Old Dec 20, 2010, 03:56 AM
edi.winter is offline
Find More Posts by edi.winter
Joined Jul 2009
Well THATS a wall full of money, all I have to show are used tires and my bikes.
edi.winter is offline Find More Posts by edi.winter
Old Dec 20, 2010, 04:05 AM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
It's not exactly that, since I own these vehicles from new! My first ever was the Marui LC, bought as a kit in 1987!!!
They are worthless in money-terms, most are used and abused, but their sentimental value is priceless to me!!!!
Mind you, not all of the vehicles are runners... Only 5-7 of them are...
End off off-topic!!!
steliosh is offline Find More Posts by steliosh
Old Dec 20, 2010, 10:56 AM
stubbyphilips is offline
Find More Posts by stubbyphilips
I'm hooked on RC Moto
stubbyphilips's Avatar
Berkeley
Joined Jun 2006
That is a very nice display Steliosh.
You have good organizational skills...
stubbyphilips is offline Find More Posts by stubbyphilips
Old Dec 23, 2010, 03:02 PM
steve croston is offline
Find More Posts by steve croston
steve croston's Avatar
United Kingdom, England, Preston
Joined Nov 2009
Can someone help me out ?
ez 10 turn motor
lipo
mtroniks g2 esc
futaba 3cvs
When Ive finished fitting the brake I tried it out and I have found the front brake survo gets really hot. I have tried turning down the brakes on the esc and this has not helped I have already burnt 1 survo trying to sort this out.
steve croston is offline Find More Posts by steve croston
Old Dec 23, 2010, 06:40 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
I burned out my stock brake servo in less than a week. It's been replaced by an Airtronics (Sanwa) 94091, which has worked well since. In fact, the Air servo was so cheap, I picked up a spare to keep in the pit box.
Guidoracer is offline Find More Posts by Guidoracer
Old Dec 23, 2010, 09:37 PM
DLAWW is offline
Find More Posts by DLAWW
DLAWW
DLAWW's Avatar
United States, CA, Gardena
Joined Dec 2005
Lito what servo horn is that on the SB brake kit, that does not look like the one I recieved.
DLAWW is offline Find More Posts by DLAWW
Old Dec 23, 2010, 10:18 PM
Guidoracer's Avatar
United States, CA
Joined Nov 2004
That is the servo horn that came with the Airtronics servo.
That horn had six lobes originally; I just cut off three of them.
Old Dec 24, 2010, 02:37 AM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
Some minor questions to those who are already built and ran their SB-5's...
I'm currently doing the bodywork... There are two body posts that would require drilling the rider's knees to pass trough. Are these of any use, or you can leave his knees undrilled and let the bodyposts just support the knees in case of a crash?
I guess if I drill these and use r-clips, these will be the first to get lost!!! Right?!
Another one... I tried mounting my Xerun 120A speedo in there and it's JUST 2mm wider than the space available. So, it has to seat itself at the front of the tray. However, when the bike is in the air, front suspension extended, the steering servo wires kink against the speedo fan... The servo is a "normal" sized DS1015. Maybe a low profile Savox 1251 (is that right?) would cure this? I'd hate to have to buy another ESC, right now!!!!
I'm going sensored with the 5.5T and a 6.5T motors I use in my TC... Also, in case of going stock 17.5T I will again have to go sensored, so the Genesis Ride/5700kv sensorless is out of the question for now...
(I have two of these, one in my Firestorm, in a desperate attempt to try and race my son's Flux equipped EFS (!) and another one in my Anderson M5 cross... I guess the EFS's one would get out, the Anderson is more... fun! I might try to swap electronics, of course, and use the Xerun/6.5T in the EFS... decisions-decisions!!!)
And then, there's the question of where to hang the capacitors! Both the Xerun and the Genesis ride have big capacitors not mounted on the ESC!
While looking at the bike without ESC and motor, space seems as big as a touring car's, then when trying to squeeze all those cables, suddenly space it at a premium!!!!
One more... now that I look at the bike... Is the supplied crash bar rod sturdy enough for a start, or should I get me some white one?
(Waiting for PMT tires, now from Formby, so the bike will NOT run, not even next week, I presume, being this time of year, the mail services will go to snail pace!)
Old Dec 24, 2010, 04:51 AM
HASSE.D is offline
Find More Posts by HASSE.D
sweden
Merry christmas steliosh.Just drill out for the bodyposts.I had no problems with the bodyposts or the r-clips.Im using the mtroniks g2 speedo and its also abit tight to mount,when using a standard size servo.Im using the sav÷x mg1251.I have my capacitor in front of the speedo.Check also the ride hight both front and rear.40-43 front and 48-50 rear.And i also limitated the drop by installing 2 small o-rings in the front shocks under the pistons.Try this mod before you get another servo.It might work.And the crash bars are ok.
HASSE.D is offline Find More Posts by HASSE.D
Old Dec 24, 2010, 07:24 AM
gnilre is offline
Find More Posts by gnilre
Copenhagen, Danmark
Joined Dec 2009
Hallo Stelios. You might reposition the bodyposts. Lower by some 20mm, and 22mm to the fore, giving a distance between them some 32 mm, and shorten them some 10mm!
This way the body is a bit easier to pul off or up whichesever you call it.
It is drivers hands which wears out first trom crashes!!
Happy Cristmas and New Year from Erling.
gnilre is offline Find More Posts by gnilre
Old Dec 24, 2010, 07:25 AM
Joined Jul 2009
ez 10 turn motor
lipo
mtroniks g2 esc
futaba 3cvs
Buy a other servo, the stock one is rubbish.
Old Dec 24, 2010, 08:37 AM
Joined Nov 2009
hi edi which servo do you use?
Old Dec 24, 2010, 03:57 PM
Torrance is offline
Find More Posts by Torrance
Torrance's Avatar
Joined May 2009
the TT micro servo has some compatibility issues with some 2.4G radios. sometimes it vibrates at a high frequency which causes it to get hot even when it's just turned on without even applying the brakes. this happens more with the metal gear version. since it's not a digital servo it can't handle the fast settings on some radios that were made for digitals. if your radio has an option for a slower frequency then this could cure the problem. on my bike i use the plastic gear version of the servo with a Spektrum radio system and haven't had any troubles. i've had the same servo installed since Leipzig last year.
i told TT to find a solution for the micro servos before i left them. their electrical engineers have found the solution but whether the factory implemented them or not i don't know.
Torrance is offline Find More Posts by Torrance
Old Dec 24, 2010, 03:59 PM
Torrance is offline
Torrance's Avatar
Joined May 2009
wow! the great Erling has one of my bikes... i'm truly honored.
Old Dec 25, 2010, 12:09 AM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
I've met Erling at the Worlds and we had a fascinating conversation on bikes and rc bikes!
Thanks for the advice Erling!
And Merry Christmas to you too!
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 05:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
