Old Jun 18, 2010, 06:00 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Sander's Skywalker FPV camera plane build
Alright, figured I'd start a new topic. Here's how I built up my Skywalker. I strayed quite far from the typical way this thing goes together.
1) Elastic bands to hold the wings on, are you kidding? This needs a safe and secure way of attaching the wing to the fuse. I cut the center portion of the wings off and attached that to the fuse permanently. I then made provisions for two thick wall (not the supplied!) 10mm CF wingspars using ABS plastic sheet.
2) Glassed the botton with light glass cloth and WBPU. Otherwise this plane with the large AUW will have dents and scuff marks on the bottom after the first flight already.
3) Wings reinforced with CF strips to prevent folding. Originally even the EPO version would fold its wing due to lack of strength.
4) Made channels and cut outs for wiring the stuff that will be placed above the wing (OSD, thermophiles, etc. etc.). This is all easily accesible through the hatch on the side of the fuselage.
5) The elevator hinge was a joke, so I rolled my own using the tried and tested depron and packing tape procedure I use on the majority of my planes. Also made the tail plane removable so the plane can be easily transported.
Configuration used:
- HS65HB servos on all control surfaces
- Graupner 345Z 1400kV (3536 size) motor
- 9x6 prop (properly balanced!)
- 2x 3S 4400/20C (parallel) all the way in the nose
- Pixim 540vtl camera for FPV
- ImmersionRC 8ch EzUHF Rx
- ImmersionRC EzOSD
- ImmersionRC ATV channel Tx
- 3A switching BEC for Rx and servos
- Pictured is a Sanyo VPC-FH1 HD camera
- 2.0kg AUW (with HD camera or 2x 3S/4400)
I have a few issues with the design of this plane I'd like to comment on as well:
a) Tail section, needs wider tail boom and fatter tail fin, too much flex and torsion currently which makes the tail move in the prop wash and results in poor tracking (EasyStar has the same problem).
b) Nose section, must be at least 10cm longer, nose is too short now, very hard to get correct CG with the long tail boom. I need two 3S/4400 packs to balance it out without the HD camera, and one 3S/4400 with the HD camera.
c) Wing attachment, elastic bands are just not an option, my suggested solution provides for a far better and safer/stronger mating of the wing to the fuselage.
d) Control surface hinging, too rigid on the original, needs to be redone thinner or the end user needs to roll his own.
If there's any questions or when I need to clarify anything just ping me and I'll do my best to answer any queries.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Jun 18, 2010, 06:13 AM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
As nice as always. Sander great work!
Remy is offline Find More Posts by Remy
Old Jun 18, 2010, 06:27 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
Sander, you need to work on your wiring. I can still see some of them
trappy is offline Find More Posts by trappy
Old Jun 18, 2010, 06:31 AM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
I just want to point out that the AXN has the issue too.
Very nice and clean build! I wish my planes were that good looking ...
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jun 18, 2010, 06:34 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Really nice build!
I didn't see/understand exactly how the outer wing sections attach to the center wing section? I see how they slide in place (nice wiring btw) but how do they stay in place?
boopidoo is offline Find More Posts by boopidoo
Old Jun 18, 2010, 06:56 AM
iw28 is offline
Find More Posts by iw28
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
soooo cooool setup Sander!!!!
This is definitely the best setup I have seen so far!!!!
It just look so professional, very cool Sander.
Cant wait for your video
,Iw28
iw28 is offline Find More Posts by iw28
Old Jun 18, 2010, 07:50 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
That is real neat. The best part I think is your wing mount modification. I'd love to see more details which would indicate to me if it's an option for my skills. Very neat.
Cralis is offline Find More Posts by Cralis
Old Jun 18, 2010, 08:13 AM
fjnetcom is offline
Find More Posts by fjnetcom
France
Joined Sep 2009
very nice job , it is beautiful plane, clap clap !! =))
fjnetcom is offline Find More Posts by fjnetcom
Old Jun 18, 2010, 08:23 AM
ssassen is offline
Joined Jul 2004
Originally Posted by boopidoo View Post
Really nice build!
The wingspar slots are tapered and the ends of the wingspars filed down to an angle so they go in without scuffing up the insides of the slots. The wingspars go in with a bit of force and you really have to pull hard to get the wings to part again.
Cheers,
Sander.
Old Jun 18, 2010, 08:50 AM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Sander, very nice work, that gives me ideas for mine, I am going to start building it tonight
metalfred is offline Find More Posts by metalfred
Old Jun 18, 2010, 09:16 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Very nice clean build!!
rcimports is offline Find More Posts by rcimports
Old Jun 18, 2010, 09:25 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
It sure beats my strapping tape method. I bet it flies as good as it looks.
bracky72 is offline Find More Posts by bracky72
Old Jun 18, 2010, 12:17 PM
Tom in Cincy is online now
Find More Posts by Tom in Cincy
Tom Para
Tom in Cincy's Avatar
Cincinnati, Ohio, United States
Joined May 2003
Cheers,
Sander.
I have been waiting for a critical flight review before I order one one these. Sander pretty much lays it on the table.
Standing by for the report.
Tom in Cincy is online now Find More Posts by Tom in Cincy
Old Jun 18, 2010, 12:26 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Hey I really like your mods, and I might have to steal some ideas when mine comes. I do like how clean the plane looks with no rubber bands, but I've found that if you use 6-8 rubber bands its REALLY strong, but in the event of a crash they will still let go, saving the plane. but then again, shouldnt be crashing I suppose.
ashdec87 is offline Find More Posts by ashdec87
Old Jun 18, 2010, 12:38 PM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
I just realize I do have a question:
The wings are held together by the spars alone?
Discussion Skywalker 168cm FPV plane Fergus FPV Aircraft 19051 Dec 01, 2015 03:10 PM
Build Log Skywalker FPV build - EPO version S11D336B FPV Talk 109 Jan 28, 2012 12:49 AM
Discussion My first FPV plane build log fireslayer26 FPV Aircraft 91 Jul 27, 2010 08:58 PM
Discussion My FPV plane build log fireslayer26 Your Plane Photos 8 Jun 12, 2010 02:16 PM
Discussion 48" camera plane build with 360* rotating video camera Lost In OC Aerial Photography 27 Jan 18, 2006 06:00 PM
