Old Jun 22, 2010, 03:27 PM
aoliveiraneto is offline
Find More Posts by aoliveiraneto
BRA 15570
aoliveiraneto's Avatar
São Paulo-Brazil
Joined Apr 2010
Help!
Check List before Flight
Guys,
Does someone has a good check list before flight for beginners?
Thank you very much.
Arthur
aoliveiraneto is offline Find More Posts by aoliveiraneto
Old Jun 22, 2010, 03:51 PM
crash campbell is offline
Find More Posts by crash campbell
Port Macquarie, Australia
Joined Aug 2008
Hi Arthur,
How did the flight with the Chippy go?
Here is a link to a UK site that has check lists and lots of good info.
http://www.bmfa.org/faq/rc/pre_flight.html
Cheers,
Colin
crash campbell is offline Find More Posts by crash campbell
Old Jun 23, 2010, 07:12 AM
BRA 15570
São Paulo-Brazil
Joined Apr 2010
Hi Collin,
Thank you very much for your help. I've not flown my Chipmunck yet, yesterday I had a problem to run the OS FS 91, I think that the KwickFill is the problem, tomorrow I'll try again without it.
Arthur
Old Jun 23, 2010, 11:57 AM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
The link Crash gives in his post (#2) is a great reference and guide and a MUST before EVERY flying day.
One thing that I would add is flight control check before each flight. Gives you a chance to see if the surfaces are moving the direction you want them to...
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jun 29, 2010, 06:32 AM
BRA 15570
São Paulo-Brazil
Joined Apr 2010
EJWash
EJWash,
Thank you very much for your advises but I have a more doubt: What do you think about the kiwckFill? I listened goods and bads informations about it.
Arthur
Old Jun 29, 2010, 12:49 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Arthur,
I've heard guys gripe about them (Du-Bro and Great Planes) and it usually comes down to dirt getting into them and preventing the O-ring from properly seating and they leak. I installed one on my pattern ship and added the cover to it. It's been on there about six months now. No problems as of yet.
EJWash
Old Jun 29, 2010, 02:16 PM
redh is offline
Find More Posts by redh
Fla.
Joined Apr 2005
One of my students use's the quick fill and he had problems till I found out that he wasn't pulling it all the way out, then pushing it all the way back in. Also use the cover, it keeps crap out. I like the system and plan on using it. ( Du Bro ) ENJOY !!! RED
redh is offline Find More Posts by redh
Old Jun 29, 2010, 06:54 PM
BRA 15570
São Paulo-Brazil
Joined Apr 2010
Red,
Thank you very much for your advises, I'm goin to experience it because is a easy system to filling.
Arthur
Old Jul 04, 2010, 07:13 PM
BRA 15570
São Paulo-Brazil
Joined Apr 2010
My KwickFill worked very well this weekend, the engine was with a bad carburization.
Thank you very much
Old Aug 27, 2014, 11:43 AM
nymadcientist is offline
Find More Posts by nymadcientist
United States, NY, New York
Joined Sep 2012
Originally Posted by aoliveiraneto View Post
Guys,
Arthur
# 1 did u practice simulator
#2
#3
nymadcientist is offline Find More Posts by nymadcientist
Old Oct 20, 2015, 12:27 PM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
#1 Check to see if the aircraft flies
No but seriously
  1. Check battery voltage (or w/e if you fly gas)
  2. Check CG
  3. Check control surfaces are centered without input
  4. Check Throws
  5. Check control surfaces
  6. Check control direction (lol reverse ailerons)
  7. Check gyro direction (if installed)
  8. Check auxiliary functions (retracts, flaps)
  9. Check mixes (if any) to make sure that they are doing the right thing
  10. Check tracking on the runway (wheels are straight, plane rolls straight, if you have wheels..)
  11. Check wind direction, take off into it.
  12. Check rubble after crash for salvageable components
bandetlol is offline Find More Posts by bandetlol
Old Oct 20, 2015, 02:45 PM
marmalade1 is online now
Find More Posts by marmalade1
United States, IL, Wheaton
Joined Sep 2013
To clarify bandetlol's #5, be sure the control surfaces are tightly bound to the wing/stabilizer. Hinges coming loose are fairly common and can cause an alarming change in flight characteristics.
I've had one aileron fall loose, one rudder, and (thankfully just) half of an elevator. All landed well, but were concerning. I since added a small hole and a fragment of a toothpick through the CA hinge.
PD.
marmalade1 is online now Find More Posts by marmalade1
Old Nov 05, 2015, 01:21 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
PD.
On your CA hinge.. just wick CA into that hole.. will do more good than the toothpick allowing the CA to disperse more easily throughout and farther away from the hinge line
Thermalin is offline Find More Posts by Thermalin
Discussion Maiden Flight Check List / Flight Plan Fugitive_Bill Electric Ducted Fan Jet Talk 8 Aug 30, 2014 09:04 AM
Discussion AP- Setup Check -Before the BIG Event! guyg Aerial Photography 0 May 12, 2010 12:07 AM
Discussion Guys check this out! PL8 competition comes before it's available Himalaya Batteries and Chargers 4 Apr 17, 2010 06:42 AM
Discussion on your prefrlight check list, remember to check your... GAU-8 FPV Talk 6 Mar 26, 2010 01:03 AM
