Old Apr 21, 2012, 02:16 AM
tomandjan is offline
Find More Posts by tomandjan
Joined Aug 2011
thanks for the help i'll get some oils and try .o and yer very shocking the power of the thing was amazing with the ripper motor just need to find a place big enough to open it up more than a second lol
tomandjan is offline Find More Posts by tomandjan
Old Apr 24, 2012, 04:32 AM
Raymond.O is offline
Find More Posts by Raymond.O
Sweden
Joined Aug 2011
The rtr scratchbars angle and position are not the same as on the probike.You need to bend the scratchbars if you want it to be faster in the corners.
Raymond.O is offline Find More Posts by Raymond.O
Old Apr 25, 2012, 03:23 PM
z_dad is offline
Find More Posts by z_dad
Kungsangen, Stockholm, Sweden
z_dad's Avatar
Sweden, Upplands-Bro Municipality
Joined Dec 2011
Assymetric steering input reaction
I have managed a few fantastic practice sessions and everything seems to be working fine but yesterday my bike seemed to be slower to shift from right to left, than to the opposite.
When I go left and change direction to the right, the bike is very quick to shift both lean and direction, even slamming the bars. When I do the opposite, right to left, it feels slow and unwilling to react to steering input. The problem gets bigger the faster I go. When the bike is in the turn, leaning, everything is good. It's just the reaction to steering input that seems to be affected.
I run my bike very close to original with 4900kv, a bit raked up fork (1 ZH leg), fork travel restrictors, lightscale brake disc, stock steering springs, only 1 damper filled(stock 600 oil), PMT 200's (massari inserts), 3000/1000 shock oil setup, stock springs, fairly high leaning angle and a homemade belt brace (The rear wheel sits straight as an arrow and no bending or beltskipping).
Nothing seems broken or otherwise wrong, though I haven't performed a detailed inspection yet.
My first thoughts concerned the steering springs, or the single damper being overfilled but it seems ok. It was suggested that I should replace the steering bearings (I know they are due for change but haven't come around to do it yet).
The servo is bluebird low profile and is ok as far as I can tell.
What's my problem?
Are there any theories out there?
z_dad is offline Find More Posts by z_dad
Old Apr 25, 2012, 04:10 PM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
Radio settings has been the problem down here. Even though some folks Know their radio inside and out, it always seems that when they try to change something they end up going to the wrong setting on the radio and changing the wrong thing thinking its the right thing. Lol, thats all i got for you.
621clay is offline Find More Posts by 621clay
Old Apr 25, 2012, 05:05 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
Thanks, I'll look into that. Have to rule everythig out.
Old Apr 26, 2012, 12:50 AM
Gartenzwerg is offline
Find More Posts by Gartenzwerg
Gartenzwerg's Avatar
Austria
Joined Jan 2007
That would be the first thing to check, in my opinion.
I only know that problem from my cross-bikes or the GPV-1. It happens when the fork legs are "twisted".
This should not be possible on an SB-5, but maybe it's worth a try to inspect the fork legs, and rebuild the forks?
Gartenzwerg is offline Find More Posts by Gartenzwerg
Old Apr 26, 2012, 05:28 AM
Bastelpeter is offline
Find More Posts by Bastelpeter
Bastelpeter's Avatar
Germany, RP, Nierstein
Joined Jun 2011
...maybe one of the steering springs collabsed and is too short / too soft now
Bastelpeter is offline Find More Posts by Bastelpeter
Old Apr 26, 2012, 03:03 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
Thanks guys, I'm making a checklist.
Old Apr 26, 2012, 04:03 PM
rskip is offline
Find More Posts by rskip
Joined Jun 2006
Check your end points on the servo - the servo horn should be symmetrical about the centerline at full throw in both directions. When adjusting the radio - I personaaly prefer to set the epa fixed on both sides and set the trim at 0. I then use the subtrim to center - that way I always have equal servo travel from center. The traditional way of setting your epa and using trim - will usually give more steering in one direction because you set the EPA before the trim and the end points do not adjust with it. This can be a big issue if your center is way off to start out.
Also check for any bInding or interference in the steering ( body, suspension swingarms, etc).
-rskip
rskip is offline Find More Posts by rskip
Old May 01, 2012, 12:02 PM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
A strange problem occurs to me lately!
The traction of the track is very good lately, so I am trying shorter and shorter crashbars (along with Clark's Lightscale longest wheelbase settings).
