Jun 23, 2010, 10:42 AM
United States, CT, Guilford
Joined Nov 2008
very nice, sir! the red version sure looks great. as far as the st cessna, there is no comparing the two! (my humble opinion, of course  ). first the scale looks, i think you are already sold on that. i had nothing but problems with the st offering. i can't blame to model for all of it, sure a lot of my problems were self inflicted. i pranged it in on the nose a few times. if you check through that thread, a bunch of the other fellows also did this. usually the result was a bent motor shaft. these were almost impossible to swap out, so i ended up buying at least two brand new motors. the nose gear was also a nightmare....despite buying a replacement or two i had great difficulty swapping those out. i also found that plane to be marginally powered. despite buying that plane, spending all kinds of money on parts, and $43 dollars to ship it to a friend, i was glad to see it go!
i found my cessna's c.g to be spot-on with a pack installed (zippy 2200mah). it really flys well. it does seem to come in for landing at a faster speed than i was expecting, maybe because the plane is a bit heavier than some of my other models. but, the flaps work great...slowing the model down nicely. no worries about the prop striking. i do want to try a two bladed prop. it seems like at full throttle the stock one is making more noise than providing power. not a big deal, as this is a scale flyer. but, this is on my list of things to do with this plane. my rudder functions just fine. is the pushrod suppport tube secure? i am a bit laid up right now (recent back surgery) so if i can get one of my kids to help i'll take my cessna down, remove that access hatch, and see how mine is set up. did you notice that the flaps are adjustable (both the deployment speed and degree that they go down)? i left mine as is, per the manual. i don't have a fancy radio, so no mixing elevator, etc. but, it's easy to control the plane while working the flaps if the plane's speed is kept low.
have you flown yours yet? i think you'll really be happy with it when you do!
rob
