Old Jun 20, 2010, 05:44 AM
orange&white is offline
Find More Posts by orange&white
Scott R/C Time Pilot
orange&white's Avatar
NorthBend/Coos Bay,Oregon USA
Joined Dec 2009
Build Log
Cloudcraft Mercury Now with maiden video
Hi. I am hoping to build a 45" Cloudcraft Mercury.
Has anyone or know anyone who has built a Cloudcraft Mercury?
I still cant find any info or pictures of a C.C. Merc
I found the plan on the first page in the 2010 build off thread.
The plan was converted to .pdf and enlarged 643%, to get a 45" span, it is fuzzy, but good enough.
I changed the unrecognizable old airfoil to a good old Clark Y airfoil and plan on a tapered bass/carbon/balsa laminated spar and tapered laminated balsa leading and trailing edges.
The fuse is mostly 1/8 sq. balsa sticks with a few formers to round the top of the fuselage.
Any ideas or info would be greatly appreciated.
Maiden flight. Sorry the video is low quality, we used a digital still camera that has video.
http://www.youtube.com/user/31tudor#p/a/u/0/RfdlRXloCss
http://www.youtube.com/user/31tudor#p/a/u/1/Cak3hra-3gc
O&W
orange&white is offline Find More Posts by orange&white
Old Jun 20, 2010, 08:16 AM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
I think the original C-C kits were designed around rubber power. You cannot simply enlarge the plan to some certain size without checking upon the basic formulae and arrangements.
You plan to get this done this year?
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Jun 20, 2010, 03:12 PM
John38 is offline
Find More Posts by John38
Southampton, UK
Joined May 2007
The CC Mercury is one I fancy building in the future - but scaled up from 24" to 72" for electric.
any reason why you just didn't double everything and go for 48" ??
let us know how you progress
john
John38 is offline Find More Posts by John38
Old Jun 20, 2010, 05:14 PM
Joined Dec 2009
Wm.
I understand what you are saying, I have been using Chuck Cunningham's rc design ideas for years. At the size I am going to use, the enlarged rubber plans structure will be fine for a small electric plane. I hope to start cutting balsa in a few days.
John.
I saw the Merc when you posted the pic, where did you get it?
I used the same picture then converted it to .pdf to be able to scale and tile the plan. It took 643% to get a 45" span.
I plan to use a Esky 400xt and a 10-5 prop and a Rhino 3s 1250mah batt.
The C.C. Mercury has a long fuselage and a short wing and I will probably fly it like a sport plane, barnstorming the local park.
Scott
Old Jun 21, 2010, 12:07 AM
Joined Dec 2009
Here is the plan taped together and pinned on the wall.
The wing is 45" with a 7.5" chord marked at the center.
The fuselage is 34" tip to tail.
Scott
Old Jun 21, 2010, 09:14 AM
Applehoney is online now
Find More Posts by Applehoney
Ajax, Ontario, Canada
A very strong resemblance to the Comet 'Dipper' of 1946. Perhaps influenced by the 'Mercury' ?
Applehoney is online now Find More Posts by Applehoney
Old Jun 22, 2010, 05:55 AM
John38 is offline
Southampton, UK
Joined May 2007
Scott,
I copied the Mercury off an A5 size newsletter.
I have - thru a torturous route ( I am not a draughtsman - managed to get a working plan at 24" span available either as DWG or DXF formats. The standard is not CAD standard but is workable to experienced builders.
both these files are about 4Mbs which I think are too large for here - but I will try anyway.
maybe Planeman could work his magic and convert to PFD - I can only read pfd as I dont have the full program - no need and too many $$$$$$
I could also scale up in the dwg and DXF formats ( I favour 48" for dual role - electric free flight and also RC.)
let me know what you want and I will email direct if the forum upload quality not good enough
john
nope the uppload wont accept dwg or dxf files - so need to email
Old Jun 22, 2010, 05:40 PM
Joined Dec 2009
Hi John.
I know nothing about cad drawing , but I can convert DXF to pdf files.
If you can size the Mercury to 48" as a DXF file, I can convert it and send the files back to you through the thread or to your email.
If Planeman wanted to redraw the Cloud Craft Mercury plan, I couldn't thank him enough. wink...wink...
Scott
31tudor@charter.net
Old Jun 22, 2010, 07:20 PM
Dsegal is offline
Find More Posts by Dsegal
Dave Segal
Philadelphia PA USA
Joined Jun 2001
The AMA Plans Service has the Cloudcraft Mercury plan and can enlarge it for you. It is listed under Mercury.
Dsegal is offline Find More Posts by Dsegal
Old Jun 23, 2010, 03:05 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
These oldtimer planes can be scaled up and still fly very well. Just check out Evan's 16' wingspan Quaker, weighs between 30 and 30 lbs.
http://www.rcgroups.com/forums/showt...ghlight=quaker
Wayne
Windependence is offline Find More Posts by Windependence
Old Jul 06, 2010, 03:18 AM
Joined Dec 2009
Ok I am off....
I cut leading edges from 1/4" medium balsa and the trailing edges and wing tips from 1/8" medium balsa, the ribs are 3/32 balsa. I havent made the spars yet.
Scott
Old Jul 06, 2010, 04:15 AM
r/c junkie is offline
Find More Posts by r/c junkie
TEAM OZSKUNKWORX
r/c junkie's Avatar
KORUMBURRA IN THE BOONDOCS
Joined Jan 2006
Sweet dude looking good mate
Shane
r/c junkie is offline Find More Posts by r/c junkie
Old Jul 06, 2010, 08:26 PM
Joined Dec 2009
I forgot how much work there is building a plane from scratch
Cutting parts, planing parts, sanding parts, making spars, just to get to the building part. You "laser cut" scratch builders have it easy Although it doesn't show, I have been busy for the last few hours making a wing kit.
Old Jul 07, 2010, 01:18 AM
Joined Dec 2009
I know I am a little slow, but one wing half is done
Old Jul 07, 2010, 01:40 AM
TEAM OZSKUNKWORX
r/c junkie's Avatar
Joined Jan 2006
Dont stop now Scott your on a roll.
Shane
Question How to get 2C charge rate on older ProPeak Mercury EX charger Davee1 Batteries and Chargers 6 Jan 13, 2015 04:40 PM
New Product Replikit Mercury Picador vintage1 Control Line 66 Jan 12, 2011 03:11 AM
Discussion Looking for a Mercury runabout kit Beau0090_99 Scale Boats 5 Jun 21, 2010 12:47 PM
Discussion Ford giving Mercury the axe D B Cooper Life, The Universe, and Politics 38 May 29, 2010 05:37 AM
Discussion Cloudcraft Mercury info req'd John38 Vintage & Old-Timer Designs 1 Sep 11, 2008 06:53 AM