When I mount very short crashbars, my times go down, (happy me!) but the front wheel tucks inside during the exit of fast corners, leading the bike to the inside of the corner, usually ending in the grass...
I am running PMT treaded tires (stock rules) and it does it with either used or new ones.
I tried a slick front tire, a slick rear, (always PMT200, from Clark), combinations of all the above...
I even tried the shortest wheelbase positions of the swing arms, but still the same occurs.
The only solution seems to be 5mm longer crashbars, and the fenomenon disappears!
And then my times refuse to go below 24.14!!!!!! haha!
The bike has no problem turning right or left, and this occurs on both types of turns... usually very fast turns, like the end of the main straight which leads to a long uphill...
then on the other side, going downhill, letting go of the throttle, no brakes usually, when I push the throttle mid turn towards the exit, it will do it most of the times...
Any insight would be helpful...
Oh... I am running middle position crashbars...
And those +5mm crashbars that "work", are maybe 5mm shorter than what I used in Riccione in October...
steliosh is offline Find More Posts by steliosh
Old May 01, 2012, 04:47 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
Hi Steliosh, I wonder. Do you use mechanical restricors for the fork movement?
If not, my guess is:
The longer wheelbase from the lightscale kit moves the CG forward. That puts a lot more push to the front in high speed turns. A high lean angle might make the fork come very close to a point where it actually folds into itself (You may have experienced this on a regular bicycle if you fall down and the handlebars tries to knock your teeth out as the front wheel folds.). With all that weight on the front and a completely crossed up fork, the bike may not recover from a slip or a bump (as seems to be your problem). Steering restrictors on the fork may help you recover better, as the fork does not travel so far from the effective angle.
My experince (limited) is that you need surprisingly small turning angles for the fork, to still make sharp turns.
I just had this thought and decided to share it before thinking too much.
It may also be completely wrong
Hope it helps
Micke
Old May 04, 2012, 05:25 AM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
It certainly makes sense, z_dad!
And, no, I do not run any restrictions on the forks, although I have turned down the ATL of the steering channel to about halfway, each side, after carefully finding the center with the subtrim.
I reverted to slightly longer scratchbars and the situation disappeared... anyway my track is not super on traction and it's quite bumpy at places...
Thanks for the input!
Old May 05, 2012, 06:39 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
Assymetric steering response
Hi guys, thanks for the input on this issue, it has helped me in concentrating on the proper area.
I just finished checking, adjusting and testing.
I changed the steering bearings, they were shot, though not the main issue.
As I tested the steering spring tension, I discovered that the power of the springs, at the endpoint of servo travel, were different left from right allthough everything looked symmetrical and straight.
Something in my (cheap) Radio system made the fork do different movement depending on direction. After dialling the transmitter to make the fork movement equal, the problem disappeared. An additional source of trouble detected was the brake servo cable. It COULD get tangled in the steering restrictors due to routing (cured now). There is still sluggish response in high speed but I will be trying harder springs, hope to be fast soon.
Old May 05, 2012, 07:24 PM
z_dad is offline
z_dad's Avatar
Joined Dec 2011
Turning down the ATL does limit the movement caused by the steering input, but it's not helping if the bike dynamics is pushing your fork to its mechanichal endpiont, only mechanical restriction can do that.
Still, I admit, there is nothing that says this is your problem.
Anyway, this is a simple and cheap mod that is reverseble just as easy:
There are two 2.5mm threaded holes in your lower fork triple. You can use these, or rethread them 3mm.
Put 20mm screws fully through the holes from the bottom on both sides and threadlock them there. Use a plastic nut or similar on the tip of the protruding end of the screw. This nut will touch the steering stem to restrict the fork movement.
Differnt size, different angle.
Yes, they will bend with a lot of force but it's an indicator as if you're adressing the correct parameter. If you don't like it you can just remove these screws again.
I believe this helps me keeping high leaning angle in "notsoperfect" grip conditions.
Old May 06, 2012, 12:24 PM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
Looks like my problem is simple as this:
The track I am running has med to min traction, so the tires have to work REALLY hard to compensate...
The rear becomes a slick after about 20 batteries (20 ten-minute sessions) and the front after about 30 batteries sees chinks coming off!
I mounted a used (20-30 batteries) PMT200 slick front and suddenly I could do consistent 24-low lap times (struggled to do 25-low's with the used cut slick) and the fenomenon disappeared completely!
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 05:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
