Old Oct 28, 2012, 10:07 PM
spcpicard is offline
Find More Posts by spcpicard
United States, LA, West Monroe
Joined May 2007
Originally Posted by Manta1 View Post
doesnt get any easier than that.
Sorry but that measurement would have left me with a spinner gap over a 1/4 of an inch.
spcpicard is offline Find More Posts by spcpicard
Old Oct 28, 2012, 11:22 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
A 1/4" is not bad to be honest. You don't want it too close as certain spinners can recess towards the cowling. That's what I have on mine and no problems. As a matter of fact it's a rocket ship with an unlimited vertical with that super duper 4325 310kv Motrofly , 19x8 prop on 8s with over 2500 watts of raw torque. The tail takes a few seconds to catch the nose when I blast out of a hover. I ring this 70" EXP out in the air just to see if it breaks and I can't do it. Wide open snaps, crankshafts along with some nasty blenders and tumbles. All it does is grawl and ask for more!! I witnessed some other name brands at SEFF do these things and break in the air. I only saw one EF crash and that was pilot error from a head on collision during a demo. One plane would have survived had the elevator stayed functioning even though the LG was gone. EF is the SHIZNIT!!
jw357_23043 is offline Find More Posts by jw357_23043
Old Oct 29, 2012, 08:55 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
1/4 inch is savvy with me but over may push the look good limit for some. The cowl is kinda ooen up front on that plane anyway isnt it?
Manta1 is offline Find More Posts by Manta1
Old Oct 29, 2012, 10:02 AM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Do you happen to know the diameter of the evolution standoffs? I may go that route and get the 38mm and 50mm sucks that I'm gonna have to dish out $40 plus shipping.
They are very beefy and designed for gasser setups. They are pre-tapped for M5 bolts. I drilled them out to use a single M5 90mm as that is superior as it is less susceptible to vibration backing out the bolt as there is a lot more area to compress in the bolt. You could probably drill them out to 6mm, but that would be about it.
Personally, on the 72" Extra I used 8/32 threaded rod with the aztech aeromodel standoffs and nuts on each end.
I have a few of those motor box extensions from the 74" Edge and the Velox which would probably be the first thing I would look at if you are not comfortable with the standoff idea.
The evolutions ones are again beefy and I am not worried on my A60-6XS setup. I posed a picture a while back.
Enterprise7 is offline Find More Posts by Enterprise7
Old Oct 29, 2012, 10:56 AM
Shut up and Fly!!!
Joined Aug 2011
It is open so it is not as noticeable as one might think.
Old Oct 29, 2012, 11:45 AM
EXTREME FLIGHT is online now
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Here is a great source for standoffs: http://www.mcmaster.com/#standard-th...ndoffs/=jxljla
EXTREME FLIGHT is online now Find More Posts by EXTREME FLIGHT
Old Oct 29, 2012, 12:00 PM
Joined May 2007
Anyone order from these guys? When I went to order it shows 4 weeks to ship?
Old Oct 29, 2012, 12:38 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Many of my friends have ordered from McMaster and have all reported positively- most importantly they were able to find the standoffs they needed... however, I cannot comment on timing as I have never ordered from there myself.
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Oct 29, 2012, 12:49 PM
Shut up and Fly!!!
Joined Aug 2011
Why don't you make them yourself from aluminum hex stock? Drill and tap the ends to 8/32 threads so you don't have the added weight of a long screw or bolt. It's basic hardware store material and not some "special aluminum" these people make. Why pay double or triple?
Old Oct 29, 2012, 02:56 PM
EXTREME FLIGHT CEO
Joined Feb 2004
They are an excellent outfit. One of their warehouses is in Atlanta and we have ordered parts in the morning and received them the same afternoon. Spend some time on their website, they have hundreds of useful products for us modelers.
Old Oct 30, 2012, 08:10 PM
bmoney69 is offline
Find More Posts by bmoney69
bmoney69's Avatar
United States, DE, Wilmington
Joined May 2004
Thanks for the suggestions, I'm just surprised no one else has used the motrofly 4325 and had problems using/ finding standoffs. I'll probably try to find some da50 3"mounts and add smaller spacers to get it the rest of the way, the only prob is I can't find them in stock.
i just went thru the same thing and i couldn't agree more. they should have left the motor box long. anyway, this is what i ended up using and they work fine.
http://www.mcmaster.com/#standard-th...ndoffs/=jyakn6
93505A033 Aluminum Male-Female Threaded Hex Standoff, 3/8" Hex, 3" Length, 10-32 Screw Size
93505A173 Aluminum Male-Female Threaded Hex Standoff, 3/8" Hex, 1/2" Length, 10-32 Screw Size
bmoney69 is offline Find More Posts by bmoney69
Old Oct 30, 2012, 08:12 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
i got mine within days. maybe what you are ordering is backordered.
Old Nov 02, 2012, 07:35 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
those using a separte reciever pack....what chemistry and size are you using? i bought an A123 1100 and i just don't think it's enough. the first pack i had did have a bad cell in it, but i'm only getting about 850mah out of the new pack from 3.6v/cell to 2v/cell. i just don't know, but i'm not confident i'll get two or three flights out of that. i'ver read that the 1100 A123 are notoriously overspec'd. thinking about going to a 2300
Old Nov 02, 2012, 07:47 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Consider trying the Hyperion 2100 mah LiFe pack. I have run these in a 78" Extra on gas and had great luck with them. It's only 12 grams heavier than the A123 for nearly double the capacity. You can get two and charge one while you fly the other one...but they charge in ~15 minutes anyway.
cwojcik is offline Find More Posts by cwojcik
Old Nov 02, 2012, 08:22 AM
Shut up and Fly!!!
Joined Aug 2011
I'm running the 1900mah LiFe pack sold by Tower Hobbies and I usually charge it after 4 flights((OCD kicks in). I could probably get 6 flights easily as I never put over 50% back into the pack during a charge. Here's the link:http://www3.towerhobbies.com/cgi-bin...&I=LXZTJ6&P=ML
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9645 Apr 24, 2016 07:42 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 08:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
