Old Aug 18, 2012, 09:49 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Cool thanks for the info! So when landing, you dont want full flaps either?
electricrc68 is offline Find More Posts by electricrc68
Old Aug 18, 2012, 10:18 PM
AlfaXray1 is offline
Find More Posts by AlfaXray1
AlfaXray1's Avatar
Joined May 2011
Full flaps requires a lot more precession and skill. So start with 20 degrees full is only 30 on these 172's. The Cessna 150 has 40 degrees so it is like putting out the barn doors. You really need to point that nose at the ground with all the flaps in on it.
AlfaXray1 is offline Find More Posts by AlfaXray1
Old Aug 18, 2012, 10:40 PM
Joined May 2011
Ah okay thanks. 20 Degrees for every plane including the airliners, warbirds, etc?
Old Aug 18, 2012, 10:57 PM
AlfaXray1's Avatar
Joined May 2011
Not every plane...some (the faster, aerodynamically cleaner) planes need much more flap. On 747, 737 it needs all the flaps to keep that speed stable on approach.
Old Aug 18, 2012, 11:11 PM
skorski is offline
Find More Posts by skorski
No conspiracy in theory
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
I think under details when you are choosing a plane some of the reccomended settings are listed.
I may be wrong, i'll have to double check that myself!
Basically, the more flaps the faster you drop! & AX is right practice practice practice practice!
Take one plane at a time & try approaches at different settings to see the effect!
Thats the good thing about sims you can learn without injury!
Mike.
skorski is offline Find More Posts by skorski
Old Aug 18, 2012, 11:12 PM
skorski is offline
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
Hey AX!
How ya doin?
Your last post popped in while I was writing.
Mike.
Old Aug 18, 2012, 11:14 PM
ErcoupeEd is offline
Find More Posts by ErcoupeEd
ErcoupeEd's Avatar
United States, IN, Grabill
Joined May 2004
Have any of you guys seen any of the high performance RC sailplanes that sometimes have the capability to reach 90 degrees of flaps?
Also use dual "up aileron at the same time?
It's called "crow" and can literally almost stop the airplane in flight!
Makes for extremely accurate spot landings!
ErcoupeEd is offline Find More Posts by ErcoupeEd
Old Aug 18, 2012, 11:27 PM
skorski is offline
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
I sometimes find the longest runway I can & play with flap settings while trying to maintain the same altitude. Sometimes I have to use the 2d view that just has the guages across the bottom of the screen or the outside view to see the runway!
Mike.
Old Aug 18, 2012, 11:28 PM
skorski is offline
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
Jeez.....!
Everybody an insomniac tonite?
Hey Ed!
Mike.
Old Aug 18, 2012, 11:30 PM
Joined May 2011
Mike.
Okay thanks guys. I guess i will experiment with it when i get that joystick in...its such a terrible experience flying with the keyboard and mouse! Yeah sims are awesome in the fact that you can learn without injury. I don't have a RC simulator, but luckily, most of my fleet is micros!
Old Aug 19, 2012, 12:04 AM
skorski is offline
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
Hang in there, We all take small steps to learn stuff!
Every day can be an adventure if you let it!
Mike.
Last edited by skorski; Aug 19, 2012 at 12:07 AM. Reason: Because i'm old enough that i can!
Old Aug 19, 2012, 12:06 AM
Joined May 2011
Yep im taking small steps...im an insomniac tonight...cant sleep.
Old Aug 19, 2012, 12:09 AM
skorski is offline
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
I'm off to host on fsx for a short hop around the patch,
catch you next time!
Mike.
Old Aug 19, 2012, 11:14 AM
Joined May 2011
Another question...I just experimented with landing, and have observed something. Am I supposed to let the plane roll a little bit on landing before applying the brakes, or should i apply the brakes right before touchdown? What i have noticed is, when i dont apply the brakes right before touchdown and let the plane get down on the runway without the brakes applied, it bounces back up into the air. But, when i apply the brakes right before the plane touches the ground, it tends not to bounce and makes for a pretty good landing.
Old Aug 19, 2012, 02:52 PM
AlfaXray1's Avatar
Joined May 2011
You're touching down on the pavement with the wheels locked up by Brakes. That makes it where it will slam the nose down and will make it stopr quicker. But if you did that in a real airplane you will damage landing gear, tires, perhaps ever run the plane off the runway one side or the other. So If you let your speed bleed off in the landing flair with all the power removed and let the plane settle it will not bounce. You ar landing weith to much speed and hitting hard on the runway it will bounce back up and there is still flying speed so it fill float a moment and then hit again and as you do this over and over it is called "Pilot Induced Oscillations". NOT GOOD, so let the speed bleed off while you are still in the air don't force it onto the runway.
Sold sold jpflyrc Non R/C Items (FS/W) 5 Nov 01, 2010 03:26 PM
Discussion Computer Flight Simulator FS-X plus Shrink Tubing! ***OVER*** wizzinbya Other Websites 149 Apr 20, 2010 02:40 PM
Discussion flight simulator x from microsoft Robbie106gti Simulators 4 Mar 31, 2010 09:16 PM
Discussion Microsoft Flight Simulator X Big Foot 48 Simulators 6 Oct 14, 2006 08:23 PM
Discussion Microsoft Flight Simulator X BD Flyer Electric Plane Talk 5 Oct 08, 2006 07:30 PM
