Old Jun 19, 2010, 04:53 AM
SUMO13 is offline
Find More Posts by SUMO13
SUMO13's Avatar
Joined Feb 2005
New Product
SB 5 TT / Tips Tricks Troubleshooting
HI ,
like EDDI sugested , a new Thread for sharering experiences .
Yesterday i found out ,assembling the bike , that the main Shaft (swingarm Drivetrain ) has way too much play, needs to be shimmed .
@ Torrence ,
can You tell us something about the rubber of Kit Tyres ?
compareable to 100, or 200 PMTs ?
SUMO13 is offline Find More Posts by SUMO13
Old Jun 19, 2010, 07:35 AM
SergeL is offline
Find More Posts by SergeL
Belgium
Joined Jun 2010
I'm planning to use a 6.5 T brushless motor on the stock spur (87T). Which pinion is recommended.
SergeL is offline Find More Posts by SergeL
Old Jun 20, 2010, 04:28 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
Gear Ratio Table
Heres a Sheet with the possible Gear Ratio and Rollout for the Thunder Tiger SB5.
Gearing: How often does the Motor Pinion Turn when I turn the Rear Wheel one revolution (360).
Rollout: How far does the bike move if I turn the motor Pinion one revolution. (thats 1:12 Pan-Style)
These two parameters give the best comparison to other bikes.
And usually the motors have these Ratios in the manual but mainly for cars.
I found the 2WD Off Road recommendations usually work for 1:5th Bikes...
But dont give me hell if that doesnt work for you....
For example:
On the JABBER I drive a 9TDelta with 104T/24T => (11,9:1)
So in the SB5 I need approx. 93T/19T
or
Jabber: 13.5T GM, 92T/31T is the same as 87T/27T for the SB5...
edi.winter is offline Find More Posts by edi.winter
Old Jun 20, 2010, 11:55 PM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
A rough speed calculator. Not that you need it to tell you the speed, but the gearing suitable...
http://scriptasylum.com/rc_speed/_top_speed.html
steliosh is offline Find More Posts by steliosh
Old Jun 24, 2010, 12:09 AM
mp- is offline
mp-
Find More Posts by mp-
mp-
Napa, California
Joined Jan 2004
What is the recommended silicone oil weight for:
front dampers?
rear dampers?
steering dampers?
mp-
mp- is offline Find More Posts by mp-
Old Jun 24, 2010, 01:20 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
front: Asso 3000wt
rear: Asso 1000wt
steering: only fill one with 20wt.
Old Jun 24, 2010, 01:43 AM
Torrance is offline
Find More Posts by Torrance
Torrance's Avatar
Joined May 2009
Originally Posted by SUMO13 View Post
HI ,
@ Torrence ,
for the swingarm play... check the instructions to make sure that you have your flaged bearings installed in the correct direction (the flanges should be towards the inside of the frame plates).
yes i can tell you all something about the kit tires... they suck we only included them in the kit due to some dealer's requests. they're basically only RTR grade rubber. nowhere near as good as PMT 100 or 200. if you plan to only play with your bike on the street then the kit tires are ok. if you plan to go on a racetrack then don't waste your rims by glueing these tires on.
Torrance is offline Find More Posts by Torrance
Old Jun 30, 2010, 12:37 PM
mberli is offline
Find More Posts by mberli
Joined Jun 2010
Hi Edi,
What Is the lib. of kit shock spring ?
Tnx. Matteo
mberli is offline Find More Posts by mberli
Old Jun 30, 2010, 02:32 PM
mp- is offline
mp-
mp-
Napa, California
Joined Jan 2004
I had the same problem with swingarm shaft play. I used a .6mm thick shim between the frame plate and left side swingarm spacer.
mp-
Old Jun 30, 2010, 11:22 PM
DLAWW is offline
Find More Posts by DLAWW
DLAWW
DLAWW's Avatar
United States, CA, Gardena
Joined Dec 2005
what glue do you use for the tires, we use shoo goo for our rims and tires here. I would think the shoo goo is to heavy, so what is being used and is it reliable?.
DLAWW is offline Find More Posts by DLAWW
Old Jul 01, 2010, 02:11 AM
TT-Tom is offline
Find More Posts by TT-Tom
TT-Tom's Avatar
Germany
Joined Jul 2006
Hello DLAWW,
the Teamdrivers use CA Glue. I prefer the Team Associated CA.
Works perfect with the plastc rims. Before glueing I clean everything with Brake Cleaner.
TT-Tom is offline Find More Posts by TT-Tom
Old Jul 01, 2010, 02:21 AM
edi.winter's Avatar
Tirol
Joined Jul 2009
Originally Posted by mberli View Post
Hi Edi,
Tnx. Matteo
I am not sure what you want to know exactly:
But here is a list of the Asso springs (they should be the same as in the kit)
And a list where I compared the Asso and new and old Serpent springs (I use those)
Tire Glue:
I use any slow setting CG Glue. The plastic rims are easier to glue anyway. But its important to glue the entire bead. First start by mounting the whole tire and insert on the rim. Then pull a sector of the tire up exposing the bead and bead seating on the rim. Drip in a few drops of CG. Try to coat the rear inner wall and the bottom of the seating only. Quickly reseat the bead. Do that all around, sector by sector. Do both sides. Let the glue set. Normally then only the inner of the tire is glued properly the outer facing side will only be glued here and there according to how much CG you poured into the seating. Then try to pull off the tire. Be rough and apply quite a amount of power. Be sure you have reopened the sectors where the tire hasnt been glued properly. If you rip off the whole tire you havent glued properly in the first place. The tire should only slightly come off on the outer bead seating. When you have done that just glue the outer seating sector by sector.
Old Jul 01, 2010, 12:09 PM
mp- is offline
mp-
mp-
Napa, California
Joined Jan 2004
The steering dampers rub the upper swingarm as the suspension is compressed. About the only solution I can see is to grind/carve some clearance in the area of the swingarm where they contact. Anyone else have this problem?
mp-
Old Jul 02, 2010, 12:02 AM
Torrance is offline
Torrance's Avatar
Joined May 2009
mp-
should have plenty of clearance unless you're using a different servo horn from what's included in the kit.
i left TT before i got to see all the final production pieces so who knows if they managed to screw up some of the parts. the swingarm play would be a classic example - i haven't assembled a box kit yet so i'm unable to diagnose the problem. on the pre-production prototype i have, all the clearances are good.
Old Jul 05, 2010, 04:21 AM
TT-Tom is offline
TT-Tom's Avatar
Germany
Joined Jul 2006
Dear mp,
check that you have mounted the dampers underneath the servo arm.
Some make the mistake and mount the dampers on top of the servoarm.
Build Log ProJet MQ-9 Build (Tips/Tricks) NewEMan UAV - Unmanned Aerial Vehicles 594 Jan 04, 2016 05:44 PM
Discussion I have a Lanier SE5a coming, any tips or tricks............. mtdoramike Scale Kit/Scratch Built 14 Mar 19, 2011 06:17 PM
Question Gravity Hobby P 51 tips and tricks? Lilbanks96 Parkflyers 0 Apr 19, 2010 05:32 PM
New Product Formby Models TT SB-5 Pre-order snooey Motorcycles 12 Mar 02, 2010 11:15 AM
Need your TT/NF Nitro tips and tricks!! grymg Motorcycles 5 Aug 10, 2005 09:52 AM
