Old May 18, 2011, 05:56 AM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
I really like it cause I've got "Gorilla Hands", and it makes it a LOT easier for me to work around the larger parts!
EZglider is offline Find More Posts by EZglider
Old May 19, 2011, 07:16 PM
EZglider is offline
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
HelivsFMX?
What was the auw for your 40" "Big Ripper"? I weighed up my cut foam w/ cf installed, came to between 7-8 oz. If I don't go Gorilla Glue crazy, I think I can bring it in around 15-16oz. with a 1000 mah 3s battery. That's what I'm shooting for, anyway.
Old May 21, 2011, 05:34 AM
MarcinN is offline
Find More Posts by MarcinN
Warszawa, Poland
Joined Jul 2008
Hi everybody
I also have Lil Ripper
After destroying first version from 3/6 mm depron, laminating with fiberglass cloth, with monster dualsky motor (weight about 350g),
I finished light version (284g = 10oz).
My setup:
motor emax gt 2205/22 (23g) - more than 500g thrust
with 8x4 prop
ESC emax 12A
servos 4xhitec 55
orange (dsm2) receiver, weight about 2-3g
Rhino 750mAh 3s 20c
Today was the maiden flight
It flies super
Shaun, thank you for your plans and kits
Here is a link to polish forum, when I wrote some words about this fantastic model
http://pfmrc.eu/viewtopic.php?p=380424#380424
Marcin
MarcinN is offline Find More Posts by MarcinN
Old May 21, 2011, 05:56 AM
3DMON is offline
Find More Posts by 3DMON
KK4EHM--FPV Mon!
3DMON's Avatar
United States, FL, Sebastian
Joined May 2005
Hi Marcin,
I took a look at that link with Google translate. I like your color scheme.
Thanks for the kind words!
3DMON is offline Find More Posts by 3DMON
Old May 21, 2011, 06:18 AM
MarcinN is offline
Warszawa, Poland
Joined Jul 2008
Thank you Shaun,
It was rather fast work, two spray depron paints, but in the air it looks well
Old May 24, 2011, 10:29 PM
Titangliderconve is offline
Find More Posts by Titangliderconve
No dihedral. That's how I roll
United States, NV, Reno
Joined Apr 2011
Is there a build guide for this?
Thank you, and good job on your plane
Titangliderconve is offline Find More Posts by Titangliderconve
Old May 24, 2011, 10:33 PM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
Click the download instructions link here: Instructions
Old May 24, 2011, 11:40 PM
TheOne420 is offline
Find More Posts by TheOne420
Chad
TheOne420's Avatar
United States, CA, Cathedral City
Joined Dec 2010
I got your plans and crunched them down to a 15" ws it flies great just a little heavy but it has a eflite 180 ,2 x 2.5gram servos,1 x parkzone s2000 linear servo, dsm2 compatable rx and a 9amp bl esc in it so the power is just fine but its not to floaty. A 17 or 18" ws should fix that problem though.
if anyone wants to make the plans smaller I say go for it cause it still flies great. if you do a 15"ws def go with ar6400 cause it should fly much better with the lighter weight
TheOne420 is offline Find More Posts by TheOne420
Old May 25, 2011, 12:07 AM
scot88 is offline
Find More Posts by scot88
Joined Jun 2010
Just finnished my Lil' Ripper made from DTF. I did a KFM4 wing, doubled the fuselage sides where the wing goes through and covered with packaging tape. Thanks 3DMON
scot88 is offline Find More Posts by scot88
Old May 25, 2011, 04:31 AM
EZglider is offline
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
I like the Dale Jr. Paint scheme!Let us know how the KFm wing works.
Old May 25, 2011, 05:18 AM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
I did a small profile version that size of the Lil' Ripper using the mini Parkzone brick and it flew ok too. I was really hoping I could have done the full fuse with that setup but it would have been too heavy. The brushless setup seems like it would be a better way to go. Thanks for sharing your results.
Looking good Scot88! I'm curious how the kfm4 is gonna do on it too. Hope the maiden goes well.
Old May 31, 2011, 12:02 AM
scot88 is offline
Joined Jun 2010
Maiden went great, 1 click of trim on the elevator. I'm a tad tail heavy with the cg on the front of the servos,wants to dive a little inverted . My AUW is 13.8 oz , the tape cost me about 2 1\2 - 3oz. Not sure why it's tail heavy. It flies great, flies like it has less wing loading than my Piranha (also KFM4) and wayyyy quicker (@ 40% throws). It spins like a top @ 60% throws, first three flights were at 40% for most of the time. Flight times are around 10 min, motor almost warm,not at all hot.
motor - 1300 kv silver wonder/9050 GWS prop
esc - TP 18A (20 amp) why don't they call it a 20A?
battery - 800mah 3s
servos - hxt-900 (probably could have used the hxt-500)
radio-Turnigy 9x reprogramed w/ER9X, 6ch reciver
I built this as a 3d / airobatic trainer, I think it's going to be just what I was looking for. Thanks 3DMON.
Do I have the cg thing backwards? If it's diving inverted don't I have to move the weight back? KFMs like the cg back a little.
Old May 31, 2011, 05:21 AM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
Congrats on the maiden. If the plane wants to dive when it is inverted it is nose heavy. Just move the battery back a little to help.
Old Jun 01, 2011, 03:02 PM
helivsFMX is offline
Find More Posts by helivsFMX
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
I think Im gonna rebuild another ripper. This time a slightly bigger than lil ripper (110%). I want it to work with my bell 1750KV motor so I think a 34" WS should be good. My last big ripper at 40" was a bit on the heavy size for the bell 1000kv motor I had so I need something a bit lighter.
Does anyone have experience comparing the KFM4 wing to the flat plate? I would like a KFM4 for windy conditions, but dont know if the added weight is worth the sacrificing... I think I'll just build it flat plate style again.
Also, has anyone tried the dollar tree foam board? I think I'll try that this time since its a bit more rigid than FFF and is a bit nicer looking.
helivsFMX is offline Find More Posts by helivsFMX
Old Jun 01, 2011, 04:55 PM
EZglider is offline
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Heli,
I'm using the DTF on my 40 in. currently in progress (I build SLOW!) Double laminated for wing, horiz. & vert. stab,some strategic doubling around the wing and rear section for strength.Looks like it's gonna work well. I did my original 31 in. Lil Ripper the same way.
Build Log **Speedy** by 3DMON (Plans & Video) 3DMON Foamies (Scratchbuilt) 1033 Dec 11, 2015 06:11 PM
Build Log ***3DMON'S Full Fuse F-22*** 3DMON Foamies (Scratchbuilt) 75 Feb 06, 2015 02:51 PM
Article Hacker Models Extra 330SC Full-Fuselage EPP Plane Review Spackles94 Sport Planes 86 Mar 29, 2013 09:13 AM
Discussion 3D plane project... need help with fuselage creating GreenAce92 CAD/CAM 3 Jan 25, 2010 07:23 PM
Discussion Silent Mite - Aerobatic Full Fuselage Fun Plane hoppy Foamies (Scratchbuilt) 4 Nov 22, 2009 02:58 PM
