Old Mar 18, 2011, 02:57 AM
dukeofearl is offline
Find More Posts by dukeofearl
3D crazy
dukeofearl's Avatar
Australia, QLD, Warwick
Joined Aug 2010
Originally Posted by FlopGun View Post
Duke, I flew mine on a Scorpion 380kv 6S combo. I started with a 20x8 Xoar which didn't have enough speed. Switched to Xoar 19x10 and that's the sweet spot. Didn't try 20x10 but I think you'd be heating things up a bit.
Ok thanks for that, can you remember what amps and wattage you were getting with both those props on that motor.
Regards
Pete
dukeofearl is offline Find More Posts by dukeofearl
Old Mar 18, 2011, 05:02 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
Originally Posted by powerlines View Post
This is the BEST looking plane I have EVER had in my Fleet!!!
Thanks TERRY for the Great deal!!!!
Thanks Chris H.. For the AWEsome work you do!!!!
can't wait to fly this tomorrow!!!!
It's POWERlines approved now!!!!
Hope you enjoy it as much as I did.
See ya down at SEFF!!!!
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Mar 18, 2011, 05:21 AM
3D crazy
dukeofearl's Avatar
Joined Aug 2010
herc,
You list on page 1 that you use a Castle Ulitmate BEC, I cant seem to find one under that name. Is it the CC BEC Pro or standard CC BEC ?
http://www.castlecreations.com/products/ccbec.html
Also on the topic of BEC's is there any advantage in using a BEC over plugging a 6.6v battery directly into the receiver to power the servo's. My understanding is that BEC's reduce power from higher voltage to lower voltage. If I'm using a separate battery pack for my receiver and servos etc then do I really need a BEC at all.
I have BEC'S on my 48" planes drawing the power from one large battery that is also powering the motor so I understand why its needed in that instance.
I'm not real sure when using two battery packs why its needed when I can simply choose the right voltage battery for the receiver to start with.
This is my first plane using separate batteries so its all new to me.
Regards
Pete
Old Mar 18, 2011, 05:49 AM
Chuchuf is offline
Chuchuf's Avatar
Joined Aug 2009
Originally Posted by dukeofearl View Post
herc,
Regards
Pete
The reason to use a BEC is to regulate a higher voltage to something lower. For instance, if you were running a Lipo as your flight pack battery, and had servos/receiver that couldn't run on the 8+V of a fully charged Lipo, you would run a BEC in line with the Lipo and "regulate" the voltage down to 4.8 or 6V which would be acceptable to the servos.
If you are running (as an example) a 4.8V NiCad as your flight battery, then a BEC wouldn't be needed.
On these larger planes it is wise to run a seperate battery to power the servos and receiver whereas on the smaller planes the esc has a BEC built in to it and that supplies the voltage to the servos/receiver from the flight pack batteries. On the smaller planes this is dome for room and weight considerations where they are not an issue on the larger planes.
Also lots of folks are running LiPo's for their servo/receiver battery packs and since most servo's (except for the newest HV ones) are limited to up to 6V operation, that lipo needs to be voltages regulated down to 6V or less.
Terry
Old Mar 18, 2011, 06:17 AM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
I have run the LIFE packs since they come out.. I love them.. POWERfull and reasonably cheap.. I have them in 70'' plus.. I run a 2200 in my 50CC yak and it's rocking.. No regulator needed.. Just have to have a charger that will charge them.. LIFE=A123
LATER!!
powerlines is offline Find More Posts by powerlines
Old Mar 18, 2011, 06:37 AM
crazyflyin is offline
Find More Posts by crazyflyin
Live for Jesus, Fly For Fun
crazyflyin's Avatar
United States, MI
Joined Aug 2008
Got the AR8000 with the Telemetry module. Willl connect Flight pack and temp sensors tomorrow.. LIFE in the HOUSE!!!
MOTROLFLY on the way!!!
Thanks KEN!!!!
Congrats on the 70", I have the same color scheme and really like it. I was looking at some of motrofly motors as well, if you get a chance to weigh it, let us know.
crazyflyin is offline Find More Posts by crazyflyin
Old Mar 18, 2011, 06:51 AM
3D crazy
dukeofearl's Avatar
Joined Aug 2010
LATER!!
