Old Jul 29, 2010, 02:44 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Originally Posted by FlopGun View Post
......A heavier prop is going to spin a little slower, be less efficient, so not good....
Additional weight will reduce responsiveness to throttle changes as more torque will be required to change the RPM, however when the speed isn't changing the prop will spin just as fast as a lighter prop with the same geometry. Any differences in current draw, torque, etc will be due to the shape of the blade not it's weight.
Aio_1 is offline Find More Posts by Aio_1
Old Jul 30, 2010, 12:23 AM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
First off, Edge was right, I moved the packs up and that improved everything.
Hovers very easy and TRs easier to control and fixed the inverted harriers.
Love this plane!
So here are the numbers on my setup
Xoar standard prop 19x10
Scorpion 4035-380
Pentium Hobbywing 100A
Bench tests
Zippy Flightmax 6S 5000mah 20c
Amps 102 Watts 2150
TUrnigy 6S 5000mah 25c
Amps 102 Watts 2350
The hobbywing's specs are 100amps with 120 amp burst 10 seconds
FLight tests
70 degrees ambient air temperature
9.25 lbs AUW
7 minutes of 3d precision mix
Turnigy = 3850mah used
motor approx 130 degrees (using finger)
Batteries warm not hot, Zippy a little warmer than Turnigy
Guys, am I overcooking it?
I really like this setup, the plane 3Ds very well with a nice throttle range in the sweet spot and vertical is not ballistic but very good.
FlopGun is offline Find More Posts by FlopGun
Old Jul 30, 2010, 08:51 AM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Looking good Flop. That looks like a good 6S setup. I love this plane too!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jul 30, 2010, 10:41 PM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Love this plane!
Scorpion 4035-380
Bench tests
Amps 102 Watts 2150
Amps 102 Watts 2350
FLight tests
9.25 lbs AUW
Castle reccommends that you don't pull any higher than 50%-70% of what the pack can do continuous in amps.
So your 20c 5000mah pack would be 50-70amps
25c 5000mah pack would be 62.5-87.5 amps
I think your pulling way too many amps at full throttle. Watt meter or download from controller?
My buddy will drop off his Scorpion 4035.380 ntomorrow for me to try.
I'm kinda thinking 8s is better all around for power and efficiency.
The 78'' 300 on 10s is very efficent I think. I get around 73-74 amps at full throttle, 2900 watts, and land with 30-40% in the packs after 7 good minutes. I could push it to eight minutes and see. The whole system is slightly warm. Using a 21x10 xoar also. If I do one of these planes I think the 8s would be better all around. I don't know, still thinking about it?
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Aug 02, 2010, 12:14 PM
EXTREME FLIGHT is online now
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Glad to hear you are enjoying the Extra FlopGun. Would love to see some video!
EXTREME FLIGHT is online now Find More Posts by EXTREME FLIGHT
Old Aug 02, 2010, 01:36 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Funny you should ask! Video is encoding right now, should have it up in an hour or two.
Just a word of caution about my setup. I'm still experimenting and indeed it could be running too hot, we had a cutout on the 5th pack yesterday, not sure but think it was probably ESC overheating, so don't try my setup at home lol. at least not yet, I need to collect some more info, the ESC is buried deep under the cowl so I couldn't test for heat after the cutout.
Old Aug 02, 2010, 01:54 PM
EXTREME FLIGHT CEO
Joined Feb 2004
Looking forward to it.
Old Aug 02, 2010, 02:52 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Just to set the table for this video.
Daniel cut his left hand in a propeller accident on Thursday.
After 10 stitches and looked like he was going to be grounded, but that didn't stop him, he *won* the Pacific Coast Freestyle Championship yesterday in Molalla, Oregon. Congratulations Daniel!
I like to think that this warmup flight on the EF 70 helped just a little bit.... so this is early morning before the contest. Daniel with a Touch of Gray on a cold cloudy morning.
Thanks to Daniel for flying her and also to that guy Alex who later setup some mixes for me. !! rOCK.
Danielph's "Touch of Gray" on the Extreme Flight 70" Extra EXP (5 min 45 sec)
Old Aug 02, 2010, 03:03 PM
Prestigeauto is offline
Find More Posts by Prestigeauto
Portland/NJ/NY
Joined Jun 2010
Man i cant wait to get mine,Been talking to hercdriver7777(Chris) About This Plane And He's Got nothing But Postive Things To Say About It!
I was Going To Pull The Trigger On 70" Slick,Good That I waited!!!
Placing Order Tomorrow,Mr Hansen This Plane Looks And Flies Awsome,Great Job!
Now Just A Choice Of Motor As I Intend To Run It On 6S,Any Suggestions ExtremeFlight?
Prestigeauto is offline Find More Posts by Prestigeauto
Reply With Quote  (Disabled)
Old Aug 02, 2010, 04:33 PM
Columbia SC
Joined Feb 2005
Great flying Daniel! And Flop that looks like a great high power 6S setup. I hope you can get the bugs worked out of it! With that prop it almost sounds like a gasser on cans.
Old Aug 02, 2010, 05:44 PM
Portland/NJ/NY
Joined Jun 2010
THis plane has like absolutely no wing rock,specially in upright harriers Amazing
And FlopGun Great Flying Dude!!!!It Does sound A Bit Like A Gasser
Old Aug 02, 2010, 08:37 PM
danielph is offline
Find More Posts by danielph
TEAM EXTREME!
danielph's Avatar
High Prairie, WA
Joined Nov 2007
HOW MANY TIMES DID I TELL YOU THAT WASN'T TO BE POSTED? Oh fine... My first real flying after the accident had to be on video. Haha. Chris, I was out of my element during that flight, but could tell that it was a sweet plane right off the bat! The jealousy just gets worse. -just kidding.
Thank you again Flop for letting me fly it even in my condition. Sure had fun with ya' this weekend!
danielph is offline Find More Posts by danielph
Old Aug 02, 2010, 08:38 PM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Great job of flying Daniel and awesome video. The colors looked good on that plane. The plane looks reeal smooth.
Cory
Old Aug 03, 2010, 01:07 AM
Columbia SC
Joined Feb 2005
Well, I can't claim to have the skills of Daniel yet, but I'm trying my hardest. However, I did finish editing my footage from the weekend. Enjoy!
Extreme Flight 70" Extra 300 EXP (6 min 17 sec)
Old Aug 03, 2010, 07:58 AM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Awesome flying and great video Chris. What battery setup did you use while flying.
Cory
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9747 Jun 26, 2016 05:14 PM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
