Old Sep 28, 2010, 03:49 PM
PeppyK is offline
Find More Posts by PeppyK
PeppyK's Avatar
Bratislava,slovakia
Joined Apr 2010
Originally Posted by RC4x4 View Post
I started on my buddy Glenn's 300 today. Got everything hinged, langing gear on, tail wheel on, servos in and linkages, and ironed out for the first time.
Tomorrow I will finish up the deflections, and some misc stuff. If I'm lucky, I hope to mount the motor and speedo etc.. Hopen for a thursday maiden.
Glenn, you gonna be around to see it?
I just have to say, what an easy build. Everything has fit together just perfect. Very good looking plane in person, and I can't wait to fly it.
I will post pictures of it next to the 78'' 300. I just love the colors and the scheme.
I will also post spec's on the electronics used once I get some pictures.
Fly Low and Fly Safe!
Cory
can you after maiden compare 78 and 70??
THANKS
PeppyK is offline Find More Posts by PeppyK
Old Sep 29, 2010, 08:28 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
THANKS
I sure will.
I'm almost done. Motor will be mounted tonight and the rest of the front end. Set the deflections and it is done! I will get an auw also. I'll try and put the watt meter to it also. Pictures to follow as well.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Sep 29, 2010, 01:05 PM
michaelJH is offline
Find More Posts by michaelJH
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
For all you guys who have been doing alot of testing on these setups, If you could give me your opinion on my setup that would be much apreciated!
I have decided to go with This unless you have any advice of somthing better.
Scorpion 4035 330kv
Phinix ICE 100A ESC
6s 5000 30C packs
JR 8611A servo's on rudder and alirons (I know it is overkill but I already have them )
Hitec 5245MGs on the elevators
Fromeco 1100 A123 RX pack
JR 921 RX
If you have any advice on somthing that I should change please let me know!
michaelJH is offline Find More Posts by michaelJH
Old Sep 29, 2010, 01:19 PM
ggroyal1117 is offline
Find More Posts by ggroyal1117
ggroyal1117's Avatar
Norcross, GA
Joined Dec 2005
This is how I setup the receiver powered by a CC Pro BEC and Hyperion 1300mah 3S lipo.
ggroyal1117 is offline Find More Posts by ggroyal1117
Old Sep 29, 2010, 01:28 PM
Norcross, GA
Joined Dec 2005
I have a question about AXI motors. I was looking at the specs and the 5325-18 looks better than the 5320-18. The 5320 shows 6 cell and the 5325 shows 8 cell. Everyone seems to like the 5320-18, but would the 5325-18 be even better? Hobby-Lobby has a 15%off sale for a couple of days. My Scorpion 4035-330 is working fine, but I was thinking about a backup.
George Royal
Old Sep 29, 2010, 03:23 PM
Zisko is offline
Find More Posts by Zisko
Joined Sep 2010
I have a problem with the wires, leading to the rudder. I crossed them inside the fuselage, which leads me to the problem, that every time I bring the rudder servo to it's final position, the wire, that is not pulling, gets loose. Anybody else have this problem? Did you cross the wires?
Zisko is offline Find More Posts by Zisko
Old Sep 29, 2010, 07:09 PM
Norcross, GA
Joined Dec 2005
On the first page of this thread, hercdriver7777 shows the pull-pull rudder wires crossed and the offset 3" servo arm(SWB). I used hercdriver7777's info more than the manual, he did a great job.
Thanks, Chris
Old Sep 29, 2010, 07:20 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
It is my pleasure!
Zisko what servo arm are you using?
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Sep 29, 2010, 10:45 PM
Zisko is offline
Joined Sep 2010
It's a 3" Airwild: http://www.braeckman.de/servoarmegross.htm
It goes straight until its end and has no crank like the swg's. But if you think about geometry, this can't make the difference.
It is just, when you go to the end position of the rudder, the wire, that doesn't pull at the moment gets loose. At this moment, the rudder would just be fixed between the air presure and the pulling wire. Normaly, that must be like this at any extra, because I didn't do something special, but at it is my first linkage with wires, it seems to me a little strange. What does your wires do in the end position? Are they both absolutely tight?
PS. Wires are tight till about 25 of rudder-movement. Than they get loose
Old Sep 30, 2010, 12:24 AM
attack duck is offline
Find More Posts by attack duck
Joined Feb 2005
Scorpion 4035 330kv
Phinix ICE 100A ESC
6s 5000 30C packs
JR 921 RX
330 kv is too low for 6S on this motor. I tried that combo on a 68" Velox
and performance was underwhelming. The power really came alive after
switching to the 380 kv motor. The 330 kv works great with 8S.
Glenn
attack duck is offline Find More Posts by attack duck
Old Sep 30, 2010, 12:31 AM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
The wire that is not pulling will get loose, totally normal. I don't remember if wires that are not crossed get loose? I have one plane like that and don't remember. But, it is normal.
Cory
Old Sep 30, 2010, 08:14 AM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Build is done!
Just wanted to let everyone know the build is done.
What a beautiful plane. I will get an AUW before I fly it and put the watt meter to it. Updates to come.
Here's the spec's:
Scorpion 4035/380kv motor
Castle Ice 100 speed control
Castle ccbec (small blue one)
Hitec HS985mg servos - ailerons and rudder
Hitec HS5245 digital servos on elevators
SWB servo arms
Great planes 3'' aluminum backplate spinner
APC 20X8 prop / will also try a Xoar 20x10 wood prop
Batteries - FlightMax, Hyperion, Thunder Power will be used
All stock hardware used
Cory
Old Sep 30, 2010, 08:17 AM
Zisko is offline
Joined Sep 2010
What I found ut is, that I din'd absolutely center the rudder hinge (about 0,08"). Looking at the geometry of the whole thing, theoretically there is no need to have loose wires, because the hinges at the rudder and the servo are exactly the same length and centered beneath the turning point.
Should I move the wholes in the hinge to make this thing better or does anybody have another idea?
Old Sep 30, 2010, 10:55 AM
Columbia SC
Joined Feb 2005
Zisko, I wouldn't worry about this too much. It's not that critical at all IMO.
Old Sep 30, 2010, 03:30 PM
straightedge_ is offline
Find More Posts by straightedge_
click here
straightedge_'s Avatar
San Diego, CA
Joined Feb 2008
Michael and Glenn,
I'm not second guessing anybody, but according to my "calculations" the next line for 6S (22 Volts) in the 4035-330KV prop sheet would read:
APC 20x10, 90 Amps, 1980 Watts, 5100 RPM, thrust 7800 grams, efficiency 4 g/W which sounds like a good fit.
http://www.scorpionsystem.com/files/...data_chart.htm
Glenn
straightedge_ is offline Find More Posts by straightedge_
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9698 May 25, 2016 12:39 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
