Old May 06, 2012, 03:47 PM
z_dad is offline
Find More Posts by z_dad
Kungsangen, Stockholm, Sweden
z_dad's Avatar
Sweden, Upplands-Bro Municipality
Joined Dec 2011
It feels good to find the cause of a problem and solve it, isn't it?
The tire in the picture still has the molding fuzz left in the middle.
You drive hard.. and stock.
On the other hand, you stated:
"I am running PMT treaded tires (stock rules) and it does it with either used or new ones.
I tried a slick front tire, a slick rear, (always PMT200, from Clark), combinations of all the above...
I even tried the shortest wheelbase positions of the swing arms, but still the same occurs."
How is it, you solved your problem among solutions earlier tested and rejected?
z_dad is offline Find More Posts by z_dad
Old May 06, 2012, 05:45 PM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
I know!
I had tried an old slick, one of my old ones, since Lostallo, or maybe earlier still...
I realized that, after I wrote it... when I got home and serviced the bike... And I have marked all my tires with dates and what inserts are in there, so I can select...
However, I have two sets of slicks glued by Clark, and two sets of treaded, also by Clark.
Today I ran an almost new (comparatively!) Clarks slick and it worked!
Both my treaded fronts are almost the same,, chunks missing... terrible!
The "older" Clark's front slick has started doing the "edge" so I just mounted the newer one...
I did one more change since last time: 3000cps oil and black springs on the front shocks, while before these it was 2000cps (both Xray oils) and red springs (slightly softer -not alot- than blacks).
One thing about rear slicks... they do not SEEM to suffer as much as the treaded ones... however, them being slicks you cannot visibly tell wear, as you can do with treaded ones...
But at least the rear treaded tires are still useable even being almost slicks...
steliosh is offline Find More Posts by steliosh
Old May 06, 2012, 08:26 PM
steve bisco is online now
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Hi steliosh , im glad I just run my bikes around a carpark and have fun with what ever I have you take it to another level
steve bisco is online now Find More Posts by steve bisco
Old May 07, 2012, 01:22 AM
Gartenzwerg is offline
Find More Posts by Gartenzwerg
Gartenzwerg's Avatar
Austria
Joined Jan 2007
The missing chunks on the front tire are usually caused by crashes, or when the tires touches ground after a Headshake. I had this on my NF 509 as well.
Does your SB5 shake it's head a lot, or did you find a setup that keeps this under control?
Gartenzwerg is offline Find More Posts by Gartenzwerg
Old May 07, 2012, 01:51 AM
dragbikebam is offline
Find More Posts by dragbikebam
dragbikebam's Avatar
Memphis, TN USA
Joined Apr 2009
Originally Posted by steliosh View Post
I know!
I wondered about the slick vs tread wear also and concluded that there is less material used in the treaded tire. Treaded is a slick with the rubber grooved out causing faster wear..just a theory of mine though..I guess if I weighed them it would be evidence but have not gone to the trouble
dragbikebam is offline Find More Posts by dragbikebam
Old May 07, 2012, 03:57 AM
edi.winter is offline
Find More Posts by edi.winter
Joined Jul 2009
This is 100% true. The tires have the identical crossection. The treaded tires just have the grooves cut. The tires are about 10-15g lighter up front and 15-20g lighter rear. Thats why they wear faster. I havent run treaded tires since 2009. I also use slicks in the wet.
edi.winter is offline Find More Posts by edi.winter
Old May 07, 2012, 04:14 AM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
Good morning everyone!
@ Bernhard: No, somehow, despite the not-so-good traction of "my" track, I rarely have headshakes... usually it's my fault, really (read: no good use of throttle, or brakes)
I agree with Edi... they are the same, with material missing already from where it's needed...
Anyway, I continue practising with front slicks and we will see...
Old May 07, 2012, 05:27 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
About the threaded tires.
They can be mounted in both directions.
The thread pattern pointing forward like an arrow on top of the wheel, witch seems the most common, and the opposite that's pointing the pattern to the rear.
The "forward" one has the threads working directly across the forces at the contact patch while cornering, thus wiggling the beams.
