Old Feb 24, 2011, 08:34 PM
casper43 is offline
Find More Posts by casper43
Chris
casper43's Avatar
brisbane north
Joined Feb 2011
No aussie suppliers ?
casper43 is offline Find More Posts by casper43
Old Feb 24, 2011, 08:40 PM
choook is offline
Find More Posts by choook
Australia, VIC, Melbourne
Joined Feb 2011
not sure i get my stuff of him hes got lots of stuff and cheap 100 $23 ea 200 $25 ea $14 post to vic
choook is offline Find More Posts by choook
Old Feb 24, 2011, 08:45 PM
casper43 is offline
Chris
casper43's Avatar
brisbane north
Joined Feb 2011
ordering now the site recommends using nuova faor inserts, but out of stock is there some in the kit that are suitable or an alternative
Old Feb 24, 2011, 10:07 PM
Roofas is offline
Find More Posts by Roofas
Who needs 4 wheels..
Roofas's Avatar
Australia, VIC, Menzies Creek
Joined Aug 2009
You can use the inserts supplied with the kit, they work fine for me.
Roofas is offline Find More Posts by Roofas
Old Feb 25, 2011, 09:11 AM
Tüsken is offline
Find More Posts by Tüsken
Tüsken's Avatar
Sverige, Västra Götalands Län, Lidköping
Joined Jan 2010
Originally Posted by Appel82 View Post
Edi, did you get the diskspacet" to work ??
Is there more people how try your prototype spacer?
This plastic is real good and strong it's hard to work with
If there is anyone ho can pm me how I can get the spacer to work with stock brakecaliber
You got PM Appel82.
Tüsken is offline Find More Posts by Tüsken
Old Feb 25, 2011, 07:27 PM
rcmotogp is offline
Find More Posts by rcmotogp
rcmotogp's Avatar
Joined Feb 2011
G2 Ride
Does the G2 ride motor bolt straight in the SB5 or does it require an adator plate? If it requires an adaptor does it come in the esc/motor combo kit?
rcmotogp is offline Find More Posts by rcmotogp
Old Feb 26, 2011, 02:01 AM
ado1974 is offline
Find More Posts by ado1974
ado1974's Avatar
melbourne, australia
Joined Jun 2009
took sb5 out today for its third battery
bike was good... driving was
have to sort a handling issue.
at constant speed it leans quicker to the right than it does to the left.
i tried playing with wheel alignment. but it had very little effect.
i will check the springs and dampers for binding or different rates.
the only other thing i could think of that would effect it is balance(heavier on the right side??
or a twisted chassis.. will check that as well
any other sugestions??
cheers
a
ado1974 is offline Find More Posts by ado1974
Old Feb 26, 2011, 02:36 AM
scaulfi is offline
Find More Posts by scaulfi
Big thrills w/o hospital bills
scaulfi's Avatar
Brisbane, Australia
Joined Sep 2003
Hi, I don't know if the G2 will fit the sb5 but, I know the G2 doesn't come with any sort of adaptor plate. Just comes with the motor/esc, wires and capacitor.
scaulfi is offline Find More Posts by scaulfi
Old Feb 26, 2011, 06:21 AM
Squidlips is offline
Find More Posts by Squidlips
I once beat Colin McCabe
Squidlips's Avatar
Southport, England
Joined Oct 2005
The Mtroniks G2 motor usually comes with a 540 adaptor plate needed to fit the likes of the SB-5 and most other bikes.
Squidlips is offline Find More Posts by Squidlips
Old Feb 26, 2011, 06:24 AM
Squidlips's Avatar
Southport, England
Joined Oct 2005
cheers
a
Have you swapped the o rings in the steering dampers for better ones?
The standard ones (read rubbish!) tend to make for uneven steering as they drag and don't hold oil in the damper.
I have Associated RC18T silicone o rings in mine and it made a huge difference!
Hopefully this would sort the problem
Old Feb 26, 2011, 07:15 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
cheers
a
What you want to check is already very close: If nothing of that helps:
check the steeringservo adjustments on the radio, maybe something there isnt set up properly.
edi.winter is offline Find More Posts by edi.winter
Old Feb 26, 2011, 09:33 AM
Gaz65 is offline
Find More Posts by Gaz65
northants uk
Joined Jan 2011
Originally Posted by edi.winter View Post
Au contraire, the Prototype didnt have that option.
Its for three different Crashbar Assembly options.
See Pictures.
What difference does these positions make to the bike?
Gaz65 is offline Find More Posts by Gaz65
Old Feb 26, 2011, 11:43 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
The further back the less weight is on the rear wheel when the bike lays on the crashbars. Try starting off with the forward most Position (1).
Old Feb 26, 2011, 12:39 PM
Gaz65 is offline
northants uk
Joined Jan 2011
Thanks Edi
Have my bike set up in the middle postion,but just bought another with brushless etc and brake but that ones set up in the front position(1) and just wondered what the difference was.
Old Feb 26, 2011, 07:19 PM
ado1974 is offline
ado1974's Avatar
Joined Jun 2009
squidlips/edi
thanks for the assist
still running stock sb5 orings.
i am not running any oil in the dampers, and i have made sure the orings are lubed so they slide ok.
balance is ok...not perfect, but not much i can do about that
chassis is as straight as i can measure. wheel alignment within 1mm at the front axle, and cant detect any twist
radio(i think you were right edi)
i discovered the futaba 3gr Tx has a trm-st and sbt-st function in the displayed menus.(i thought it only had sbt-st)
i think i may have got the two confused while changing the setup
this would have meant the servo was centered using the normal trim function instead of subtrim.
a little info for those that didnt know the difference.
normal trim will change the centered(neutral) point between the endpoints of the servo horn rotation.
if the servo is trimmed to the left. it will have less rotation to the left than the right, as the endpoints have not moved.
subtrim will move the entire range of the servo.... endpoints included
if the servo is trimmed to the left using subtrim. the rotation left and right from the centered(neutral) point will remain the same
hope this helps someone at some point
cheers
a
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 06:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 07:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 06:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 12:15 PM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 10:52 AM
