Old Jan 12, 2013, 10:29 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Originally Posted by bigroger View Post
I thought the dm4330 was even less difference then that? 560g versus 568g with fibre mount?
I should have got the 4325 at the time, but 3dhs flyers were suggesting the 5320 kept a bit cooler if you run back to back packs and drew less amps for the same setup.
I don't have any trouble and besides the 4325 310 is more than enough power. I just don't see the need for that much power or weight IMO. You could always go back and have no regrets.
jw357_23043 is offline Find More Posts by jw357_23043
Old Jan 13, 2013, 10:47 AM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Flew my first packs with a parallel () connector I made. I am giving up on the more expensive 6s5000mAh in favor of two packs in series from my 60"MXS 6s3300mAh. (6s6600mAh).
Getting an extra minute of flight and batteries are coming down at 3.8/ cell. With batts all the way back, I have a slight trim change in CG, but still fantastic all around and I like the longer flights; I can probably add another 0:30 to my timer.
...also broke 2 props- I need to finally put my LG on the right direction to prevent nose overs. Pics coming
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Old Jan 13, 2013, 06:40 PM
Shut up and Fly!!!
Joined Aug 2011
Don't you mean series instead of parallel?
Old Jan 13, 2013, 06:51 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
I think he means parallel.
If he went from 6s3300 to 6s6600 thats parallel.
Series would be 12s3300.
bigroger is offline Find More Posts by bigroger
Old Jan 13, 2013, 06:52 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Was a bit confused myself, and PM'd but may have confused him even. LOL
I was trying to figure out if he's using 4 total packs or two.
So 12s at 3300 by using two 6s 3300's in series, or 12s 6600 by using two such 'series' setups in paralllel...or just 6s at 6600 (if just two packs in parallel)
C_Watkins is offline Find More Posts by C_Watkins
Old Jan 13, 2013, 07:12 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
I just assumed as he was coming from a 6s5000 setup that he was staying with 6s but gaining mAH. Hence parallel.
Don't worry once you start looking at 8s, 10s, 12s setups it all becomes crystal.
Old Jan 13, 2013, 08:59 PM
USA, GA, Atlanta
Joined Nov 2008
LOL~ All the advice is well received. I actually tend to get them backwards myself
To clarify, this is what I meant:
6s3300mAh + 6s3300mAh = 6s6600mAh
Latest blog entry: New Drone Movie :D
Old Jan 15, 2013, 11:53 AM
cookci is offline
Find More Posts by cookci
Joined Jul 2011
What throws are people using on the ailerons or has everybody gone for "as much as they can get"?
I have 12 kg of torque available in the servos apparently
Initially on my 3dhs edge I went for "as much as I can get" but brought it in a peg or 2 to regain some much needed resolution. .. as it happens it now rolls a lot faster so the torque was really needed.
cookci is offline Find More Posts by cookci
Old Jan 15, 2013, 03:13 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Cooki,
I initially set up 45 deg on my extra but yesterday I dialed it back to 40deg and it actually rolled faster and smoother.
Don't know it was blow back but more likely the ailerons might be acting as an air brake or something f you go too high.
I'm running the swb1.5" arms on hs7985 servos at 6.5V.
Old Jan 15, 2013, 03:37 PM
cookci is offline
Joined Jul 2011
Cooki,
Hi Roger,
Do you find you still have enough in a prop hang?
Old Jan 15, 2013, 04:14 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Cooki,
no issues at all with torque in hover at 40degree.
Like you I always set ailerons as much as I can get but recently on a couple of 60" planes found I was getting reduced roll rate so moved the servo arm in to reduce throw and the roll increased.
The 70" extra hovers very sweetly, the ailerons seem plenty effective to control the torque roll even on 40degree of throw.
Old Jan 15, 2013, 04:20 PM
cookci is offline
Joined Jul 2011
Cooki,
Great news. I have ordered a protractor as I have just been guessing the movements. I think I will aim for around 40 degrees.
I'm very interested in the increased centering and resolution as my servos aren't the best.
Old Jan 16, 2013, 01:54 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
In addition to other advice, sealing hinges can, surprisingly, also increase roll rate.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jan 16, 2013, 07:29 AM
Shut up and Fly!!!
Joined Aug 2011
What servos are you running?
Old Jan 16, 2013, 12:44 PM
cookci is offline
Joined Jul 2011
Tower pro 996mg digital. They are actually quite good for what they are providing you don't end up with a fake one.
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9441 Feb 06, 2016 11:15 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 09:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 12:33 PM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 09:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 03:48 PM
