Old Jun 20, 2010, 08:40 PM
greenmonsta79 is offline
Find More Posts by greenmonsta79
Brazil,IN
Joined May 2010
going from 20C to 30-40C discharge 14.8 can i burn my ESC??
Hey guy's I have a Nitroplanes Airfield 70mm F-16 my batteries are the generic batteries they come with, A 14.8 2200mah 20C battery, When i finish flying the batteries are hot and puffed, I mean burn yourself hot, I had ordered a Turnigy 2200mah 30-40C battery since I was told that jets should run a higher C rating
but I just don't know for sure if there is a chance I could fry the ESC? Also I don't know the ESC rating I would assume its a 50-60 but does not say anywhere, How would I find out what the largest capacity battery I could run in it? How would I determine it?? I know size and weight increases but the other variables. Thanks a million for any replies!
greenmonsta79 is offline Find More Posts by greenmonsta79
Old Jun 20, 2010, 09:20 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
The motor will pull as many amps as it needs. The fact that a battery is capable of supplying more does not change this. If your 20C batteries are hot and puffing, they are not capable of supplying enough amps for your motor/fan combo. You will need to measure your current draw and select the battery so that capacity times c-rating is greater than the amp draw - for example your 2200mAh 20C battery would be capable of no more than 44A (assuming that the manufacturer is honest about the numbers. I wouldn't run it above 30A). If your esc has been running reasonably cool until now, it won't be a problem with higher c-rating batteries. The only limitations for battery capacity are physical size and weight.
jkettu is offline Find More Posts by jkettu
Old Jun 21, 2010, 02:05 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
As jkettu has said, you need to measure your amps to make sure everything is running within it's ratings.
A possible issue when you change to higher-C battery is that your present pack might have been restricting the amount of amps the motor can get so, when you change to a pack with higher C, that restriction will be gone and the motor will be able to draw what it really wants -- which might be more amps than before.
I would have expected the stock batteries to be appropriately sized for the model, so it might also be worth checking if there's anything obvious that's making them overheat, like a bad motor, or no cooling airflow.
Edit: How long are your flights? If you're getting your 20C packs too hot, then in theory you've been running at somewhere close to 20C (44A for those packs), which will only give you 3-minute flights. And have you been running the packs until there's no more power left in them? That'll cause them to heat up as they run down to dangerously low voltage.
abenn is offline Find More Posts by abenn
Old Jun 21, 2010, 09:51 AM
Brazil,IN
Joined May 2010
I would say flight time is around 5 minutes, Granted I don't fly at full throttle the full flight, I usually bring it in when the motor fluctuates in sound makes a weird uh un uh un sound like it was meant to do it when it runs low so you can land it, even if I fly it for say 2 minutes and bring it in the battery is still smokin' hot, Also last night after this post I was installing a my 7ch Hobbyking 2.4 system in my Airfield 70mm F-4 Phantom and I stuck that 30-40C discharge battery in it and throttled it up and it smoked the 50A ESC in a instant! SMOKED literally like a old freight train!!!! terrible and I know for a fact that it had worked with the other 20C battery so!? I have a brand new Mystery 60A ESC that I am installing tonight but I will not run that 30-40C Turnigy Battery!
Old Jun 21, 2010, 10:14 AM
zagimon is offline
Find More Posts by zagimon
Patrick Jenkins
USA, LA, 5
Joined Dec 2006
That is a battery suited for cruising around and throttle managment. The 2200 20C that is. I would go with a 2500 25C at the least. You may want a 30c to 35c, but I use 25C and they just get warm. For EDF, 2200s are just for 4 min flights.
zagimon is offline Find More Posts by zagimon
Old Jun 21, 2010, 10:22 AM
zagimon is offline
Patrick Jenkins
USA, LA, 5
Joined Dec 2006
A battery can't smoke an esc if the set up is correct. Did you have a esc that is rated for 3S and 4S batteries? Maybe you went from a 3S to a 4S or the ESC was defective.
Old Jun 21, 2010, 11:40 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Apparently you do not have a wattmeter. A wattmeter is an essential tool when setting up electrics. You have to know how much current your system is asking for so that you can properly size the ESC and battery. A $50 wattmeter will go a long way toward saving many $$$ worth of ESC's and batteries.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jun 21, 2010, 01:50 PM
Brazil,IN
Joined May 2010
No I have a digital multimeter it was at my shop, I swear to god the minute I plugged the 2200mah 30-40c 14.8 Turnigy battery into the ESC leads it smoked it and just seconds previously I had the battery the plane came with the generic 2200mah 20C 14.8 plugged in and it worked fine, The minute I plugged that Turnigy battery in the ESC literally Smoked (damn smell was in the house for hours!) Bad battery??????
Old Jun 21, 2010, 01:57 PM
abenn is offline
Joined Jul 2004
I think I read recently of a battery pack that was shipped with the plug on the wrong way round.
Are you sure your Turnigy was plugged into the ESC the right way? -- reversing the leads is about the only way I know to instantly smoke an ESC.
Old Jun 21, 2010, 02:26 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There have been cases of the main power leads being reversed on a LiPoly. There have also been cases of the balancing leads reversed.
Old Jun 21, 2010, 02:33 PM
Brazil,IN
Joined May 2010
Black to Black, Red to Red, All I know for sure is the ESC went to the big ESC heaven in the sky and in a big way!!! I think when I get home tonight I will toss it. I don't feel like toasting another ESC because of a turd battery!
Old Jun 22, 2010, 02:25 AM
abenn is offline
Joined Jul 2004
Black to Black, Red to Red, ...
Yes, but have you checked that red is in fact the positive wire on that pack? What I read (and I think everydayflyer was talking about too) was the actual colour leads being the wrong way round, as well as the plugs
For Sale LiPo 4 CELL 14.8 2500 mAH 20C Craig Jacobs Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 12, 2010 05:13 PM
Wanted 2200mah 20C 14.8 Volt cgjohnst Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 30, 2010 09:30 PM
Discussion 20C vs. 40C Watts at same discharge rate? RamboFlier Batteries and Chargers 4 Feb 25, 2010 11:28 PM
Download Yet Another LiPoly comparison SMC 40C TP Pro Power 30 TP Pro Lite V2 (20C) everydayflyer Batteries and Chargers 57 Jul 25, 2009 09:50 AM
Is going from 7 to 8 cells (and higher discharge) enough to cook a brushed 400? Peter Young Power Systems 25 Mar 30, 2005 11:27 PM
