w/motors no head or electronics | jettvolks | Aircraft - Electric - Helis (FS/W) | 4 | Nov 21, 2007 07:15 PM |