If I were to use Hitec MG analog servo's all round would the below battery be ok straight into the receiver without using a BEC. Its rated at 6.6v....
http://www.hobbyking.com/hobbyking/s...dProduct=14468
Or would I be better going to 4.8v as Chuchuf suggested
http://shop.desertaircraft.com.au/catalogue/c13/p843
If I did go to 4.8v would that be enough to power 5 analog servos ?
Regards
Pete
Old Mar 18, 2011, 08:23 AM
powerlines's Avatar
Joined Apr 2004
I have used this with Digital soo far.. I have heard some servos don't work well over 6V I have a buddy that has the 645MG and he has no issues!!
Old Mar 18, 2011, 08:25 AM
powerlines's Avatar
Joined Apr 2004
You want the motor or all up..
It has a turnigy on there now.. I will leave it for a while to test.. I told Terry I would..
Old Mar 18, 2011, 09:58 AM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
herc,
Regards
Pete
I am using the BEC Pro. I think it used to be called the ultimate bec or maybe I'm losing my mind.
As for why to use one - mainly to provide clean steady power to the RX and servos. If you use a nicad or nimh the voltage to your gear will change as the battery discharges. Meaning, the plane will feel different when the pack is fresh than it will when it is more discharged. Also voltage will fluctuate under load from the servos and in my experience 2.4 RXs and digital servos perform best with clean steady power. The BEC will keep the voltage the same even under load and first flight or last flight will have exactly the same voltage.
Also, my 1300 lipo and BEC is lighter than a comparable nimh or nicad.
Also, I can charge a lipo to 100% in less than an hour without damaging it.
All that said, I would rather run a nimh or nicad without a regulator or bec than run a bec off the flight battery on a high power setup.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Mar 18, 2011, 10:11 AM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
Regards
Pete
Pete, I didn't measure the 20x8. On the Xoar 19x10E I was pulling 83 amps.
It should be noted that the Xoar 19x10E is not a standard Xoar size and is available at just a few shops. I got mine at Chief Aircraft.
FlopGun is offline Find More Posts by FlopGun
Old Mar 18, 2011, 11:52 AM
crazyflyin's Avatar
United States, MI
Joined Aug 2008
I am interested in just the motor weight.
Old Mar 18, 2011, 12:22 PM
cjcyclesrc is offline
Find More Posts by cjcyclesrc
Fly Extreme!!
cjcyclesrc's Avatar
United States, NC, Lexington
Joined Oct 2007
I'm trying one of the Hobbico LiFe Source batteries in my 70". I've been running a123's for over 3 years and they are great. My friend that owns the Local hobby shop here started stocking these LiFe Source batteries so I thought I'd give one a try. It's lighter than the A123's also. If I didn't get this battery, I'd probably end up using a 2300 mah A123. I just like using them and not having to run a regulator. A Regulator/BEC would be fine in a plane this size but i'm just used to my bigger gassers and the benefits of not having regulators. I finally got my 70 back on the bench last night. I'll get it finished tonight. I can't believe it's taken me this long to get back to it.
http://www.rcgroups.com/forums/attac...mentid=3595225
cjcyclesrc is offline Find More Posts by cjcyclesrc
Old Mar 18, 2011, 02:34 PM
powerlines's Avatar
Joined Apr 2004
this is from Kens site..
http://www.subsonicplanes.com/Motrolfly_Motors.html
* Weight: 455 grams
* Stator Width: 43mm
* Stator Height: 25mm
* Motor Width: 54.8mm
* Motor Length: 52mm
66.3mm X mount to Hub face
* Hub Length: 38.5mm
* Hub Shaft: 8mm x 30mm
* Motor Shaft Size: 6mm
* 12 tooth 14 magnet DLRK
Old Mar 18, 2011, 02:35 PM
powerlines's Avatar
Joined Apr 2004
It's the ones I use.. I love them.. I have had them in the last few planes.. NO issues at all..
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9745 Today 07:06 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
