Old Jun 17, 2010, 03:37 PM
Mack531953 is offline
Find More Posts by Mack531953
Joined Jun 2010
Brushless motor wiring to ESC
Okay had a Wasp 200se that the motor mounted on top with the pinion shaft pointing down, changed to a wasp 250 belt and the motor mounts on the bottom with shaft points up. I wrote down the color and the right plug it goes to. But it seems to be running backward now. Do I need to swap some wires? If so which ones? Don't want to do the hit & miss way, my luck I'll burn out something....that means more money,more money...
Mack531953
Mack531953 is offline Find More Posts by Mack531953
Old Jun 17, 2010, 05:56 PM
skyartec-usa is offline
Find More Posts by skyartec-usa
Pontiac/Auburn Hills, Michigan USA
Joined Mar 2009
Re: ESC
Mack531953
"I wrote down the color and the right plug it goes to."
Would have been useful to include this information in your question. Without it we can only guess at your current wiring.
Here is same answer I sent to the customer that emailed me with the same question:
Confirmed from Belt 250s currently on our instock.
ESC A to Blue on Motor
ESC B to Yellow on Motor
ESC C to Red on Motor
Hope this helps
Max
skyartec-usa is offline Find More Posts by skyartec-usa
Old Jun 21, 2010, 12:56 PM
Joined Jun 2010
Wiring
Worked perfect, I didn't even know they had connectors til I started moving the electonics to the New Wasp Belt 250....
Thanks again
Mack531953
Old Jun 21, 2010, 07:40 PM
r00x is offline
Find More Posts by r00x
Joined Jan 2010
I know this thread is completed, but just weighing in for the future reference of others:
I was under the impression that swapping any two of the three motor wires around would reverse the direction of the motor if it was going the wrong way. It's just an effect of the arrangement of the coils in the motor. Seems to work for me if I'm dealing with ESCs/motors that have no colour-coding, so I hope this is useful to anyone who strays across this thread
r00x is offline Find More Posts by r00x
Discussion wiring / esc setup kd A 220 brushless,no activity fatbloke-dim Power Systems 9 Jun 04, 2010 09:14 AM
Question TP 2415-07T Brushless Heli Motor 3850kv Wiring Help? mncowboy969 Electric Motor Design and Construction 0 Apr 26, 2010 07:50 AM
Discussion Wiring brushless motor and speed controller dissymmetry Power Systems 2 Mar 06, 2010 12:25 PM
Brushless Twin Motor and ESC wiring question TGoodwin Power Systems 19 Sep 16, 2007 11:32 AM
Discussion white silicon (spaghetti) wire for wiring of brushless motor, esc, etc reefboy Power Systems 7 Dec 26, 2006 10:22 AM
