Old Jun 18, 2010, 11:15 AM
KenS999 is offline
Find More Posts by KenS999
KenS999's Avatar
United States, IL, Huntley
Joined Oct 2008
Help!
How To Straighten Bent Motor Shaft??
Hello,
Is there a tried and true method of straightening a bent motor shaft on a 400 size brushless inrunner ? Hammer? Vise? .... Maybe something more civilized?
Ken
KenS999 is offline Find More Posts by KenS999
Old Jun 18, 2010, 11:27 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Yes there is one that works extremely well and actual it is the best method available.
Step #1-A Remove motor shaft from motor.
Step #1-B If shaft is bent alot and removal is not possible without damaging magnets, buy new motor.
Step #2 Roll motor shaft on a flat surface (glass talbe) to be sure its bent.
Step #3 Pick-up phone and call LHS or order online a new replacement shaft.
Step #4 Wait for replacement to arrive.
Step #5 Rebuild motor with new shaft.
Or
Use what available to you aka HAMMER OR VISE and try to get it as close to as possible. Bend in the shaft will be less visible on lower KV motor then higher KV motor.
freechip is offline Find More Posts by freechip
Old Jun 18, 2010, 11:42 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
One of the better ways of straightening a slightly bent piece of wire rod (a motor shaft or solid control rod) is sandwich it between two flat, hard surfaces (like the flat part of your vise behind the jaws and a flat, steel bar) and pound the top steel bar with a hammer as you roll the rod to be straightened. Works OK on spring steel used for landing gears but I doubt it would do anything to a hardened steel shaft.
I think you'll find that replacement is the best solution.
Alan
Al Offt is offline Find More Posts by Al Offt
Old Jun 18, 2010, 11:57 AM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Agree with everyone, it's not really worth the effort to try and straighten it.
If it's not perfectly repaired, along with a vibration, you risk destroying the front bearing, and also take the chance of the armature hitting the windings inside the case.
Granted I straightened more then my share of cheap outrunner shafts, but even those 5 or 6 dollar motors are worth just replacing the shaft.
If the motor supplier doesn't offer a shaft, just go buy a long shaft drill bit in the correct diameter. Cut off what you need and you will now have both a hardened motor shaft, and another drill bit. If the old shaft had notches for a prop adapter or collar, they are easy enough to reinstall with a Dremel.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Jun 18, 2010, 12:36 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Did not read origanal post properly,
wellington53 is offline Find More Posts by wellington53
Last edited by wellington53; Jun 18, 2010 at 03:36 PM. Reason: Misread Op post, wrong advice.
Old Jun 18, 2010, 12:47 PM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
Step #1 Remove motor shaft from motor.
Or
You missed the step of
Figure out how to get the shaft out of the rotor without destroying the magents, since this motor is an inrunner, not an outrunner.
Jeffery is offline Find More Posts by Jeffery
Old Jun 18, 2010, 01:00 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
You are right, this is something everyone has missed, from the motors I have seen, the shaft can not be removed, to be replaced. Many in runners can not even be taken apart.
Quote from above
(Figure out how to get the shaft out of the rotor without destroying the magents, since this motor is an inrunner, not an outrunner. )
H.
himeros is offline Find More Posts by himeros
Old Jun 18, 2010, 02:39 PM
Glenn
Joined Jan 2004
Good catch Jeffery, Just shows how we can misread something.
Old Jun 18, 2010, 03:29 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
The O.p did not ask how to remove it but how to bend it back into shape. So I assumed it was already removed so I made changes to my post.
Funny how our brain just registers the some parts of what we read, Over looked the inrunner part.
Old Jun 18, 2010, 03:53 PM
Jeffery is offline
And You're Not
Joined Oct 2002
We're just "wired" differently. I'm a diehard old inrunner guy who's never really made the outrunner scene. I do actually own a couple of outrunners.
Old Jun 18, 2010, 07:07 PM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
You have to learn to rely on good luck.
Al M is offline Find More Posts by Al M
Old Jun 18, 2010, 11:35 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
You can get inrunners apart. They went together in the first place, right?
Usually there is some kind of backplate that needs to be removed. Some screw them on and that'll be obvious, others use Loctite or similar to glue the backplate in. Heat usually softens the loctite up enough so that a rap on the opposing end of the shaft will pop it loose. The shaft is likewise loctited in. Usually a press of some kind that is relatively accurate (bearing press) is emploed. Once the shaft is pressed flush with the end of the rotor, a smaller diameter pin will finish pressing the shaft out. At this point I measure the diameter of the shaft and buy a piece of matching drill rod. Some Dremel work later and you have your replacement shaft. Reinstallation is the opposite of the disassembly with cleaned components and fresh red loctite. Or:
Call the hobby shop and buy a new shaft. The old one isn't usually worth straightening out and the more you work it, the less strength the shaft will have and bend easier the next contact. Use directions above. Or:
Go online and order another cheap motor to replace the other cheap motor.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 19, 2010, 08:26 AM
dalehart is offline
Find More Posts by dalehart
dalehart's Avatar
United States, PA, Allentown
Joined Jun 2005
I have successfully straightened an inrunner motor shaft by clamping the end of the shaft in a drill press and using the motor case as a handle to bend the shaft straight. Start by clamping the shaft in the drill press, then hold the motor case gently and turn on the drill press to observe how much wobble there is. Turn off the drill press and rotate the drill chuck by hand until the motor case is at the far right point of it's wobble. Hold the motor case and push it to the left, going a little past center since the shaft will bounce back. Rotate the chuck again to see how well you have done, and repeat until it looks perfect. The final test is to turn on the drill press again and see if there is any wobble. If there is, just keep trying until you get it the best you can.
Dale
dalehart is offline Find More Posts by dalehart
Old Jun 19, 2010, 09:53 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Typically motor shafts will be hardened. By bending them you are cold working them causing possible embrittlement. Also you will likely not be able to completely remove the bend and likely load your bearings non-axially and thus shorten their life. A new shaft is your best bet.
http://en.wikipedia.org/wiki/Work_hardening
http://en.wikipedia.org/wiki/Embrittlement
going4speed is offline Find More Posts by going4speed
Old Jun 19, 2010, 09:58 AM
KenS999 is offline
KenS999's Avatar
Joined Oct 2008
Thank You !
Thanks for all the great info, it is indeed helpful.
Ken.
Discussion Is there anyway to straighten out a bent shaft on a motor sherlockshah Power Systems 21 Nov 27, 2009 08:26 AM
Question How to straighten a bent a shaft? x0wnag3x Micro Helis 10 Dec 28, 2005 10:21 AM
Best way to straighten a bent Mega motor shaft? BioBa Power Systems 2 Nov 29, 2003 11:34 AM
How to straighten a bent shaft from a Hacker-Maxon?? Flying Cat Power Systems 25 Jan 11, 2003 12:28 PM
