Old Jun 17, 2010, 08:48 PM
AMcC is offline
Find More Posts by AMcC
AMcC's Avatar
Australia, NSW, Sydney
Joined Jul 2008
Hyperion TIcool bec - Castle 10a bec
I was just seeking some advice/opinion on which of these two becs I should buy, ie the Hyperion Coolbec or the CC 10amp bec. Both seem to be good although searching through some forums there is the suggestion that there may have been problems with the CC bec. Which ever one I get will be used on a twin set up with multiple packs in series and parallel (hence the bec). Any actual experience of these items appreciated. PS My only other ubec was a turnigy that failed. I'm not knocking Turnigy they are the motors in my twin but I do not trust their BECs anymore.
AMcC is offline Find More Posts by AMcC
Old Jun 18, 2010, 11:51 AM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
I myself like the Castle, if I can't get an Ultimate. Never had a problem with either brand.
Don't know anything on the Hyperion.
Make sure you read the fine print on a stand alone bec. The more voltage you throw at it, the less amp output it will have. So make sure your needs to power all the servos and rx are bec capable.
You could easily burn out a bec by thinking it's rated at 10 amps when after you power it with 6 s, it's out put drops to 5 amps and your system draws 6.
Castle does list this info right on their website and paperwork.
Also the output leads that plug into the rx are only rated for 5 amps max, so if you are running more then 5 amps, you will need multiple plugs going to the servo.
They can be direct plugged or done off a Y harness to one of the other leads.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Jun 18, 2010, 01:53 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I've run a couple of Hyperion CoolBECs for a couple of years now, and have had no issues. I've not run them at their full capability though -- only 4 or 5 HS81 servos in each model -- and have installed them in the cowls in a good cooling stream of air. Also got a couple of Ultimate BECs doing similar service, also with no issues.
The Ultimate BECs caused interference when I was on 35MHz, but I've since moved to 2.4GHz, so no longer an issue. I've only used the Hyperions on 2.4GHz.
abenn is offline Find More Posts by abenn
Old Jun 30, 2010, 09:06 PM
AMcC is offline
AMcC's Avatar
Joined Jul 2008
Thanks guys
Old Jul 04, 2010, 04:46 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Ive got both, never had any problems with either
The CCBEC is MUCH smaller than the hyperion though, if thats an issue.
jackosmeister is online now Find More Posts by jackosmeister
Sold CC 10A BEC & Castle Link aussie_g Aircraft - Electric - Power Systems (FS/W) 0 May 01, 2010 05:27 PM
Question Hyperion Ticool BEC transient Power Systems 2 Apr 16, 2010 07:45 PM
Found Castle Creations 10a bec<<< Got one misplacedtexan Aircraft - Electric - Power Systems (FS/W) 2 Mar 25, 2010 07:51 PM
Sold Hyperion Titan 80A Hi-Pro Opto w/TiCool switching BEC + usb programmer HighNear90 Aircraft - Electric - Power Systems (FS/W) 4 Jun 02, 2009 10:52 PM
For Sale (BYE BYE R/C HELIS) Hyperion Titan 80A Hi-Pro Opto w/TiCool switching BEC & usb prog HighNear90 Aircraft - Electric - Power Systems (FS/W) 0 Feb 10, 2009 10:48 PM
