Old Jan 08, 2011, 09:15 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
Here you can find a few bits I made for the SB5.
Headstock: considerably lighter than the Original.
Rear Swingarm that should be stiffer than the Original Kit thingy.
Keep in mind that those parts are PROTOTYPES!
edi.winter is offline Find More Posts by edi.winter
Old Jan 08, 2011, 04:34 PM
ado1974 is offline
Find More Posts by ado1974
ado1974's Avatar
melbourne, australia
Joined Jun 2009
nice work edi
you are liking the shapeways site??
the rear swingarm box.
you have it marked as making the rear of bike 5mm higher.
should this be used with the longer front forks??or does the bike need to sit higher in the rear?
cheers
a
p.s.
my sb5 should arrive next week
ado1974 is offline Find More Posts by ado1974
Old Jan 09, 2011, 06:00 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
The 5mm higher Rear was a wish from Mr.Zonzini. He said that the bike will turn better when its higher. It hasnt been tested yet we will see.
I will be bringing on further parts in the future and they might be making previous bits obsolete. But "HEY" all of you can try prototype parts, no risk no fun.....
One thing I am working on is a improved front brake assembly with the option to flip it Left/Right. But I am waiting for the servohorn made of Stainless because I dont know about the qualitiy of the parts. Once thats okay I will release the parts.
Old Jan 09, 2011, 06:40 AM
ado1974 is offline
ado1974's Avatar
Joined Jun 2009
edi
if you are talking about the printed stainless, i doubt it will be good enough.
it will require machining on virtually all working surfaces, the finish will be almost like a polished sand casting.
cheers
a
Old Jan 09, 2011, 06:45 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Ah okay. Sounds crappy.
But still thanks for the Tip once more. Hope this works out for everybody.
Old Jan 09, 2011, 03:36 PM
ado1974 is offline
ado1974's Avatar
Joined Jun 2009
edi
the stainless does machine nicely though.
i have made a couple of parts with it.
but like i said. treat it like you are getting a casting made, unless dimensions and surface finish arent critical
i havent done any destructive testing on it yet, but it machines a little easier than normal stainless, but much harder than the bronze that it is infused with.
wil take some pictures of other parts i have made previously and send them to you
cheers
a
Old Jan 12, 2011, 04:42 AM
SUMO13 is offline
Find More Posts by SUMO13
SUMO13's Avatar
Joined Feb 2005
Hi Edi,
is the swingarm box already for sale ???
A friend of mine works with a laser and is able to do alot of different metalls like staintless or alloy , maybe i can help somehow ?
Arnim
SUMO13 is offline Find More Posts by SUMO13
Old Jan 12, 2011, 05:15 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Whereabouts are you?
Old Jan 13, 2011, 04:14 AM
SUMO13 is offline
SUMO13's Avatar
Joined Feb 2005
Aye Edi,
im from the North of Germany , so global we are not so far from each other . i have been at the worlds in Leipzig , sittn next to The Danish crew and Patrik and Stubbie from Cal.
Old Jan 17, 2011, 09:19 AM
stubbyphilips is offline
Find More Posts by stubbyphilips
I'm hooked on RC Moto
stubbyphilips's Avatar
Berkeley
Joined Jun 2006
Originally Posted by SUMO13 View Post
Aye Edi,
Hey Arnim,
How are you?
stubbyphilips is offline Find More Posts by stubbyphilips
Old Jan 18, 2011, 12:35 AM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Hey guys... I've just finished assembling my SB5, and now sorting out the electronics. Problem I've ran into now is the brake servo, I know it's been mentioned here before, but I was hoping that there was another option for a replacement, other than the Sanwa unit... Being Australia there isn't always a large variety of parts around...
Anyway... My servo lasted about 30 seconds running with the digital steering...
Lukey B is offline Find More Posts by Lukey B
Old Jan 18, 2011, 01:22 AM
Roofas is offline
Find More Posts by Roofas
Who needs 4 wheels..
Roofas's Avatar
Australia, VIC, Menzies Creek
Joined Aug 2009
I believe the Futaba S3156 servo will fit.
Roofas is offline Find More Posts by Roofas
Old Jan 18, 2011, 02:23 AM
Lukey B is offline
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Thank you Peter... I just looked that servo up, and yes it seems it should fit in there... Thanks again...
Old Jan 19, 2011, 03:45 PM
ado1974 is offline
ado1974's Avatar
Joined Jun 2009
my dive into rc motorcycling has trully begun
the sb5 arrived on monday.
i have fitted a futaba bls551 servo.
issues with the steering.
i had to mount the servo with no spacers under it.
it required a couple of mm to lift it to the recomended 17mm in the instruction manual.
but there is not enough clearance for the servo mount or the heads of the cap screws to pass the pivot of the lower suspension arm.
with the servo flush it has about 0.005"
with the servo mounted flush the steering damper/spring assemblies foul on the front pivot of the upper suspension arm.
so i have mounted the dampers above the servo horn.... this isnt ideal geometry but should still give a nice consistant action.
and finally
the damper assemblies actually rub on the inside of the upper suspension arm(both sides), i will be removing the mould line and maybe a little material to give it minimum clearance
cheers
a
Old Jan 19, 2011, 04:51 PM
Roofas is offline
Roofas's Avatar
Joined Aug 2009
Got mine (steering shocker) under the servo arm no problem, you tried it under ?
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 06:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 07:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 06:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 12:15 PM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 10:52 AM
