Old Oct 09, 2011, 06:28 AM
jbpence is offline
Find More Posts by jbpence
NYC
Joined Nov 2006
Originally Posted by ROT8 View Post
See answers to your questions below!
Thanks much
jbpence is offline Find More Posts by jbpence
Old Oct 10, 2011, 12:45 PM
jbpence is offline
NYC
Joined Nov 2006
Oops forgot one
How high is the highest part of the rudder? With the tailwheel installed
Old Oct 10, 2011, 03:07 PM
ROT8 is offline
Find More Posts by ROT8
ROT8's Avatar
Montreal, Canada
Joined Nov 2003
17.5"
I am here: http://maps.google.com/maps?ll=45.627704,-73.729058
ROT8 is offline Find More Posts by ROT8
Old Oct 11, 2011, 09:36 AM
jbpence is offline
NYC
Joined Nov 2006
Thanks, it fits with with smudge to spare. Have to "twist" the fuselage as I load it to get the stab in through a narrow place, but it appears that t will fit, and if not, removing the horizontal stab, it definitely will fit
Ordering stuff
Old Oct 13, 2011, 09:56 AM
octopuss is offline
Find More Posts by octopuss
octopuss's Avatar
Belarus, Vitebsk province, Vitebsk
Joined Oct 2011
Hi guys!
Can't make up my mind what extra to buy 70' or 60'. She will be my first EF plane. What would you recommend?
octopuss is offline Find More Posts by octopuss
Old Oct 13, 2011, 05:13 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Originally Posted by octopuss View Post
Hi guys!
I would say it depends on what you want to do.
Everything else aside except flying:
The 60" is going to be a much more high energy plane where the 70" is going to be a little more reserved. Both are equally capable but the 60" has huge power, huge speed range, huge control throws and a will handle anything you can do to it.
The 70" very precise and crisp and flies a lot like a much bigger plane. I enjoy flying this plane and working on my skills, it just gives you so much time to think. To me it feels happiest in the mid speed ranges. It is so stable and predictable and straight flying that it makes me smile every time I fly it!
You can't go wrong with either one!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Oct 14, 2011, 04:39 PM
octopuss is offline
octopuss's Avatar
Joined Oct 2011
The 60" is going to be a much more high energy plane where the 78" is going to be a little more reserved. Both are equally capable but the 60" has huge power, huge speed range, huge control throws and a will handle anything you can do to it.
The 78" very precise and crisp and flies a lot like a much bigger plane. I enjoy flying this plane and working on my skills, it just gives you so much time to think. To me it feels happiest in the mid speed ranges. It is so stable and predictable and straight flying that it makes me smile every time I fly it!
Thank you!
You wrote about 60" and 78", but what about 70"? You think Extra 70" is a successful EF airframe?
Old Oct 14, 2011, 05:14 PM
danamania is offline
Find More Posts by danamania
Advocating for RC Aviation
USA, NJ, Phillipsburg
Joined Jul 2010
The 70" is awesome. I can use that word here because I also have a 71" AJ Slick which is also awesome! LOL. Check out the first few pages of this thread for some good info. Good flying! Dana
danamania is offline Find More Posts by danamania
Old Oct 14, 2011, 06:16 PM
Columbia SC
Joined Feb 2005
Sorry, I was thinking 70" but typing 78".
Old Oct 15, 2011, 06:02 AM
DTM2.0 is offline
Find More Posts by DTM2.0
Joined May 2011
Hi guys
just wanted to ask if anyone has experienced the need to add more right thrust angle to the already built in angle of the shorter gas/ep motor box.
or are you using a throttle --> rudder mix
DTM2.0 is offline Find More Posts by DTM2.0
Old Oct 15, 2011, 07:31 AM
Columbia SC
Joined Feb 2005
None of the above for me. What are you experiencing?
Old Oct 15, 2011, 01:39 PM
bdiesel3 is offline
Find More Posts by bdiesel3
He Reigns
bdiesel3's Avatar
United States, MI
Joined Apr 2011
Had a motor fail while I was in a harriar, push alittle down elevator and was able to saftly land the plane. It was near the end of the runway though so it coasted of the end and just flopped over onto it's top. Nothing major, but the top of the rudder cracked. So I dripped some thin CA in and put the covering back down, then added a white strip of covering to cover the small tears and a silver pinstripe. Now she is all fixed, time to fly again.
bdiesel3 is offline Find More Posts by bdiesel3
Old Oct 15, 2011, 05:08 PM
Columbia SC
Joined Feb 2005
Looks great! Nice repair!
Old Oct 16, 2011, 08:34 AM
DTM2.0 is offline
Joined May 2011
I was experiencing a lot of pull to the left on my maiden and second flight on vertical up lines. Tried this with,into and cross wind with the same result.
I used a logger on the maiden and with a 18x8 prop on the scorpion 4035-380 on 7S was getting 2100 watts @ 78 amps and that was about 90 % throttle at the most. for the maiden I didn't want to take it to WOT plus I was quite happy with the output
I added a little more right thrust but when I plugged in my 7s battery (3s and 4s in series) today to test if there was any improvement my esc fried quite spectacularly.
it was an CC ICE 100
Checked my wiring and couldn't identify any faults with the series harness and batteries, was using a EC5 connector so can't have reversed polarity. I've connected batteries in series many times but never had this happen
Does anyone have any experience with the extreme flight airboss 90 amp OPTO ESC might order one as replacement while I hopefully get a replacement CC ICE
Old Oct 17, 2011, 07:32 AM
DTM2.0 is offline
Joined May 2011
after the CC ICE fried I hooked up a turnigy plush 80 amp ESC and went to test the adjustment to the thrust angle and it was a lot straighter on the vertical up line even had a little movement to the right as i reduced thottle and swung around.
the turnigy only supports 6s but i was still getting 1900 watts @ 85 amps with a 20x8 APC and about 1775 watts @ 76 amps with the 18x8 APC
I ordered the airboss 90 amp OPTO ESC so the turnigy is just tempororary till that arrives hopefully by the end of the week.
I'll keep the new thrust angle for now as i'm hoping that the power increase when I go back to 7s will have my vertical up lines straight as an arrow hands off.
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9813 Aug 05, 2016 11:30 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
