Old Jan 04, 2013, 06:36 PM
cookci is offline
Find More Posts by cookci
Joined Jul 2011
Originally Posted by bigroger View Post
I'm confused.
Are you saying your tail heavy?
What servos are you using in the elevator?
I assume your pull-pull on rudder?
I have the Motrofly DM5320-300 and 8s x4000 packs in mine plus a 120A ztw opto esc and I'm still nose heavy with my batteries back against the wing tube, my esc right back till its above the landing gear plates.
I'm using 3.5" of DA standoffs as well on mine.
Hi Roger.
The manual states 5" from the leading edge however mine is 5.5".
The tail servos are 30grams each and the rudder is pull-pull.
Maybe 5" is a bit convservative and i will be ok?
cookci is offline Find More Posts by cookci
Old Jan 04, 2013, 06:57 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
I'm not sure where my actual Cg is too be honest.
I normally balance via the wing tube to be a little nose heavy on the ground then adjust by flying and assessing what the airframe does in the air.
I aim for hands off upright and inverted 1/2 throttle first then try the 45deg inverted upline after that as a final assessment. I try to get a only slight pull to the canopy on the 45 inverted upline.
bigroger is offline Find More Posts by bigroger
Old Jan 05, 2013, 03:22 AM
cookci is offline
Joined Jul 2011
Its definitely nose heavy on the wing tube so think I will be ok. I will give it a try thanks
Old Jan 06, 2013, 05:11 PM
cookci is offline
Joined Jul 2011
It flew very well with the cg as it was
I need some bigger packs now for better flight times
Should I be aiming for around 5 amp packs for 6 cell weighing around 800 grams?
Old Jan 06, 2013, 10:03 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
If your running 6s then yes 5000mA packs should be where your looking.
The higher the C rating the better IMHO but that will mean more weight.
800g is a nice estimate to start with.
Old Jan 07, 2013, 10:59 AM
cookci is offline
Joined Jul 2011
Thanks again Roger.
Ever heard of desire power lipos?
Old Jan 07, 2013, 02:57 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Yep,
I got a few of the smaller ones in 2s for foamies.
Got them from electric wingman in the UK to try.
Old Jan 08, 2013, 04:30 AM
cookci is offline
Joined Jul 2011
I will get one ordered for the extra asap to try. They seem lightweight for the capacity .
Old Jan 08, 2013, 05:20 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Hey guys,
I'm putting together another 70" Extra from whatever I can get parts wise so if you have anything laying around please let me know. I am putting together a plane to represent Make A Wish Foundation. The color does not matter as I plan to recover it in their colors. If you wish to contribute let me know so I can mail you the forms stating the value of the donation for tax purposes. As it stands now I already have a Wing set to start. Any help would be appreciated. Thank you.
P.S. This plane will be flown at events only to include my Wings for Wishes over Virginia event. Feel free to PM if you have any questions.
jw357_23043 is offline Find More Posts by jw357_23043
Old Jan 11, 2013, 04:19 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
I have a pair of stabs that I glued the hinges in too close for my liking. They are the Orange/Blue scheme
Enterprise7 is offline Find More Posts by Enterprise7
Old Jan 11, 2013, 05:16 PM
Shut up and Fly!!!
Joined Aug 2011
I'll take them. PM sent
Old Jan 11, 2013, 07:53 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I'm confused.
I kinda figured that big honkin motor would make that plane nose heavy
Manta1 is offline Find More Posts by Manta1
Old Jan 12, 2013, 07:13 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Yes, but its not much heavier then the 4330 others are using now?
Got it back when I had a 70" slick and all balanced pretty well for me at that time in that plane.
Its not that far off neutral now with just a tad of push inverted.
I have my eye on the used A60-6xs for a stonking 6s setup for this plane.
I will try out the Ice100 over the ZTW120A opto first if nothing else the Ice100 has longer leads between motor and esc that will allow me to push the esc back further under the battery tray so that will help.
Still such a sweet flying plane with no bad habits that I have found as yet.
Old Jan 12, 2013, 07:52 PM
Shut up and Fly!!!
Joined Aug 2011
It's a difference of about 50 grams. I have the 4325 310kv on mine.
Old Jan 12, 2013, 09:05 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
I thought the dm4330 was even less difference then that? 560g versus 568g with fibre mount?
I should have got the 4325 at the time, but 3dhs flyers were suggesting the 5320 kept a bit cooler if you run back to back packs and drew less amps for the same setup.
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9813 Aug 05, 2016 11:30 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
