Old Jul 25, 2010, 05:55 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Ok, guess I been brought up on Kyosho and Tamiya kits, where everything just goes togther perfect, just wish Kyosho would bring out a new bike.
steve bisco is offline Find More Posts by steve bisco
Old Jul 25, 2010, 06:15 PM
HASSE.D is offline
Find More Posts by HASSE.D
sweden
And about the stock tires,i didnt bother to try them i just bought a set of pmt 200.Yes,we shouldnt need to do that kind of work on it.
HASSE.D is offline Find More Posts by HASSE.D
Old Jul 25, 2010, 06:24 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
Originally Posted by Torrance View Post
i'm not surprised with the poor machine parts quality. big portion of why i left TT.
for the steering damper you can use the Associated 1:18 scale rear dampers bodies. they're identical in bore and length. just use the SB5 steering damper shafts and TT shock cap bladder with the AE shock body set. i think now the AE dampers come with red silicone o-rings instead of the black rubber ones. if you switch to these make sure it has the red o-rings. also make sure it's the REAR AE damper bodies (fronts won't work).
Since Thunder Tiger owns Associated and makes all their stuff in the TT factories, I would have thought the quality would be similar.
slawsonb is offline Find More Posts by slawsonb
Old Jul 26, 2010, 02:41 AM
DLAWW is offline
Find More Posts by DLAWW
DLAWW
DLAWW's Avatar
United States, CA, Gardena
Joined Dec 2005
I went to work on the dampeners today and I believe I've got much better performance out of the steering dampeners. All I did was take the stock TT dampener spring and cut it, not in half but at least three quarters of its entire length. Then put on the shaft on the inside of both dampener, added 35 ae oil. This worked wonders on the controllability of the steering. Adjusted the steering trim a bit and the bike also stayed down while turning the way I like it. Maybe 35ae is to much so I'll keep working at it to find the best oil wt for this setup.
DLAWW is offline Find More Posts by DLAWW
Old Jul 27, 2010, 11:54 AM
Pescarolo is offline
Find More Posts by Pescarolo
Barcelona (Spain)
Joined Jun 2008
I teach what I've Adapted pa the direction of my SB, herd of original shocks apart from being very thin are also unreliable, since I broke an axle, so I opted for these larger, smooth operation, and resistant ...
Failure to test how it goes on track.
Pescarolo is offline Find More Posts by Pescarolo
Old Jul 28, 2010, 10:30 AM
iansu is offline
Find More Posts by iansu
iansu's Avatar
Joined Jan 2009
Delete
iansu is offline Find More Posts by iansu
Old Jul 28, 2010, 11:45 AM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Nice adapter! Is it going to be available to the public?
Guidoracer is offline Find More Posts by Guidoracer
Old Jul 28, 2010, 01:06 PM
Skywalker21 is offline
Find More Posts by Skywalker21
Joined May 2010
Hello
Two French pilots are being developed with the rear wheels Beadlock system for sb-5. They are also developing the project for the front. End glue to glue the tires. Apparently it will be compatible any brand. They should be visible to the World in Grenoble.
Skywalker21 is offline Find More Posts by Skywalker21
Old Jul 28, 2010, 08:03 PM
iansu is offline
iansu's Avatar
Joined Jan 2009
Delete
Old Jul 29, 2010, 01:44 AM
edi.winter is offline
Find More Posts by edi.winter
Joined Jul 2009
Check out the Thunder Tiger Team Bikes.... they are using the special carbon wheelset I originally designed for my bike. The hubs are made of 7075 aluminum, the spokes are made of Carbon. They are a direct replacement for the plastic spokes. The front brake of the SB5 fits too (but better ;-)..... I designed these because I was running out of SB5 prototype spokes in March...
If there are a few orders I could make a few sets after the worlds.
edi.winter is offline Find More Posts by edi.winter
Old Jul 29, 2010, 11:21 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
WIth wheels like that I would probably attach the brake rotor to the rim and put the caliper on the inside like the Buell ZTL system, just to be different.
village_idiot is offline Find More Posts by village_idiot
Old Jul 30, 2010, 09:54 AM
iansu is offline
iansu's Avatar
Joined Jan 2009
Delete
Old Jul 30, 2010, 03:36 PM
Guidoracer's Avatar
United States, CA
Joined Nov 2004
They look like -mp's Motoproto V2 wheels.
Old Jul 30, 2010, 05:36 PM
canvey island
Joined Jul 2002
Dont Thunder Tiger do an alloy option spoke wheel centre
Old Jul 30, 2010, 06:16 PM
HASSE.D is offline
sweden
yes,and i think formbys would have them instock soon?
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 05:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