Mounting the tire reversed makes the forces of cornering work along the beams.
Now, the questions:
Is there a difference in characteristics?
More/less wear?
Heat buildup?
Since steliosh has wear issues and everyone is concerned about the summer heat in Riccone, this may be of interest.
I may also dig too deep in theories (I have a tendency to do that sometimes)
Old May 07, 2012, 11:40 PM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
the wear issues are starting after 20 or so batteries... and also my track has med-lo traction... so I THINK my tires slide a lot...
Old May 08, 2012, 01:38 AM
Austria
Joined Jan 2007
..if I remember correctly, Aaron used one set of threaded PMTs at the last race in Riccione - for all heats in both classes, Stock and Superbike. (He used his Stockbike in the Superbike class)
So if the problems start after 20 batteries, you shouldn't have a problem.
One Set for timed heats (4-5 Batteries?), and one set for the finals (7-8 Batteries if you start from quarter finals, and get into the main finals).
But I do agree, a lot of training might become expensive..
Old May 08, 2012, 01:57 AM
Joined Jul 2009
My personal not so talented experiance about slick vs. treaded.
For pure training I would just use 200s slick. There is a difference
in feel but under the line: if you are fast on slicks you will be fast
on the treaded.
The main cause for the different feel is the front tire. The rear
hardly makes a difference. The front tire has a weird crosssection:
first it has contact on the middle stripe, leaning into a turn it then
"falls" into the groove giving the bike that weird feel.
Driving slicks will give you a bit more laps. Now and then you can
use a treaded front tire just to be "up to date". But for brainless
traininglaps or fundriving I would just put on 200 Slicks and forget
about ruining your "grooves"
Old May 08, 2012, 11:35 AM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
I agree with Edi, and I just run my slicks (of any age!) fronts...
I will get two sets of new treaded tires (Clark's probably!) for the Warm Up, and then two more for the Worlds, as Bernhard said...
In the meantime, it will be only slicks...
And to be honest, me being mid pack as a driver (or lower... Yes, I know what I can do with the bike!) I cannot feel a lot of difference between the two types of tires, except for this: When the treaded front warms up, at around 4-5 minute, it starts "wobbling" or doing the "fold" trick!
I cannot see any difference of behaviour with the slicks, throughout a whole 10 or 12 minute session...
Also, I cannot see any difference on the rear... I "feel" it works the same, be it slick or treaded...
I also believe (but it will have to prove itself, this one, in two weeks) that in high traction tracks the wear is LESS than tracks with not so good traction, where the tires have to work "harder" to find traction... But then again, as I said, I m not a top-10 driver. OK, if there are 10 drivers, I AM a top-10!!!!
At Riccione in October i was 6th out of 9, but at the Worlds I was in the lower half of the results....
Old May 08, 2012, 12:07 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
I still find the PMT 200 slicks amazing. Even after a set has been sitting unused for months, all it takes is a wipedown with full-strength Simple Green then a couple of hard laps on the track to get all the dead rubber off. Or, if you are so inclined, an apply-and-dry of proper traction compound then wipe them off well, and they are back up to near full traction.
As for the cut slicks, I can echo Edi's and Stelios' experiences -- they look pretty, but wear at a much faster rate, especially on the edges, where the "meat" is needed the most. And the few times I've run in the wet (we don't do that here -- rain in SoCal?), the full slicks gripped amazingly well.
Guidoracer is offline Find More Posts by Guidoracer
Clark Wohlert is offline
Find More Posts by Clark Wohlert
Clark Wohlert's Avatar
Joined Jan 2012
@steliosh,
Your tyres have been sent today. Run them in carefully without picking up any dust for about 5 minutes. Clean them with water (never use brake cleaner) and put them aside until the pre worlds.
Be aware the fact that they will not perform well for the first fiew minutes in riccione. Tyres are somehow living rubber. They need to adopt the surface you run them on.
Running them in carefully will gain livetime of the front tyre dramaticly.
Clark Wohlert is offline Find More Posts by Clark Wohlert
Old May 08, 2012, 01:17 PM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
Thanks, Clark. I will do this carefully.
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 05:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
