Espritmodel.com Heli Air
Old Sep 02, 2012, 12:08 PM
Joined Jul 2006
thanks, I have read the thread and setup sheets etc, and see them listing 1000 and 3000 associated oil, is this the diff oil, as I cant find shock oil that high number?
all this shock oil numbering confuses the hell out of me
I have a 2nd hand bike with unknwn setup and oil etc, so I figured that I would set it up as per the setup sheet on here, then play and tweak from there, at least hopefully start with something that will work
AC-racing is offline Find More Posts by AC-racing
Old Sep 02, 2012, 12:29 PM
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
No! 1000 and 3000 oils are CST, which seems to be around 50 to 80wt oils, in general... I am using Xray or RB oils, just because it's easy for me to find them at my LHS and also I am using Xray oils in my XRay TC and other vehicles...
There's a chart somewhere, with the relevance of the two measures... (Found it: Post 442, page 30 in this thread!)
steliosh is offline Find More Posts by steliosh
Old Sep 02, 2012, 02:15 PM
Joined Jul 2006
ah ok cool, many thanks, I have much to learn
just started to go over the bike and give it a clean and fiddle with it, blimey theres lots of bits to adjust and play with,
really dont like the steering setup, but will have to wait till I had a chance to try it out, my KP I can turn the front wheel lock to lock and the springs dont even touch the servo linkage, but this SB5 when laid on its side the wheel stays pointed ahead not into the turn like my KP, either its all wrong or its going to be a whole new learning curve
Old Sep 02, 2012, 02:48 PM
Vzzznnnn...
vegos's Avatar
Greece, Attica, Athens
Joined Oct 2010
Another one:
vegos is offline Find More Posts by vegos
Old Sep 05, 2012, 09:24 AM
Joined Jul 2006
thanks, found a few niggly things like stripped threads in the plastic, and a leaky shock, but can deal with that
going to change the steering setup to something more like Im used to with just springs, also on the plans is to ditch the slipper, I run stock class here in the UK, no need for that. also gets rid of that sticky out vulnerable bit, and probably put a chain drive on it, I just prefer them, just currently sourcing the chain as its longer run than any of the normal 70-72 links available, and dont want to just link 2 together, although theres nothign wrong with that I suppose
lots of sideplay in the swingarm/layshaft, read about that on here, so got a selection of shims on the way too
set of roadies on route to me, and looking forward to trying something totally different
Old Sep 11, 2012, 03:36 AM
Joined Jul 2006
ok so its me again, think Im a little alone in the world of SB5 LOL
anyway has anyone had an issue with the screws that hold the rear of the steering servo, and the actual body mounting flange of the servo interfering with the "wishbone" part of the suspension
I was trying to do some static setup and measurements on the bench but couldnt get any sag etc how I wanted it, look down and noticed that the rear of the servo and the screws have been rubbing on the wishbone part and were actually preventing the suspension of dropping down by a good 10mm
as it was it would lift the front wheel off the floor with 38mm from battery tray to floor, now thats 48mm with no servo in there
is this a common fault, has someone maybe built something wrong, cant see what?
Old Sep 11, 2012, 03:53 AM
Gartenzwerg's Avatar
Austria
Joined Jan 2007
Common fault. Take some material away from the wishbone, until the servo case clears it.
Gartenzwerg is offline Find More Posts by Gartenzwerg
Old Sep 11, 2012, 04:01 AM
Joined Jul 2006
ok thanks,
I was ready to do that but thought it best to ask in case I had put something wrong, and being a 2nd hand bike I was unsure of what was done before me anyway
off to find the dremel and remove a tiny bit of material, hopefully this will give the handling boost I was after, no droop on the front was rubbish
Old Sep 11, 2012, 06:09 AM
Joined Jul 2006
oh one thing after another now find that with my Savox servo I cant get much steering movement with the suspension is topped out, the servo horn hits inside the wishbone at full droop, only get about half travel
think its maybe not helped by the slightly offset horn mounting on the low profile serve
back to the slightly less good full size servo and see what its like then.
aha just noticed the height difference from mounting points to the actual servo output shaft, probably 5-6mm different.
will try packing out the height and longer screws
if I pack it out to the right height then theres no chance of it clearing the wishbones GRRRR
need to do some thinking about this one
Old Sep 11, 2012, 07:43 AM
Kungsangen, Stockholm, Sweden
z_dad's Avatar
Sweden, Upplands-Bro Municipality
Joined Dec 2011
If you have the early moldings of the top wishbone, it will not have cutouts for the servo horn clearance as the sparepart version has. This would give you even more problems with an offset placed servoaxle. Cutouts visible at this pic. http://www3.towerhobbies.com/cgi-bin...?&I=LXAMDP&P=7
z_dad is offline Find More Posts by z_dad
Old Sep 11, 2012, 07:53 AM
Joined Jul 2006
aha, yes my top arm is different to that
think I just going to have to buy a new servo, standard size but higher spec, wanted low profile to clear my ESC as its a bit big and will foul on the servo lead of a stock size servo and thats not a good idea
beginning to wish I hadnt noticed it fouling and left it as it was LOL
Old Sep 11, 2012, 08:10 AM
Austria
Joined Jan 2007
I used the Savox 1251, but I mounted it the other way round, and did not use the steering dampers.
..lots of Choices..
Old Sep 11, 2012, 09:44 AM
Joined Jul 2006
thats what I had intended to do, but thought I had got the original system working ok
have now swung it round and mocked up a single sided linkage with springs either side of servo linkage etc, like the KP bikes, feels right, but need to make a servo arm or do something as I cant get the linkage to be dead straight ahead, and get slightly different results left and right for the same amount of servo travel
will either run 2 linkages both with springs behind the links, this should even out the side to side pressure or make a new servo horn to move it all in line
now can use my good servo, and have plenty of room under the servo for my fatty ESC
Old Sep 12, 2012, 04:49 AM
Joined Jul 2006
well after much hassle and stress I found a radio problem, solved it with a capacitor thanks to the power of the internet.
now the bike is stupidly responsive, might try and find a way to tone it down a touch as Im still an amateur at this, but as soon as I can get used to it I expect great things from it
Old Sep 12, 2012, 05:02 AM
Austria
Joined Jan 2007
See if you can reduce the Servo Speed on your radio
That helps a lot, and can be adjusted to suit each track.
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 529 Apr 01, 2013 07:43 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Electric Planes 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
