Old Jun 20, 2010, 11:17 AM
pglenn is offline
Find More Posts by pglenn
Joined Jun 2007
wood to fiberglass adhesive?
So I have a polyester fiberglass hull and looking to place a few wood ribs/bulkheads within it and a balsa deck over it. whats the "best" glue/adhesive for attaching to the hull? I will be using several coats of polyurethane over everything so I am not worried about the adhesive being water-proof
Patrick
pglenn is offline Find More Posts by pglenn
Old Jun 20, 2010, 11:23 AM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Patrick, Check out thistothat.com Very handy site.
420TEE is offline Find More Posts by 420TEE
Old Jun 20, 2010, 01:06 PM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
You could CA everything in place and then use a small batch of resin mixed with a filler (sawdust or talc) and then apply it to the gap areas. I do the same with epoxy, but I haven't glued wood to polyester yet. This is a good thread, I need an answer too.
Tollytime is offline Find More Posts by Tollytime
Old Jun 20, 2010, 01:08 PM
Tollytime's Avatar
Joined Nov 2006
www.thistothat.com
Old Jun 20, 2010, 02:02 PM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Constellation is glassed with poly resin. Everything glued to the hull is done with epoxy mixed with fine sawdust from the band-saw. The spots you're gluing to have to be de-waxed and sanded. Poly finish resin raises a wax to the surface when it sets which has to be removed in order to glue to the surface.
JerryTodd is offline Find More Posts by JerryTodd
Old Jun 20, 2010, 05:59 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
I've been using a Devcon 2 part epoxy product called 'Plastic welder'. It's supposed to be formulated to stick anything to fiberglass... and it DOES!
Be warned though, it doesnt have much working time..
toesup is offline Find More Posts by toesup
Old Jun 20, 2010, 07:43 PM
Prins Willem is offline
Find More Posts by Prins Willem
Old wreck in Milwaukee
Prins Willem's Avatar
United States, WI, West Allis
Joined May 2007
I have used CA and Testors green label with good success. Sanding is a must and I wipe the hull surface with acetone to remove any residual wax and contamination from fingers, sneezes, spilled coffee, etc. The acetone also is a solvent to the polyester so it will make the surface just slightly tacky for a few minutes which also helps adhesion. I have a 20 year old tug and the deck is still firmly in place. With the Testors its necessary to clamp the parts and allow to set overnight. Not conducive to rapid construction.
Prins Willem is offline Find More Posts by Prins Willem
Old Jun 20, 2010, 08:04 PM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
PL Premium
more coffee is offline Find More Posts by more coffee
Old Jun 20, 2010, 08:17 PM
pglenn is offline
Joined Jun 2007
well supposedly the CA-glue doesnt have a very long working time either (10-15secs?) so that isnt an issue so much... I trust tollytime, thats whom I bought the hull from is first place and highly recomend him for that... his initial idea was CA :-)
Old Jun 20, 2010, 10:52 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
West System G-Flex 655...
http://www.epoxyworks.com/25/pdf/G-flex_Epoxy.pdf
re: http://www.rcgroups.com/forums/showp...&postcount=481
woodybob is offline Find More Posts by woodybob
Old Jun 20, 2010, 11:07 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Originally Posted by woodybob View Post
[FONT=Comic Sans MS]West System G-Flex 655...
Totally agree!
Aerominded is offline Find More Posts by Aerominded
Old Jun 20, 2010, 11:10 PM
Tollytime's Avatar
Joined Nov 2006
Originally Posted by Aerominded View Post
Totally agree!
Yeah, I forgot all about that one. You could set everything in place with CA and then glue it with G-flex. Easy to mix and no heavy fumes. Sticks to metal, wood, and everything else.
Old Jun 21, 2010, 02:14 AM
Jacques Flambeau is offline
Find More Posts by Jacques Flambeau
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
Scuff and de-grease before using epoxy. "Goop" urethane adhesive for flat plates. A polyurethane adhesive like Titebond or Gorilla (foams and fills small gaps well). CA works, but is brittle and not waterproof.
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old Jun 21, 2010, 09:58 AM
bombertech is offline
Find More Posts by bombertech
Joined Nov 2007
Wood to fiberglass...
I did a test bond to a new glass tug hull last week. I dampened (with water) a small scrap of light plywood and used Elmers new polyurethane glue (this is basically the same as the original Gorilla glue). Lightly clamped and left overnight to cure I was rewarded with a bond that I will have to grind apart. I can't believe how well it bonded. Try it for yourself, I think you will be happy with the easy process. Keep building!
bombertech is offline Find More Posts by bombertech
Old Jun 21, 2010, 10:39 AM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
CA may not be waterproof, but it is water resistant..
http://en.wikipedia.org/wiki/Cyanoacrylate
Seeing as most of our models spend so little time in the water, and the CA'd areas are (should be!) well sealed CA can be used, but as Bill mentioned, it does / is brittle in high stress situations and is likely to pull away from the hull.
Question Adhesive for wood to metal? gtfreeflyer The Builders Workshop 4 Apr 28, 2010 09:49 AM
Wanted Looking for 70mm jet, fiberglass, wood sherlockshah Aircraft - Electric - Jets (FS/W) 6 Feb 11, 2010 09:28 AM
Discussion Polyurethane wood adhesive for glassing & minor repairs lostrider Electric Warbirds 2 Jul 26, 2006 03:34 PM
Fiberglass Rotor Blades VS Wood ? TRSDOC Electric Heli Talk 17 Aug 08, 2005 11:20 AM
Eco 8 Wood+Fiberglass blades FS ChrisT88 Aircraft - Electric - Helis (FS/W) 4 Nov 30, 2004 06:51 AM
