Old Aug 26, 2010, 08:28 PM
Torrance is offline
Find More Posts by Torrance
Torrance's Avatar
Joined May 2009
Originally Posted by slawsonb View Post
Do you know when the move is supposed to be complete?
last march. who knows when they'll actually complete the move.
Torrance is offline Find More Posts by Torrance
Old Aug 26, 2010, 09:57 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Wow, I thought the red tape at my employer was bad.
Guidoracer is offline Find More Posts by Guidoracer
Old Aug 27, 2010, 07:29 AM
Squidlips is offline
Find More Posts by Squidlips
I once beat Colin McCabe
Squidlips's Avatar
Southport, England
Joined Oct 2005
Hi guys,
We have just had a small delivery of spares from Thunder Tiger.
Any parts that have been pre ordered will go out today
Squidlips is offline Find More Posts by Squidlips
Old Aug 28, 2010, 12:20 AM
Torrance is offline
Torrance's Avatar
Joined May 2009
for those having steering damper problems may want to try these AE o-rings. they're silicone versions for the RC18 shocks which should be dimensionally the same as the SB5 steering dampers. i haven't tried it myself since i don't have any production versions of the SB5 steering dampers. the AE part number is 21332.
Old Aug 31, 2010, 04:58 AM
Roofas is offline
Find More Posts by Roofas
Who needs 4 wheels..
Roofas's Avatar
Australia, VIC, Menzies Creek
Joined Aug 2009
While waiting for this Bike to reach Australia I am going to buy running gear.
Can some please give me the dimension from ESC platform & underside of a low Profile steering servo (Fut BLS 551 was the servo I was thinking of).
*Hoping to be able to use a XERUN esc which has a height of 33mm or the stock XTREME esc which is 31mm
Thanks in advance, Peter
Roofas is offline Find More Posts by Roofas
Old Aug 31, 2010, 05:58 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
I have attached the BLS551 sheet below:
The THING is the Servohorn Axle is about 1,3mm further from the middle than with "normal" Servos.
As far as I recall Torrance designed the Steering bits&bobs with standard Servos in mind like the "in house" AceRC DS1015.
So you should check if the Steering dampers arent too short or the Servo horn doesnt touch the Fork Swingarms throughout the whole travel. Its a bit tight in "there".....
I for my part use the BLS551 (S9551) just with a different steering spring Assembly. Most of the team use low profile Servos (Graupner/JR) but also with different ways to steer the fork.
edi.winter is offline Find More Posts by edi.winter
Old Sep 03, 2010, 06:54 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
Do share....
Akura2 is offline Find More Posts by Akura2
Old Sep 04, 2010, 02:23 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Most of us dont use the steering dampers provided. Then we mount the servo turned 180 so the axle is closer to the steering pivot. And then just use a two spring assembly like just like on any other bike. Its a bit tricky to set up because there isnt much room. You also need to find the right spring hardness.
The hardest tuning spring should work for most, the team uses harder (Fmax=20N) ones I got for them.
I tried the below steering worked quite well for me.
Old Sep 08, 2010, 05:57 PM
brianlt29 is offline
Find More Posts by brianlt29
Redlands, California
Joined Nov 2004
After a couple of tumbles, the screws that hold the rear of the body together that screw into the molded exhaust part pulled thru the body.
Here's a fix/mod that Torrance shared while running on Sunday.
brianlt29 is offline Find More Posts by brianlt29
Old Sep 08, 2010, 10:08 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
This is definitely a needed mod!
Bruce
slawsonb is offline Find More Posts by slawsonb
Old Sep 09, 2010, 02:29 AM
Torrance is offline
Torrance's Avatar
Joined May 2009
i went ahead and added screws to the bottom as well (M2.5 button heads) and got rid of the side screws altogether.
Old Sep 09, 2010, 02:29 PM
Torrance is offline
Torrance's Avatar
Joined May 2009
it has been brought to my attention that the front brake kit doesn't come with any instructions. we prepared an instruction sheet for the brake kit before i left TT but i guess they didn't see it fit to include it in the package.
so anyway here's my feeble attempt at writing some instructions for it.
1. the first picture shows the brake caliper/servo assembly. the servo direction can be set either way but personally i prefer setting it counter-clockwise so that the brake cam pressure is appled towards the trailing edge of the brake disk rotation. in my opinion it should actuate more smoothly way. the gap between brake pad should be around 2.5mm initially. you can adjust more or less to your bike's needs. the servo horn has 3 brake cam sizes - i prefer to use the middle size cam.
2. the second picture shows the exploded view of the front fork assembly. if your bike is already built, you only need to remove the right fork leg to install the brakes. press the rotor pins all the way until it bottoms out.
3. the third picture shows how it should look when assembled. there is a small hole pre-drilled into the right fork leg. use this hole to zip tie the brake servo wire to the fork leg so that it won't rub against the tire. you can be creative as to how to secure the servo connector but for me i like to afix it to the lower suspension arm.
i hope this helps. let me know if you have any questions.
Old Sep 15, 2010, 03:07 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Spektrum 3VC poor range
Hi, I have just bought a Spektrum 2.4 Module for my 3VC Futaba for my SB5, thing is it has very poor range unless I hold transmitter abover my head or get up some where high, I have tried another module and rx and its the same, are they all like this ? and what sort of range should I expect? maybe I should buy the Futaba one, anybody help?
Many thanks
Steve.
steve bisco is offline Find More Posts by steve bisco
Old Sep 15, 2010, 05:26 PM
Guidoracer's Avatar
United States, CA
Joined Nov 2004
steve: Do you have the Rx arial poking out the tail or is it inside the bodywork? And which Spectrum Rx are you using?
Old Sep 16, 2010, 01:47 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Many thanks
Steve.
I dont think this is a TT SB5 specific problem. Must be your radio thats not good. I have a Futaba 3PKs and the reciever antenna has just about 2cm left after it ripped off and I dont have any glitches whatsoever.
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 05:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
